Question about Sharp Office Equipment & Supplies
Sharp XG-MB50X-L when power is applied, the lamp and temp lights are red, the lamp led is flashing. The Lamp does not turns on. Checked light and works in another projector. I have no schematics
SOURCE: Projector lamp flashes and the temp red led lights.
Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
Posted on Sep 24, 2007
  • 17 Answers
SOURCE: Sharp XG-P10XU lamp problem
power supply or lamp ballasts, both are pretty common to produce results as you describe, looking at $600.00 or so to repair. if those are the only things wrong.
Posted on Jul 17, 2008
SOURCE: Projector won't stay on
Most projectors have a filter that can be removed and cleaned. Perhaps it is clogged or you may need a new bulb.
Posted on Apr 27, 2009
projdoc
  • 2237 Answers
SOURCE: SHARP XG-P25X PROJECTOR PROJECTOR RUNNING
either the lamp hours are close to or exceeding 1400 hrs and the lamp needs replacing, or the ballast is starting to fail. with the projector on, check the lamphours in the menu. after you replace the lamp (if it needs it), reset the lamp timer by holding down the down arrow, right arrow, and enter buttons, then press power.
Posted on Aug 04, 2009
projdoc
  • 2237 Answers
SOURCE: Sharp XG NV51XE lamp reset
if you get no led on the top, reset the bimetal breaker. take off the top and press the red button on the front of the lamp housing.
Posted on Dec 23, 2009
Lamp 1 light is on upon turning power on. Then lamp 2 light turns from green to red
it might be a bad lamp. i'd recommend reversing the 2 lamps, and if the problem follows, then you know you have a bad lamp.
May 31, 2011 | Sharp XG-PH70X Projector
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
I had to replace the lamp and it blew the fuse on the power board. I replace the fuse and put in a new lamp and still have now power. the red light will come on in the front but it will not power on. ...
When you replaced the lamp, did you use a patten part lamp or an official sharp lamp. When you replaced the fuse did you check there were no signs of burnt components on the board was the power disconnected when you changed the lamp
Mar 05, 2011 | Sharp XG-E1200U Projector
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
Replaced both bulbs with brand-new bulbs. Now all
Verify that the lamp doors are securely closed. The blinking red lights indicate a lamp problem. In this case, both appear to be defective. I doubt that the lamps are the problem. double chack all connections and doors for proper seating. Update this if the problem remains.
Thanks,
Dan
Apr 16, 2010 | Sharp XG-PH50X Multimedia Projector
Sharp XG-E650UB LCD Projector won't display picture.
it only takes up to a 640x480 resolution. it is a very antiquated projector.
Aug 10, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
SHARP XG-P25X PROJECTOR PROJECTOR RUNNING THEN IT IS AUTOLOG OFF AFTER 2MIN. WHEN PROJECTOR IS RUNNING ITS SHOW GREEN LED AFTER LOG OFF IT IS SHOW RED LED ON LAMP AND POWER LED
Jan 10, 2009 | Sharp Conference Series XG-P25X Multimedia...
TV turns off aftering powering up. red LED flashes 3 times.
3 red blinks means th lamp door in not on. if you have installed the lamp door corectly and it still does this solder all three pins together on the door switch.
Oct 08, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
486 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
