Question about Apple iPhone 3G
Cannot get or send email on iphone. I get error message: username or password for imap.apple.mail.com incorrect. I deleted my account to set it up again. Now it won't allow me to set up account. Get same error message. Email worked fine up until yesterday. Help!
  • Anonymous Mar 12, 2014
    I havn't been able to receive my email and at the bottom of my screen I keep seeing "incorrect username or password.
    Scholar:
  • 55 Answers
If the Apple email server was having a problem for a short period of time, this could have been the result, an error message about failing to be able to log you in. In which case waiting a short while and trying again, or trying from a different device (like a computer) to check would have been a good course of action ...
Usually if you have an email "address," meaning a username with an email provider, and you delete the entire account, they will not allow you to choose the same username again, it's gone forever.
If your email account is permanently deleted, can you set up a new one with a different, unique username?
For audio expertise with recording and conferences and conventions, as well as PA System help with feedback and noise problems, visit my website at www.rexark.com
Posted on Mar 06, 2010
SOURCE:
How get into email by phone
Hi James
o Set Up Email on Your Android-based Device
  1. Open your device's email application.
  2. If you already have an email account set up, press Menu and tap Accounts. Press Menu again and tap Add account.
  3. Type your Email address and Password, and click Next.
  4. If you have IMAP, tap IMAP. If you're not sure, tap POP3.
  5. Use these settings for your incoming server, depending on the type of email you have: POP3 Username Enter your full email address. Password Enter your email account password. POP3 server pop.secureserver.net Port IMAP Username Enter your full email address. Password Enter your email account password. IMAP server imap.secureserver.net Port
  6. Use these settings for your outgoing server:As a troubleshooting step, you must have enabled SMTP relays for your account. For more information, see See your SMTP relays.
    SMTP (Outgoing Mail Server) SMTP server smtpout.secureserver.net Port Security type None
  7. Select Require sign-in and make sure your Username (your full email address) and Password are correct. Tap Next.
  8. Tap Next again. Name your account and enter the name you want to display on outgoing messages.
  9. Tap Done.
That's it. If everything is working OK, you should see some email messages. To make sure you can send messages, go ahead and compose an email and send it to yourself.
Mar 04, 2016 | Cell Phones
Trying to set up first email acc on iPhone 4.
in mail settings did you add the incoming and outgoing mail server address for the account?
Feb 10, 2018 | Cell Phones
Help yahoo com
Symptoms You can try these basic steps to troubleshoot Mail on your iPhone, iPad, or iPod touch. If you see a specific error message, follow the basic steps, then the steps for that error message. For example, you might see one of these messages:
  • Cannot get mail
  • Unable to move message
  • Username or password is incorrect
  • Relaying denied
  • Email address rejected by the server
Resolution First, try these basic troubleshooting steps:
  1. Tap Safari and load a webpage. If you can load a webpage, then your device has Internet access. If you can't load a webpage, check your Wi-Fi connection or try a different Internet connection:
    • Try a different Wi-Fi connection.
    • If your iOS device has an active cellular data plan, tap Settings > Wi-Fi and turn off Wi-Fi.
    • If the affected email account is provided by your Internet provider, see if your issue is resolved while connected to your home Wi-Fi network.*
  2. Log in to your email provider's website to make sure that the account is active and the password is correct.
  3. Make sure your settings are correct using Mail Settings Lookup.
  4. Restart your iOS device.
  5. Delete the affected email account from your device.
    1. Tap Settings > Mail, Contacts, Calendars.
    2. Tap the affected email account.
    3. Tap Delete Account.
    4. Add your account again.
* If you can only use your email account while connected to your home network, this might be a limitation put in place by your email service provider. For help, please contact your email service provider.
Follow the steps below for specific alerts.
"Cannot get mail" Make sure you entered the correct password. If you enabled two-step verification through your email service provider, contact them to see if you need a special password for your iOS device.
"Unable to move message"
  1. Tap Settings > Mail, Contacts, Calendar, then tap your email.
  2. Tap Account.
  3. Tap Advanced.
  4. Tap Deleted Mailbox and make sure it's set to Trash.
  5. Tap Advanced > Account, then tap Done.
    Note: If you see the issue again, repeat steps 1 through 3, tap IMAP Path Prefix, then Inbox. After you make your changes, tap Account, then Done.
"Username or password is incorrect" with POP3 account Before you check your email on your iOS device, close it on your computer and other devices.
