Question about Hotpoint WMA35 Front Load Washer
How do you get the motor off - Hotpoint WMA35 Front Load Washer
  • Hotpoint Master
  • 3,463 Answers
Remove the lower rear panel of washer.
Remove the drive belt.
Unplug the motor plug and lead.
Remove the earth wire.
Undo 2 screws at front of motor.
Lever motor away from you, keeping hold off it, to stop it dropping.
Hope this helps you.
Posted on Dec 12, 2009
SOURCE:
SHARP AR5620SL CODE L4
  • Code: L4 01
  • Description:Main motor lock detection. The main motor does not rotate. After rotation of the main motor, the motor lock signal is detected for 1 sec or more. During rotation of the main motor, the motor lock signal is detected for 1 sec. When the main motor is stopped, the motor lock signal is not detected for 5sec or more. (Though the motor is stationary, it is judged as stable rotation.)
  • Causes:Main motor unit abnormality Improper connection or disconnection the main motor and the harness. MCU PWB abnormality
  • Remedy:Use SIM 25-01 to check the main motor operations. Check connection of the main motor harness/connector. Replace the main motor. Replace the MCU PWB.
Sep 08, 2017 | Sharp Office Equipment & Supplies
I need the part number for the starter motor for my Pajero
You don't need the part number as it depends on the maker of the starter motor.
  • mitsubishi pajero starter motor ' Cars ... - Gumtree www.gumtree.com.au/s-automotive/mitsubishi+pajero+starter+motor/k0... Find mitsubishi pajero starter motor ads in our Cars & Vehicles category. Buy and sell almost anything on Gumtree classifieds.
  • MITSUBISHI PAJERO IO STARTER MOTOR ' Starter Motor ... www.startermotoralternator.com/.../mitsubishi/pajero-io/starter-motor MITSUBISHI PAJERO IO STARTER MOTOR - Extensive Starter Motor / Alternator catalogue searchable by make, model, year and engine size.
  • pajero starter motor ' eBay www.ebay.com.au > Search > pajero starter motor Find great deals on eBay for pajero starter motor pajero diesel starter motor. Shop with confidence.
  • mitsubishi pajero starter motor ' eBay www.ebay.co.uk > Search > mitsubishi pajero starter motor Find great deals on eBay for mitsubishi pajero starter motor mitsubishi pajero 2.8 starter motor. Shop with confidence.
  • Mitsubishi Starter Motors - Auto Electrics Direct - buy ...
  • www.autoelectricsdirect.com.au/index.php?_a=category&cat_id=15&... buy now online auto electrical parts, online shop,starter motors, alternators,smart solenoid, hid lighting, air- conditioning parts and accessories ,best quality ...
  • Pagination
  • MITSUBISHI COLT PAJERO CANTER L300 EXPRESS HYUNDAI SONATA LANTRA 12V 1 4...
    May 20, 2016 | 1994 Mitsubishi Pajero
    Model 841.205 lw2019. Where can I buy 13 vdc motor?
    13v Dc Motor - Alibaba.com
    www.alibaba.com > Mechanical Parts & Fabrication Services > motor
    13v Dc Motor, Buy Various High Quality 13v Dc Motor Products from Global 13v Dc Motor Suppliers and 13v Dc Motor Manufacturers at Alibaba.com.
    12V DC Motor ' eBay
    www.ebay.com/bhp/12v-dc-motor
    eBayFind great deals on eBay for 12V DC Motor in Electric Motors with Less Than 0.5 HP. Shop with ... Buy It Now. 209 watching ... Igarashi 12 VDC Motor - 4500 RPM - 12 V - Toy Car and Hobby Motor - High Torque. $6.95. Buy It Now ... Worm Motor. Output Shaft Size 1.5 x 13mm/0.06 x 0.51 (D*L) Shaft Total Length 47mm/1.7.
    Ametek Motor ' eBay
    www.ebay.com/bhp/ametek-motor
    eBayAMETEK MOTOR GENERATOR E56617 72 V DC WINDMILL TURBINE PERMANENT MAGNET WIND. $145.00; Buy It Now ... Ametek/Lamb 116765-13 Vacuum & CentralMotor, NEW 110 volt 3 stage. $114.79. Buy It Now. Free Shipping.
    Oct 25, 2015 | Philco Audio Players & Recorders
    Motor does not run properly
    What motor are you talking about the fuser motor, paper draw motor, the finisher motor, the transfer motor, the drum motor, the developer motor, corona wire transfer cleaning motor. I can go on.
    Replacing developer and toner has nothing to do with the motor running,
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
    Aug 06, 2014 | Sharp AR-5320 Black and White Copier
    How to change ac blower on a 2001 chevy silverado with the 5.3 liter v8
    With Delphi Blower Motor
    1. If equipped, remove the sound insulator panel.
    2. Remove the blower motor insulating cover screws.
    3. Disconnect the electrical connector from the blower motor.
    4. Remove the blower motor insulating cover.
    5. Pull the retaining tab down while turning the blower motor counterclockwise in order to disengage the blower motor from the heater/ventilation module.
