Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
WGR614 v6 Fails to connect to internet, no wirelss signal
Hi
I made the mistake of unplugging my WGR614 wireless router while it was starting up (or while the modem was still starting up --- it's a blur now!). The cable modem had dropped connection. After that no matter how many times I restart modem and router the router does not get to the internet (wireless & internet are not lit). Confirmed the modem works without router on main PC. I need router for second PC & wireless laptop. Should I press reset button and then what?
Thanks, SBA
  • sbanow Dec 12, 2009
    What I needed to do was reset the router (tricky little 'button" /indentation at back of router). Internet connection held for a couple of minutes, then dropped. Repeated and quickly went to the netgear site using my gateway IP as the url, to set router with their wizard. Works now ! Found this from a similar question and response.
    SBA
  • sbanow Dec 13, 2009
    Probably not the router --- using it over a year, fine. May be recent Windows updates (Dec 9) or interference from new cordless phone near to router. thanks for suggestions. The cable also supplies digital phone --- it's a complicated world...
    SBA
    Scholar:
  • 124 Answers
* Reset the router to factory default settings.. * access the router page using www.routerlogin.net * username - admin , password - password * run the setup wizard * it will automatically redirect you if the firmware of the router is not latest it will ask you to upgrade it .. * it will be automatic wizard so follow the instructions... * in case if it doesnt do that download the firmware from kb.netgear.com* configure the router then i hope so it will be working fine ..
THANKS FOR USING FIXYA
Posted on Oct 31, 2011
    Problem Solver:
  • 5 Answers
Mabey there is a problem with the LAN cable or a connection error
Posted on Dec 12, 2009
  • dj nick Dec 13, 2009
    take it back where you got the router from and get a new one
SOURCE:
Trying to set up a netgear access point with a moterola surfboard
Try doing a hard reset on the Netgear router then powercycle it together with the modem
Mar 07, 2010 | NetGear WGR614 Wireless Router
Connected WGR614 v6 to DG814. Have internet light on, no wifi. Can't connect to the WGR614 via lan from pc. Tried to hard reset nothing happens. The PC and DG814 show connection to the WGR614 but can not...
Is this the initial set-up of the network? Sometimes it just needs to be rebooted a few times to connect. The way to reboot the network is to turn off the computers, then unplug the router, next unplug the modem. wait about 30/60 seconds then plug in the power to the modem. Wait for the modem to fully boot. Wait a minute or two, then plug in the power to the router. Wait till it has booted, another minute or two. Once the router is fully booted, then turn on the pc and check to see if it connects. If the computer was previously connected to the modem, before the router was incorporated, it still has the ip address assigned by the modem and has trouble releasing it and getting an ip address from the router.
Dec 02, 2009 | NetGear WGR614 Wireless Router
Describe your WGR614 wireless led not ON problem
go to the advance wireless setting and check if radio is disabled. if it is. enable it.
Nov 06, 2009 | NetGear WGR614 Wireless Router
Issue with router and ethernet cables
I imagine you reset/unplugged all of your routers, switches, and computers, starting with your modem, then router, and then each system?
There is a setup disk that need to be used to program your router with the ISP settings, passwords, and protocols for port forwarding, etc. I imagine you tried that.
Did you try all of your cables to make sure they weren't defective?
If you tried these,and the problem persists, the issue is a defective router. By default, the unit should transmit a wireless signal, and be ready to act as a routing switch for your other systems.
Mar 26, 2009 | NetGear WGR614 Wireless Router
Netgear WGR614 v6 router drops connection
Hi, what ISP are you using (aol,tiscali...?), and how are you connecting to the router? Wired or wireless? I had similar problems with mine, it wouldn't connect or would drop connection, or loose all the settings. I updated the firmware to the latest from here:-
http://kbserver.netgear.com/products/WGR614v6.asp
Be sure this is the correct model as firmware differes from model to model.
Then I had to manually configure my ISP settings etc. Or you may have software from your ISP which configures for you.
Hope this helps.
Jan 22, 2009 | NetGear WGR614 Wireless Router
Wireless light is green but i don't receive any signal on my laptop?
Check to see if the SSID is being broadcast. That could probably you be your problem.
Thanks,
Jan 02, 2008 | Actiontec GT701WG Router (actiongt701wg)
Losing connection with WGR614 v6 router
Well, glad I found someone with the same problem, the answer will certianly surprise you.
The answer is cordless phones and satellite interent.
if you have cordless phones and/or satellite internet it will lose signal.
They run on the same frequency.
To fix it log into your router, goto wireless settings, then check the box for enable channel settings. You may have to reboot the router and PC.
Should help.
Good luck and have a happy new year.
Dec 27, 2007 | NetGear WGR614 Wireless Router
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
248 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