To see if your account is a POP3 account use the Mail Settings Lookup tool or:
  1. Go to Settings > Mail, Contacts, Calendars and tap the account.
  2. Look for the label POP ACCOUNT INFORMATION.
If your email provider offers IMAP, remove the POP3 account, then add the account with your provider's IMAP settings. POP3 communicates with one mail client at a time. If more than one mail client tries to connect, you might see a username or password error.
"Relaying denied" or "Email address rejected by the server" when you try to send email This error indicates that either an email address is incorrect or your settings aren't correct for your current connection. Make sure the email address is correct for messages in the Outbox or try a different port:
  • If you're on a Wi-Fi network connected to the same network as your email domain, such as your Cable or DSL provider, try port 25:
    2. Tap your email account, then tap Account.
    3. Scroll down and tap Outgoing Mail Server.
    4. Tap Primary Server, then tap Server Port.
    5. Delete the current port and enter 25.
    6. Tap Done.
  • When you connect to a cellular data or a different Wi-Fi network, you need to use an alternate port and authentication, if your email provider supports it. The most common alternate ports are 465 and 587. Check with your email provider for specific settings.
If you still can't send email, you can set up an alternate SMTP server.
Get help troubleshooting iCloud Mail.
Aug 29, 2014 | Yahoo Mail
Sign in gmail
The issue that originally caused the error "imap.gmail.com is not responding" on several accounts has now been resolved, so I'm closing this thread since it's extremely long and most of the recent posts aren't related to the original issue. If you still have an issue with your IMAP connection, please feel free to start a new post. It will help if you an also include the following information so the community can help you troubleshoot.
  1. If you've upgraded to iOS, try removing and then recreating the account and that's been doing the trick.
  2. Try logging into your account through the web and make sure nothing is wrong with your username, password or general access.
  3. Double check your IMAP settings (servers, ports, etc): http://support.google.com/mail/bin/answer.py?hl=en&answer=75726&topic=1668961&ctx=topic
  4. Try removing and then recreating the account.
  5. Did you recently activity 2-step verification? If so, make sure you're entering the application specific password: http://support.google.com/accounts/bin/answer.py?hl=en&answer=185833
  6. A good rule of thumb is that if you're having an IMAP issue on only one device or with one email client, then it's most likely settings and not an issue with your account. If you're getting the same error across devices and email clients (Apple Mail, iOS, Outlook, Thunderbird, etc), then it might be something else. If you only use one device/email client, try a second to help narrow down if it's just the settings.
Source: https://productforums.google.com/forum/#!topic/gmail/_uhrxzpDapc
Hope that helps!
Mar 20, 2014 | Computers & Internet
How to setup push mail for samsung monte phone on gmail
I'm not sure if this is of any help
to anyone but these are the steps
I used to set up email on my
Monte. I'm using an old hotmail
account that didn't support IMAP
or SMTP properly.
1.Set Up a GMail account eg.
someone@gmail.com
2.Set GMail to allow IMAP via the
settings link the the top right
hand corner. (under Forwarding
and POP/IMAP)
3.Under accounts and import set
up the send mail as to send mail as
someone@hotmail.co.uk. Set this
to default send adress
4.In the same tab under check
mail using pop3 set up the pop3 to
recieve from someone@
hotmail.co.uk
5.Under Email Accounts on the
Monte set up email with the
following charecteristics:
Account Name: Hotmail
SMTP Server: smtp.gmail.com
SMTP Port: 465
Secure Connection: SSL
Incoming Server Type: IMAP4
IMAP4 Server: imap.gmail.com
IMAP Port: 993
APOP login: greyed out
Download Limit: 500
IMAP4 incoming email: New
Retrieving option: Whole Message
Keep on server: checked
My email adress: someone@
hotmail.co.uk (This is the adress
the phone puts in the from line of
an email)
Username: someone@gmail.com
Password: gmail password
Pop before smtp: greyed out
SMTP auth: checked
Same as POP3/IMAP4: checked
Username: greyed out
Passowrd: greyed out
This should allow you to recieve
new messages from the time you
set up the gmail account on your
phone and to send emails with all
the appearences of coming from
your hotmail account while
actually coming from google's
smtp server. Really do check that
the GMail is set up properly, make
sure it recieves emails adressed
to your hotmail and that it sends
in your hotmail account's name.
