Question about Cell Phones
My Ummeox q421 will not charge do i stick it in the usb hole or the circle hole
  • 82 Answers
Circle hole.
Posted on Jan 01, 2010
My dad gave me a RCA tablet. and I have no clue which version it is it says that the models is a RCT6378W2. when he gave it to me all it has was a cover on it. my dad said to go to walmart and buy a...
Here is a link to the users manual for your tablet.
http://www.rcatablets.com/sites/default/files/RCT6378W2_RCA.pdf
There is a hole on the back of the tablet that you can stick a paper clip in to reset the computer. If this doesn't work then I would make sure you have the right charger for the tablet. You have to use the round DC charging hole to charge it. It will not charge thru the USB port.
Aug 17, 2014 | Tablets & eReaders
Moto v9 not charging solution
The chargers you are using. Are they Motorola Original parts or from another manufacturer?
Definitely odd that it works with the USB charger but not the wall or car chargers. Can you take it into an at&t corporate store and have them try one of their chargers in the phone. This way we can eliminate if it could be the chargers. Could be something with the charging port on the phone though there is a hole in that theory as the USB charger works.
If you take the battery door off your phone you should see a little white or pink/red paper circle. Which color is it?
How long have you had the phone?
Feb 28, 2011 | Motorola Mobility MOTORAZR2 V9 Cellular...
Flip Mino HD wont do anything and the light is stuck on. Had it plugged into USB to download and charge...came back stuck like this.
You can always try a reset... on bottom of camera inside opening for tripod there is a tiny hole. Take a small paper clip and stick it in the hole and hold to a count of seven. Repeat a couple times.... and good luck.
Simple things first.
Feb 17, 2010 | Pure Digital Flip Video Ultra Camcorder
Tomtom will not turn on.
Your battery might be completely flat.
Try the followings:
1) Connect your Tomtom to a PC/LAPTOP via a USB data cable or to the provided car charger: you should see a 'red' indicator lighted near the ON/OFF push button: this indicates that power is getting to your device.
2) If the red indicator is function is on, stick a tooth pick or match stick in the 'reset' hole at the bottom of the unit (opposite the mini USB cable port) and while still applying pressure to trigger the reset button, turn the device ON via the ON/OFF button at the top: this will cause the system to go into diagnostic mode/hard reset.
3) Take the the tooth pick/match stick out of the reset hole and the power the device off.
4) The device should turn on now, at least while still being charged.
If your device cannot be turn on while being charged and reset, then you have a major failure.
If your device can be only be turn on while being charged , then you will need to replace the internal rechargeable battery.
Hope it helps: let me know hoe you go.
Jan 08, 2010 | Tomtom ONE GPS Receiver
My TomTom one xl is showing a big red X on the opening screen . and cant do and thing else.
If you have a big red circle with a white X in it, indicates that you have a serious problem with your unit:
1) Try a 'hard reset': while the power is on, stick a small (tooth/match) stick through the hole under your unit base and opposite to were the USB connector go, for a few seconds, remove the pressure on the stick will cause a complete system reboot if possible.
2) If above does not work, connect to the computer, use Windows Explorer -> Properties -> Tools > Error-checking to scan and repair any problem with your Tomtom drive & check if you still have a problem.
3) If above does not work, and this is usually the solution for 'big X error', use TomTom Home to restore from a previous backup followed by a device update while connected online.
Hope it helps: let me know how you go and good luck!
Jan 06, 2010 | Tomtom GPS
My tomtom is connecting fine to the computer, but once I get the pop up window saying my device is safe to properly disconnect and I disconnect it and try to turn it on without it being hooked up to the...
If you have a big red circle with a white X in it, it usually means that your TomTom One 'disk' is corrupted: first try a 'hard reset' , while the power is on, stick a small (tooth) stick through the hole under your unit base and opposite to were the USB connector go, for a few seconds, remove the pressur on the stick will cause a complete system reboot if possible.
Next, since you can connect to the computer, use Windows Explorer -> Properties -> Tools > Error-checking to scan and repair any problem with your Tomtom drive & check if you still have a problem.
If there is an error or you cannot reboot, hopefully you have a backup made either by copying the whole unit disk content or more traditionally via TomTom Home, I would suggest a complete restore your device content follow by a TomTom Home device update.
Hope it helps: let me know how you go.
Jan 05, 2010 | Tomtom ONE XL GPS
I have a umeox q421 phone and when i try to plug in my usb cable to my computer to transfer my songs. my phone tells me that the data file can not be read. i have been trying everything for 2 days and i...
we did have the same problem. you need to have a memory stick for it to save downloaded stuff on it, the phone memory stores only things like pics taking with the phone. hope that helps
Nov 10, 2009 | Cell Phones
Where Charge
Again :)... U plug a special usb key in the headphones hole...so u charge via usb.
Sep 17, 2008 | Mpio FL350 MP3 Player
When I connect the USB cable to my PC and phone, my phone shows a circle and connected shows above the circle but my PC says I am not connected.
I have a customer with a Dell that never sees my USB memory stick. It chimes and acts like it is connected, but it still never shows up on the panel.
We have never been able to solve the issue, so we just move to a different computer.
You can try finding the USB port in my computer device manager, then tell us if you fixed it, but I don't hold out much success.
Carl
Sep 02, 2008 | Samsung Lands Phones
Sync issue
SanDisk Sansa View - Reset - Use the slide switch on the side and hold it tward the Mic hole for 10 sec. Then try to reload the drivers onto your computer, and use the disconnect button in the software, then re-connect the USB plug.
Dec 24, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
