Question about NEC MultiSync 1940CX 19" LCD Monitor
The base of my monitor is broken where the screw from monitor attaches to base to hold monitor upwirght plastic broken off mickey mouse see up can I order a new base?
  • 63 Answers
Yes you can order a new base, try any computer shop to see if they have 1 that fits or any major computer shop, cheers
Posted on Dec 12, 2009
Why does it have so much amazing stuff in it? And why does it make me laugh?
Bethany, Mickey is just the coolest !!! what more can be said?
Mickey mouse is 88 years old now. Check the attached links cartoons, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
First Mickey Mouse Apperance EVER May 15 1928
Roughin It Mickey Mouse Cartoon Disney Shorts
Dancevidaniya Mickey Mouse Cartoon Disney Shorts
Movie Time Mickey Mouse Cartoon Disney Shorts
Apr 18, 2016 | Disney Fisher Price Dance Star Mickey...
I need help removing the stand to my ASUS VH197D LED monitor so that i can attach my wall mount.
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
Aug 01, 2011 | ASUS VH197D LCD TV
How do you dismantle AL1917W LCD monitor?
Remove the base and all the screws, base plastic attachment cover will have to be remove to get to the base mounting screws. Use flat blade screw driver, starting at the botom edge and work you way around.
See service mauals here: http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1917&kategoria=&kat2=all
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 25, 2010 | Acer AL1917W LCD Monitor
How do you take the base of a envision H170L
Can't find too much info on this monitor. Look for a crease/gap in the plastic around the neck of the stand. Most likely a plastic cover is covering the screws you need to unscrew. You'll probably just have to pop it off.
You may have to first remove the flat part of the base (if looks like it separates from the neck). Check the bottom of the base for tabs or plastic clips holding it to the neck. If the flat part of the base doesn't come off, just look for the plastic covers mentioned above to reveal the screws that are holding the base on.
Jan 12, 2010 | Envision H170L Monitor
How do I open it to look inside?
First, lay the tv/monitor on its screen on something level and soft as not to damage the screen. Remove any visible screws that seem to attach the base to the unit. Some models you have to look under the base for pins orso to push together to slide the base from the stand, only then you could reach the 1 screw holding the monitor to the stand....Once stand removed, remove any screws you see holding the monitor casing together, usually only a few screws since they are mostly held together by plastic "clips"...Once screws are removed, then gently insert a flat(screwdriver orso) inbetween the case?housing, repeat this all the way around the case/housing till completely loose....You will prob have a few wires or maybe a ground wire that you would have to remove before completely being able to seperate both sides(front case, back case)..Sometimes you might have to unscrew and remove the skinny washer/nut around the cable input orso..
Nov 18, 2009 | X2Gen MG19MY 19" LCD Monitor
Is there any way to remove the base from the Optiquest Q7 monitor? We would like to attach the monitor directly to the server rack.
On mine I pulled on the round cover where the base attaches to the screen. It came off and there are 4 screws underneath. Remove those screws that hold on the base
Jul 15, 2009 | ViewSonic OptiQuest Monitor
Broken flash handle
Loctite makes a glue suitable for this type of repair. It is very strong and does not melt the plastic if too much is applies, unlkie super glue.
Apr 02, 2009 | Quantaray Cameras
Cannot attach base to samsung lcd monitor sw2233
Llay the monitor face down on the floor (I put it in the styrofoam from the package) and then put it up against a solid surface. Then push the part into the socket before attaching the round base.
I tried pushing down onto the monitor while holding it upright but that didn't work. When I called Samsung tech support the solution above is what they told me to try and it worked.
Mar 19, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
NEC MultiSync 1940CX 19" LCD Monitor Logo
182 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
