Question about Panasonic EUR7720KY0 Remote Control
EUR7722X30 remote controler problem. Cant operate the dvd player with it. Not battery problem, the batteries are new.
  • wclwong May 11, 2010
    same issue here. did you try to use it to control other device (TV ?) thus caused this problem ?
  • evatihanyi May 11, 2010
    My problem with the remote controller has been solved. Thank you.
marsrover
  • 682 Answers
SOURCE: Remote problem
dear friend:after apply fresh and new battery and install it in right direction bring an normal radio set -put it in am postion tune dial in position between channel and press power button in remote many times you will hear clicks eash time you press the button if you hear the clicks clearly the problem will be in the player .
Posted on Feb 24, 2008
ButtFuzz
  • 463 Answers
SOURCE: remote control has stopped working
If you have replaced the batteries with KNOWN GOOD ones, observed the proper polarity when re-installing the batteries AND made sure the remote is in DVD "mode" (if it is a multi-remote) when trying to use it, the remote is bad. Replace the remote.
Posted on Mar 25, 2009
SOURCE: Cannot operate SA-HT520 by remote control
PRESS DVD/CD BUTTON IN THE REMOTE AND EVERYTHING WILL BE FINE
Posted on Jun 11, 2009
  • 5 Answers
SOURCE: Philip Universal Remote can't control Lasonic DVD player
Hi
You can try to consult the codelist here:
www.urc.philips.com
Posted on Jun 18, 2009
  • 66 Answers
SOURCE: remote control problem
You should call your manufacturer and see if you can have either the dvd player replaced or the remote replaced.
Posted on Aug 04, 2009
Remote stopped functioning for dvd\vcr unit
When the remote control won't operate the DVD player recorder, check the batteries. Try replacing them and see if the remote works. If the batteries are fine, the code on the remote and the code on the DVD player recorder might not be the same. When aiming the remote at the unit a number will be displayed. To set the remote to the same number, which will be 1, 2, or 3, press down OK on the remote as the appropriate number at same time.
God bless you
Sep 27, 2012 | Samsung DVD-VR375 DVD Recorder/VCR
I have just purchased a magnavox blue ray dvd player, but I cannot get the dvd player to operate after I press the startup button on thed remote.Can you please help me. Thanks
naturally, make sure everything is plugged in correctly, and that the batteries in the remote or charged.
if the player is new, you might want to check the manual to make sure you are operating it correctly.
if the player is not new, and has worked in the past, then the problem is probably something trivial like batteries, or wearing out of the iod on the remote, the plastic on the button in the remote, or something interfering with the signal.
Mar 27, 2011 | Philips Magnavox DVD/VCR Dual Player
I bought this particular unit, years ago. And, though I don't watch dvds very often, the remote control stopped working this week. I thought that the reason was because of the batteries that were in the...
Apparently, the original remote is no longer available, but it always worth trawling eBay for used remotes. I've found many unavailable remotes for customers there. Remotes.com have a substitute remote available for $19.99 plus $7.95 shipping = £27.94 total.
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12895166582000&smodel=DVD224&brand_pn=COBY_DVD224
I will try some other sources and will post back if I can find an original.
Regards,
BElectric
Nov 11, 2010 | Coby DVD-224 Player
Panasonic HT520 remote not responding
Hi.Im Dani from Spain.I have the same pb.To solve this problem-a new one remote.My remote its
a panasonic universal remote control dvd system eur7722x30(i dint find it but i find this:panasonic universal remote control dvd system eur7722x40;i need to see if its compatible(hope so)
This is the link http://cgi.ebay.com/Panasonic-Universal-Remote-Control-DVD-Syste-EUR7722XD0_W0QQitemZ130350261905QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1e597b2691
Good luck
Jan 24, 2010 | Panasonic SC-HT520 System
Samsung DVD (1500) Remote problem.
Try to reset the blu ray player's remote control.
Remove the batteries and hold down the POWER button on it for 30 seconds.
Then replace the batteries with fresh ones
Jul 03, 2009 | Samsung BD-P1500 Blu-Ray Player
Remote won;t work
Hi
if the battery is new, you need to replace the IR in the remote control this is the bad parts thats why you can not operate.
Thanks!
Jun 06, 2009 | Daewoo DVD Player
Replaced battery in remote still doesn't work.Cyberhome, RMC-300Z
Where can I buy a new remote control for 300 dvd player?
Feb 05, 2009 | Cyberhome CH-DVD 300 DVD Player
My remote does not work
Reset remote. If universal remote, put on dvd mode.
  • If your remote has a Reset button, take out the batteries and press the Reset button for 2 or 3 seconds. Re-inset the batteries and try using the remote again.
  • Note: Many remotes have a small hole marked Reset instead of a raised Reset button. To activate the Reset function, you need to push a thin, rigid wire (for example, a straightened paper clip) into the hole to "press" the Reset button. Also, the Reset button or Reset hole may be located under a sliding cover on the lower section of the remote.
  • Remove the batteries and hold down the POWER button for 1 minute. Insert fresh batteries and try using the remote control again.
  • If this does not solve your problem, remove the batteries again and press and release each button on the remote control once, then repeat. Re-insert the batteries and try operating your remote again.
Otherwise you need a new remote. If under warranty call manufacture to see about getting one free of charge. They can also help you purchase a new one if not under warranty.
Jun 12, 2008 | Cyberhome CH-DVD 300 DVD Player
Panasonic EUR7720KY0 Remote Control Logo
462 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
