Question about Makita 6339DWDE 14.4V 1/2" MXT Driver-Drill Kit Tools
Dont no what new chuck i need for my makita 6339d 14.4v
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: chuck removal
First open the chuck jaws and remove the LH chuck retaining screw. After that find a bent handle allen wrench about the size of the chuck. Put the shorter end in the chuck and clamp down on it. Put chuck on a block of wood or workbench with the long end at about a 30 degree angle so you can hit it counterclockwise with a hammer. It might take a couple hits but it will come off.
Posted on Jan 08, 2009
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
  • 313 Answers
SOURCE: how do i remove the chuck from a Makita 8391D
I think you will find that if you open the chuck fully you will see a cross head screw inside the chuck which you need to undo before removing the chuck. this secure the chuck from unscrewing while being used in reverse to undo screws. Once this screw is out a spanner is used at the base of the chuck to unscrew it from the shaft. this may need a short sharpe shock to get it to move.
Posted on Jul 31, 2010
SOURCE: Hi i broke the chuck on my 1/2 makita cordless
Put the biggest hex key you have in the chuck and tighten it then hit it clockwise with the spindle lock engaged a couple of times. The screw in the chuck will then undo clockwise and the chuck can be undone after by putting the allen key back in and unscrewing it anti-clockwise maybe with a light tap from a mallet.
Hope this helps
Jon
Posted on Nov 05, 2010
The chuck on my new makita drill is stuck with a drill bit in it. It won't open back up.
This is caused by tightening the chuck using the drills power, if you clamp the bit in a vice and using a pair of multi grips on the chuck in an anti clockwise direction gently bounce the grips and after a few tries it will undo, don't use too much pressure or try to unwind it in one move or myou will damage the chuck sleeve
Oct 16, 2012 | Makita Drills
What keyless chucks will work on my makita hammer drill will a dewalt xrp chuck work on a makita
as long as the chuck is used for a hammer drill and the thread size is exact yes it will. I believe the thread is 1/2-20 and also make sure the chuck has a hole in the center for the reversing screw to keep it from loosening up. Let me know if you need more assistance. The thread size is usually stamped on the side of the chuck. Makita sometimes used a metric thread.
Dec 31, 2011 | Makita Drills
How can i replace the keyless chuck on my makita
I answered that question already on another post, but if you need to know how to remove the chuck I have detailed instructions in the TIP SECTION on how to do this. Let me know if you need more help
Dec 31, 2011 | Dewalt Makita Bhp452 18v Lxt Lithiumion...
The chuck wont open or close properly the three bits inside dont work at the same time they are all different lengths
Hi, the simplest and best solution is to replace the whole chuck. This is a cheap and easy thing to do and suitable 13mm chucks are available online from lots of different manufacturers and are nearly all compatible. here is link to a genuine Makita replacement chuck , but there are plenty of cheaper brands to choose from. http://www.ereplacementparts.com/keyless-drill-chuck-p-90496.html Hope this was of use to you.
Jan 22, 2011 | Makita 6349DWDE 18V 1/2" MXT Driver -...
How do I remove the Chuck from my Mikida 9.6 volt keyless drill
Dont know about a Makita, but my Craftsman drill , if you open the chuck all the way and look inside the hole where the bit goes, there;s a screw there that you can use to remove the chuck. amybe yours is the same way.
Nov 23, 2010 | Makita Keyless Drill Chuck Set, HP1501...
How do i remove the chuck from a Makita 8391D
Jul 31, 2010 | Makita Drills
Need to replace worn chuck on my makita 6480 drill, thanks
If you back off the jaws(fully open) you should see a bolthead. Loosen this and the chuck should pop off with a few easy taps from a small hammer. If you dont see the bolthead, then all you have to do is turn the chuck to a fully open position and keep turning with force in the same direction and the chuck should unscrew. This type can be very difficult to remove. Exercise patience and it will come off. Thanks, Dana
Sep 30, 2009 | Makita 6408K 3/8" Variable Speed,...
Damaged chuck
Grasp chuck, reverse it until fully open. Look inside where bit goes and should be an allen head or torque head screw holding chuck to motor arbor/shaft.
May 14, 2009 | Makita 5/8" 2 Spd Hammer Drill
May 04, 2009 | Makita Drills
Makita 6408 drill motor. can't see how to replace the chuck.
If you have the 6408 as listed the spindle is threaded and you are correct there is no retaining screw. What you would need to do is find a bent handle allen wrench about the size of the chuck capacity 3/8" and insert the shorter end in the chuck and tighten. put the chuck on a block of wood or workbench and position the long end at about a 30 degree angle in the counter clockwise position and strike it with a hammer, this might take a couple hits. If this is not a 6408 let me know and I will look at the tool for you and see what you got.
Jan 23, 2009 | Makita 6408K 3/8" Variable Speed,...
Makita 6339DWDE 14.4V 1/2" MXT Driver-Drill Kit  Tools Logo
124 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
