Question about Kyocera Mita FS-820 Laser Printer
Paper stucked inside
When I tried to print a single sheet the paper got stucked inside. but I can't see where it is to take it off
    President:
  • 3,085 Answers
Open the top cover.
Pull out the toner / developer units and look for paper under neath.
In the rear, pull open the access door.
remove the paper tray and look for misfed paper.
Posted on Dec 12, 2009
    Genius:
  • 1,018 Answers
There are two types of paper jams:
1) A jammed piece of paper at or near a sensor. Or a shred of paper is stuck under a sensor.
2) A paper feed operation that does not send paper into the printer will get reported as a jam it the paper does not reach a sensor in the time that is allotted to reach the sensor. The printer knows that the page is late and suspects a jam occurred prior to the sensor.
To determine if there is a “Pick” problem in the tray, place a mark (line or scribble) on the top sheet in the paper tray. Send a print operation to the printer. If a jam is reported, check the tray. If the marked page is still in the tray then you know the paper pick failed.
There are dozens of reasons for paper to fail to pick. The simplest fix to try is to remove the paper and fan it to remove any possible static charge causing the paper to stick together.
Don
SOURCE:
Load error
When trying to print on continuous stationery, the display may show "Online Single Load". This will occur if the printer is expecting to print on single sheet paper even though you may want it to print on continuous paper. To clear the error follow this procedure. • Take the printer off-line by pressing the Online key • Press the Setup key • Press the key under "Paperway" in the display • Select Tractor 1 (or Tractor 2 if fitted/required) • Press the key under "Set" • If the job still refuses to print try loading the printer with a single sheet of paper to clear the command. To do this remove the tractor feed paper and close the cover on top of the tractors but not the outside cover. You will see a guide into which put a single sheet of paper and press the key under "Load" in the display. • The printer should commence printing. If it does not, then press and hold the key under "LF/FF" to eject the single sheet. Now follow the instructions above again to select the Tractor. The display should read "OnLine Tractor Load". Load the tractor fed paper into the Tractors and press the key under "Load". The printer should now be ready to print. Check your software settings for the correct paper path type. Ensure that the display does not show "Manual" otherwise you will have to clear this error in the same manner as you have for Single sheet
Dec 06, 2011 | Tally Dot Matrix T2265C Printer
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Hi, my canon ip2600 printer is grabbing multiple sheets of paper when printing instead of a single sheet at a time. It prints but some lines of print in the final result are to compressed to be almost...
the printer is grabbing multiple paper because the paper is stuck together in cold times the paper sticks together when you insert paper into the paper try try to make the papper loose
Mar 01, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Paper feed jams. feeds from lower tray, turns 180 deg. then jams. Single sheet feed is fine
    while keeping the paper .. ensure that it is properly stacked... fan the paper and ensure that it is not stuck to each other.. also open the printer cover and see if any paper is stuck inside..
    Try to open the rear access door ,and clean the paper roller with slightly damp lint free cloth
    Aug 12, 2010 | Brother MFC-7820N Printer
    How do I unjam paper in HL 2142
    You open your printer (use your manual to correctly do this)
    check all paper paths to see if any paper is stuck
    Next take out the toner and drum and check again for any stray scraps of paper that may have been stuck there.
    Also open the paper tray and look inside there to see if anything is stuck there.
    If your printer has a single sheet tray check there too
    If your printer has a back opening, check there too
    I recomend that you also purchase "paper path cleaning sheets" to keep the unit clean and paper jam free (once a week if you print constantly and twice a month if a casual user)
    NEVER NEVER NEVER get mad and RIP out stuck paper. Such an action will break internal mechanisms inside your laser printer.
    Hope this helps Have a great day
    Mar 06, 2010 | Brother HL-2040 Laser Printer
    HP paper jam
    That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
    Please remember to rate all users who assist you for free :)
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
    Photo paper loading
    is this still current issue?
    Apr 15, 2008 | Canon PIXMA iP1600 Printer
    Printing Issue
    switch off the printer and open up the cover and remove the toner and see is ther any paper is stuck inside. or try to print a single sheet from front panel. bye
    Sep 21, 2007 | HP LaserJet 1320 Printer
    Automatic Paper feed
    Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
    Sep 06, 2007 | Samsung ML 1210 Laser Printer
    Kyocera Mita FS-820 Laser Printer Logo
    338 people viewed this question
    Top Kyocera Mita Office Equipment & Supplies Experts
    Adorjani Laszlo
    AAAA262430
    Marvin
    Marvin
    Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