Sep 20, 2010 | Health & Beauty
How can i get me sky emails connected to my i phone
Log into Sky webmail, click mail settings, forwarding and pop/imap
enable IMAP.
iPhone:
Configure your mail client:
1. Tap Settings.
2. Tap Mail.
3. Tap Add Account.
4. Tap Other. (Note: Don't tap Sky Email; if you do, you'll set up POP rather than IMAP. We are aware of this issue and are currently working to make setting up Sky Email more intuitive for the iPhone).
5. Make sure that:
- The IMAP tab is highlighted
- Host Name is imap.tools.sky.com
- Username is your full Sky Email address, including '@sky.com'
- For Outgoing Mail Server (SMTP), Host Name is smtp.tools.sky.com
6. Tap Save.
And you've finished. You can verify your Advanced settings by tapping Settings, then [your Sky Email IMAP Account] followed by Advanced.
Incoming Settings:
- Use SSL: ON
- Authentication: password
- Server Port: 993 for IMAP.
Outgoing Settings:
- Use SSL: ON
- Authentication: Password
- Server Port: 465
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 30, 2009 | Apple iPhone 3G
Email deleted on the server still remains in my iphone
That's strange. Except if you have the iPhone email settings set to POP instead of IMAP ...
Without knowing how much you have troubleshooted this already, I'll suggest making sure that IMAP is ENABLED on ALL your Gmail accounts and ALSO that IMAP is enabled on all your iPhone email accounts.
If IMAP is working properly you should stay in synch, no matter how you check or delete individual emails.
If you have IMAP enabled on one of the Gmail accounts, you can still access it via POP settings with the iPhone. If this is the setup, then when you delete an email on the server, it will not be synced when you check your mail on the iPhone, but instead you'll just retrieve any new mails that hadn't already been retrieved previously. However, if you delete a mail message on your iPhone in this scenario, it will not "return."
For audio recording and PA System help, visit www.rexark.com
Oct 14, 2009 | Apple iPhone Smartphone
Cannot set up yahoo mail on iphone 3G
1. should go to http://mobile.yahoo.com/ to register by adding you phone no., you will receive sms and click link in the sms. 2. in iphone, add account manually then can set the pop = pop.mail.yahoo.com, smtp = smtp.mail.yahoo.com
Jul 09, 2009 | Yahoo Mail
Cannot get email
This is a very common problem. Upgrading you iphone firmware if it's not current may solve this problem. Or try changing your address for the account from example@yahoo.com" to your yahoo id without the "@yahoo.com"
Otherwise the built-in yahoo option for iphone can be buggy:
  1. Delete the Yahoo account on your iphone
  2. Create anew account via Other option
  3. Fill in the usual user id and password fields
  4. Under IMAP tab set Host Name under Incoming Mail Server to imap.apple.mail.yahoo.com
  5. Under Outgoing Mail Server, in Host Name field set it to cwmx.com
If you have a very large yahoo inbox, you may have to do the following:
1. Go to your yahoo account in a regular browser on your computer. Makesure you're using the new version of Yahoo mail (the one that looks andfeels like outlook).
2. Create a new folder. I called mine "archive - inbox".
3. Select ALL emails in your inbox so that your inbox folder will becompletely empty once you move them (there's a box you can check whichwill select everything). I had over 5,000 emails in my inbox, so thiswould have taken ages using the Classic version of Yahoo mail.
4. Move all emails to your newly created archive folder. Go back intothe archive folder and select any unread/new emails and move them backto your inbox.
5. Go into Yahoo on your iphone and refresh the mail. This will clearout the old emails and download the most recent emails from your inbox.
More info here: http://discussions.apple.com/thread.jspa?messageID=7926883
Oct 26, 2008 | Apple iPhone Smartphone
Apple iPhone and Network Solutions web mail
So I had the same problem using a Network Solutions mail account and got it working. Here is what I did:
Name: Whatever you want
Address: first.last@domain.com (user specific) Must include the @domain
Description: same as above
INCOMING MAIL SERVER
User Name: first.last@domain.com (user specific) Must include the @domain
password: password
OUTGOING MAIL SERVER
Host name: smtp.domain.com
Username:no entry
password:no entry
At message that SSL failed select YES to continue without using SSL should get message twice (incoming & outgoing server tests)
Made no changes to Authentication (default-password) or Server port (default-25)
Came up and began to load mail instantly.Sent test mail and all is good.
Aug 24, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Logo
232 people viewed this question
Top Apple Cell Phones Experts
jacobcheatha
Level 1 Expert
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
