Question about Car Audio & Video
I need a wiring diagram for connecting this JBL MR-5 player up to power and speakers. It is going on a UTV so a simple hook up is needed. There are three sets of RED and WHITE connectors on the harness that are labled "rear in/out","front in/out and "aux in/out. Are these for speakers? can I plug head phones into one of these (with a "y" adapter and get sound? Thanks. I also have been looking on line for a operation manual with no luck at all. Can you help? Thanks Rick Please e-mail me at rickpotes@ymail.com
  • 2 more comments
  • rick potes Dec 13, 2009
    Thank you for the wiring instructions. A couple of more questions. If connecting power wire, RED, to switched to ACC do I still connect YELLOW at battery Positive (+) terminal?
    Also there is a second 6 terminal plastic conector with four 18 gage wires, green blue red and black, is this the switched power wire? Do I connect the black wire on this as well to ground?
    The other bigger plastic connector is 12 terminal with 16 gage wire. This is the one with a fused yellow wire ,constant power and black ground wires plus the others you mentioned.
    You are a great help but I need to ask about the switched connection again. On the 6 terminal plastic connector there is a red wire. On the 12 terminal plastic connector there is also a red wire. which red wire would be hooked up for acc switched? Also the is a blue wire that has a 1 amp in line fuse on the 12 terminal plastic connector, Is this the radio triggered you mentioned? I would like to hook up so it only is powered on when key is turned on. I can get by if I need to hook directly to battery.
    Thanks for your help and patience.
    Thank you. What are the 4 wires, red blue green and black, used for on the 6 pin plastic connector? I think this should be the last question.
    I would like to thank Benimur very much for his help, is was very helpful.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the description "...RED and WHITE connectors..." and the labels are significant as they indicate RCA jacks. These are low level signal inputs/outputs intended for external amplifiers and add-ons and not intended for speaker nor headphone connections.
Offhand, the speaker connections are:
  • white & white / black - front left;
  • gray & gray / black - front right;
  • green & green / black - rear left;
  • violet & violet / black - rear right.
Additionally, other wires are:
  • yellow - always on / constant +12 such as the battery's + terminal;
  • red - switched +12 such as the ACC terminal of the ignition switch;
  • black - any grounded metal part of the vehicle not only to the ground wire of the harness;
  • blue - radio triggered + 12 meant for a power antenna or an external amplifier.
Unfortunately, no readily available owner's manual.
Good luck and thank you for asking FixYa.
Posted on Dec 12, 2009
  • 1 more comment
  • Louie  Role
    Louie Role Dec 13, 2009
    Appreciate your postback. To your subsequent queries:
    • If connecting power wire, RED, to switched to ACC do I still connect YELLOW at battery Positive (+) terminal? - yes, as the yellow carries the main power (hence it is fused) as well as memory backup;
    • Also there is a second 6 terminal plastic conector with four 18 gage
      connect the black wire on this as well to ground? -
      no, it is not necessary
    • The other bigger plastic connector is 12 terminal with 16 gage wire. This is the one with a fused yellow wire... - yes, this is the main / power connector that will have to be used.
    Cheers.
  • Louie  Role
    I understand.
    Please use the red wire coming from the 12-pin connector. All other / un-used wires should be capped or taped (no bare strands of wire exposed).
    Yes on the blue wire. This is the wire to be connected to an external device such as a power antenna or an add-on amplifier.
  • Louie  Role
    The 6-pin connector plugs into the extension wire set of an optional hard wired remote control such as a JBL REM20GSW.
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
Wiring diagram for 2004 toyota 4runner with jbl
It appears that red is a speaker connection and not power. The complete wiring diagram I'd in the link below.
speaker wire color Toyota 4Runner Forum Largest 4Runner Forum
Jan 26, 2014 | Toyota Cars & Trucks
I need help hooking up my system from cable box to old toshiba 52 inch tv does not have hdmi on tv red, green , blue wires i also bought today a sony blue ray player speakers are not working ...
Please indicate the brand and model of your receiver, BD player and your speakers. Basically, you just need to connect the cable box and blue ray player to the receiver. The 5.1 speakers should be connected to the blue ray player, then another set of cables from your BD player to your TV. When you want to use the speakers while watching TV, you need to turn on the blue ray player too.
Sep 15, 2011 | Audio Players & Recorders
Picked up and used JBL GTS 300 and wanted to install it in my truck. I'm looking for a simple wiring diagram. I'm pretty good at hooking things up but it would be nice to have a guide. JBL is a...
You want to pick up a wiring harness for your truck at your local parts store or online, should be petty cheap. Then all you have to do is match up colors, ie purple with white stripe to purple with white stripe. The other thing you can do is hook a9 volt battery between the similar colored wire pairs from your trucks wiring. Then you will know which pairs go to which speaker. The other ones you need to know about are red, black and yellow, they should correspond directly to your trucks wires, red and black are power and yellow is the accessory
Jun 08, 2011 | JBL Car Audio & Video
Hook up monitor speakers to PC?
how i hook up my JBL SPEAKER TO MY COMPAQ COMPUTER LOST MY DIAGRAM TO THE COMPUTER FORGOT HOW TO HOOK THE WIRE TO MY COMPUTER
Mar 18, 2009 | Compaq fs740 17" CRT Monitor
VRX 928 array speakers:Can we use straightwire waveguide3 cables?
Sure, why wouldn't it be? Are you using the 14 gauge wire and what length are you needing? If running crazy long lengths double the 4 conductors together which will give you an effective 11 gauge cable.
Jan 16, 2018 | JBL Audio Players & Recorders
Bloon Fuses!
You don't need schematics to replace the fuses.
Open the speaker unit by unscrewing the back. The fuses are located near the on/off switch assembly. Replace them and screw the the unit back together.
To avoid blown fuses, try lowering the volume.
Aug 18, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
