Question about Kirby Generation 3 Bagged Upright Vacuum
How do I detach the bag? - Kirby Generation 3 Bagged Upright Vacuum
  • Kirby Expert
  • 324 Answers
Watch the instructional video on our site;
http://www.goodvac.com/
Good luck,
Rocky
Posted on Dec 15, 2009
  • 85 Answers
From behind grab under the emptor and turn they stick
How do I replace the OUTER bag on my Oreck XL2200?
Depends on whether you have a bag dock or not. If you have a bag dock, squeeze the inside part where it hinges and pull off the outer part, then spread the inner part and pull off of the handle tube. Then you can pull the outer bag off of the same handle tube connection and then disconnect from the bottom. Installation is just the reverse of taking it off. If you do not have a bag dock, there is a "U" shaped clip that goes over the top of the bag connection on the handle tube. Use a flat blade screwdriver to pry up on the clip and pull it off. You can then pull your bag off the handle tube and disconnect at the bottom and replace your bag. Hope this helps!
Oct 05, 2014 | Oreck XL2200RS lightweight upright vacuum...
Blue plastic bag holder on oreck upright detached - how to put it back in?
Amy, not sure from your description whether the outer part is what came off or the smaller, inner part came off. If it is the outer part, all you need to do is squeeze the two prongs of the inner part of the bag holder together and slip the two pegs into the holes on the outer part of the holder. If the inner part came off then you have to spread it, so that it will go over the opening on the handle, and then follow the directions I gave to install the outer part. Hope this helps.
Feb 17, 2014 | Oreck XL Ultra Bagged Upright Vacuum
How to set up kirby to vacuum mattress
Detach lower end of bag from body of vacuum.
Attach hose to the opening.
Attach above floor tool for vacuuming.
See video instructions on below site.
http://www.kirby.com/Portals/0/videos.html
Feb 22, 2011 | Kirby Generation 3 Bagged Upright Vacuum
The machine keeps shutting off with a full bag lite everytime I turn it on..? the previous bag isn't full and it does it with a brand new one
The most probable problem is a clog in the hose.
First detach the hose from the vacuum and turn it on. If it runs without the hose, you're on the right track. Detach the hose from the wands and drop a coin in one end. Lift the end so the coin should drop through. If it doesn't, there's definitely a clog. Plug the hose into the exhaust port, place other end into front of vacuum, and turn it on. This usually clears it.
Also check the elbow at the power nozzle. Clogs here are usually visible, but you can hold the PN up to the light to check for a blockage.
If none of these take care of the problem, the entire vacuum needs to be taken to an authorized Aerus Electrolux shop for diagnosis and repair.
http://www.aerushome.com/storelocator/
Feb 17, 2011 | Electrolux C101 Bagged Canister Vacuum
My vacuum turns on for a second and shuts off. I have replaced the bag and filter, and it still happens. The replace bag light turns on after I do this.
1. Detach the hose and turn on. If it runs, place hand over opening. If it shuts off, the control valve assembly is dirty or worn out and needs cleaned/replaced. This is a job that should be done by an authorized Aerus Electrolux service tech. It's most commonly caused by use of "made-to-fit Electrolux" bags, rather than the genuine bags made by Home Solutions.
2. If the vacuum keeps running after detaching hose and placing hand over in port, then check the hose. Drop a coin or similar small item through the hose. If it doesn't go through, there's a clog. It will probably be at the bend of the handle. Plug hose into exhaust port and turn vacuum on. Make sure the other end of the hose is in a bag to catch the dirt and stuff coming out. If you have problems, it's easily removed by a service tech.
Dec 04, 2010 | Electrolux Epic 6500 Vacuum
Smelly bag . How do I get it off?
See tthe instructions how to install/ remove disposable bag:
http://www.goodvac.com/articles.asp?id=137#1.2.2
If you need extra bags you can order them on our website
Good Luck,
Rocky
Dec 08, 2009 | Kirby G5 Bagged Upright Vacuum
How do you replace the bag on a Hoover Elite 200?
I had the same problem and just figured it out myself. Detach the clamp (attamched to the bag) from the handle. Then slide the bag out from the clamp either left or right. The cloth bag then opnes and you can replace the actual bag inside. Hope this helps.
Nov 11, 2009 | Vacuums
Kirby G 6 but it only blows air out, no suction. Also how do you detach the cloth bag to wash it?
I have the solution for the cloth bag laundering process...
Here is a link to my guide for cleaning the Kirby cloth bag...
http://reviews.ebay.com/DEODORIZING-CLEA...
It should be helpful. :0)
The Tech Drive problem SHOULD be able to be fixed easily and fairly cheaply by a vac shop or Kirby distributor. There is an adjustment that needs to be made, but it shouldn't require purchasing any parts.
Marci
Nov 17, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby attachments
Just twist it out away from the machine. Sometimes you have to pull HARD. You can't break it.
Marci
Sep 23, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
48 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