    6. Remove the blower motor.
    With Visteon Blower Motor
    1. Remove the sound insulator panel.
    2. Disconnect the electrical connector from the blower motor.
    3. Remove the screws from the blower motor.
    4. Remove the blower motor from the HVAC module.
    5. Remove the retainer from the blower motor wheel. Discard the retainer.
    6. Remove the blower motor wheel from the blower motor.
    Jul 27, 2014 | 2001 Chevrolet Silverado
    Electric motor keeps cutting out
    There may be a thermal protector placed internally within the motor or motor-compressor to protect the motor and motor winding's components from dangerous overheating that can cause motor failure.
    This overheating generally occurs when the motor is overloaded, a bearing seizes up, something locked the motor shaft from turning, or the motor simply fails to start properly. A failure to start may be caused by faulty start winding's in a motor.
    The thermal protector consists of one or more heat-sensing elements integral with the motor or motor-compressor and an external control device. The thermal protection is in place to turn the motor off when excessive heat is generated within the motor circuitry and keep it from burning up the motor.
    These thermal protectors are reset when the motor cools to a safe operating temperature. There is usually a visible red button located on the wiring side of the motor, opposite of the motor shaft, but not always. In some cases, these buttons are reset manually.
    Mar 10, 2014 | Garden
    Have a kenmore stove, and a code of F93 is coming up. What is the solution?
    F90
    F91
    F92
    F93
    F94
    F95
    If lock motor runs:
    1. Test continuity of wiring between EOC and lock switch on lock motor assy. Repair if needed.
    2. Advance motor until cam depresses the plunger on lock motor switch. Test continuity of switch contacts. If
    switch is open replace lock motor assy.
    3. If motor runs and switch contacts and wiring harness test good, replace the EOC.
    If lock motor does not run:
    1. Test continuity of lock motor windings. Replace lock motor assembly if windings are open.
    2. Test lock motor operation by using a test cord to apply voltage. If motor does not operate replace lock motor
    assy.
    3. If motor runs with test cord check continuity of wire harness to lock motor terminals. If harness is good replace
    the EOC.
    Door lock motor or latch
    circuit failure
    AS YOU SEE THE F93 CODE REFERES TO THE DOOR LATCH MOTOR
    Jul 19, 2011 | Kenmore Ovens
    The heater blower stopped working and the fuse is not blown?
    Blower Motor Removal & Installation W/O Air Conditioning Blower Motor (W/O Air Conditioning) gm-10-00-634.gif
    To Remove:
    1. Remove the PCM.
    2. Remove the coolant reservoir.
    3. Remove the rear coolant recovery reservoir mounting stud.
    4. Disconnect the cooling tube from the blower motor.
    5. Disconnect the electrical connector from the blower motor.
    6. Remove the blower motor mounting bolts.
    7. Remove the blower motor insulating cover.
    8. Remove the blower motor.
    To Install:
    1. Install the blower motor.
    2. Install the blower motor mounting bolts.
    3. Connect the electrical connector to the blower motor.
    4. Connect the cooling tube to the blower motor.
    5. Install the rear coolant recovery reservoir mounting stud.
    6. Install the coolant reservoir.
    7. Install the PCM.
    W/ Air Conditioning Blower Motor (W/ Air Conditioning) gm-10-00-633.gif
    To Remove:
    1. Remove the PCM.
    4. Disconnect the electrical connector from the blower motor.
    5. Move the PCM connectors out of the way.
    6. Remove the blower motor access cover screws. CAUTION
      Do not cut any deeper than necessary in order to remove the access cover.
    7. Cut through the access cover on the cut line using a sharp utility knife.
    8. Disconnect the cooling tube from the blower motor.
    9. Remove the blower motor mounting bolts.
    10. Remove the blower motor.
    To Install:
    3. Connect the cooling tube to the blower motor.
    4. Install the blower motor access cover.
    5. Install the blower motor access cover retaining screws.
    6. Using black weather-strip adhesive, seal the cut line.
    7. Connect the blower motor electrical connector.
    8. Reposition the PCM connectors.
    9. Install the rear coolant recovery reservoir mounting stud.
    10. Install the coolant reservoir.
    11. Install the PCM.
    Feb 08, 2011 | 1996 Chevrolet Blazer
    How to change blowermotor on 2001 gmc jimmy
    To Remove:
    1. Remove the PCM.
    To Install:
    7. Install the PCM.
    To Remove:
    1. Remove the PCM.
    To Install:
    Dec 08, 2010 | 2001 GMC Jimmy
    My heater and ac dont work but the blower motor turns on?
    sounds like something wrong with control head
    Apr 15, 2010 | 2001 Chevrolet Impala
    Hotpoint WMA35 Front Load Washer Logo
    67 people viewed this question
    Top Hotpoint Washing Machines Experts
    vince
    gbob59
    James Hehling
    James Hehling
    Level 1 Expert
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
