Question about Fetco International CBS-2018 Coffee Maker
Start Thermostat I have Fetco 2018. ON initial set up set up guide says to turn on thermostat. How do you do that on this model? I bought on auction and don't have manual.
    New Friend:
    Problem Solver:
  • 10 Answers
This machine has only main control board and beyond the basic settings is not possible to make any changes. Perhaps it was there to reset previously set water temperature in the tank.
Posted on Nov 01, 2013
Model sf35f furnace wont quit heating after reaching thermostat setting
Sounds like the heat anticipator in your thermostat is either bad or out of adjustment. Turn of the furnace power. Remove the thermostat wires from the thermostat. Turn the power back on. Connect the white and red wires together. The furnace should start up. Let it run a couple of minutes. Then disconnect the wires. The burners should shut off immediately. The blower will continue to run for 60 to 360 seconds then shut off. If this happens replace your thermostat. If the burners continue to burn, then your problem is either the furnace or the thermostat wires.
Sep 12, 2014 | Heating & Cooling
My gas pack won't light
First, the thermostat white wire is the wire that initiates the furnace to start. When you select heat on your thermostat the tech should get a 24-28 volts between the white wire and common on the thermostat wire in the furnace. If you do not get the required voltage, there is a break in the wire from the furnace to the thermostat that needs to be tracked down and eliminated.
Feb 27, 2014 | Goodman Manufacturing Goodman...
Problem with thermostat
Try this. Do as you already did above, but this time turn the thermostat slightly clockwise till it comes on again, and leave it at that setting for a while. Does it control now?
Jan 01, 2014 | DeLonghi Heating & Cooling
Braeburn 1200 thermostat cool air blows out when set to heat
I have a feeling your thermostat needs replacing. Check and see if there is a little screw that you can set to increase the temperature on the thermostat.
Oct 24, 2017 | Heating & Cooling
Fetco cbs-51h coffee maker not heating hot enough. turned thermostat all wasy up. coffee luke warm.
It can be the Temperature sensing probe, heating element or a loose/burned wire connection.
Adjusting the brew temperature is not going to help
Jan 17, 2011 | Coffee Makers & Espresso Machines
I just purchased a house with brand new furnace wired to a RTH2300 Honeywell thermostat. It only has two wires running to it. I can't seem to get it to work in "manual mode"-where I set it on...
?? Connect Wires 5.
Labels don't match?
If a wire does not match any terminal on the thermostat,
see next page.
Quick Installation Guide
6
Alternate Wiring
If a labeled wire does not match any terminal
designation, see diagram below.
Do not use C, C1 or X wire. Do not use B wire if you already
have O wire. Wrap bare end of wire with electrical tape.
This thermostat cannot be used if your old thermostat had
any two of the following wires: R, RC, RH, 4 and V.
Place a jumper (piece of wire) between Y and W if you have
a heat pump without auxiliary/back-up heat.
?? Connect Wires (cont'd)
Programmable Thermostat RTH2300
7
Set jumper JP1, on the back of the thermostat, if you
have connected a wire to the G terminal.
Incorrect jumper setting: An incorrect setting is
noticeable in a gas or oil heating system. When heating
starts, you will initially feel cold air coming out of the vents
as the fan is running before the furnace has enough time
to heat up the air.
?? Set Heating Fan Control 6.
HG Leave the jumper in this factory-set
position if you have a gas or oil furnace.
HE Place the jumper to this position if you
have an electric furnace.
JP1
8
Set jumper JP2, on the back of the thermostat, if you
have a heat pump.
Incorrect jumper setting: The heat pump operation
will be reversed, i.e., it will cool in Heat mode and will
heat in Cool mode.
?? Set Heat Pump Reversing Valve 7.
O Leave the jumper in this factory-set
position if you have connected O wire to
the O/B terminal.
B Place the jumper to this position if you
have connected B wire to the O/B terminal.
JP2
9
1) Install 2 AAA
batteries on the
back of the
thermostat.
2) Align the two
brackets on the
top of the
thermostat with
the corresponding
slots on the top of
the wallplate.
3) Push the
thermostat
against the
wallplate.
4) Tighten the screw
at the bottom of
the thermostat.
5) Turn power back
on at the heating/
cooling system.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
When i turn the power on it just keeps pouring out water, whats going on?
The level probe is dirty or damaged, or the inlet solenoid is damaged. I would check the probe first.
Oct 09, 2009 | Fetco International CBS-2018 Coffee Maker
Refridgerator acting erratic
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
May 07, 2009 | Kenmore 57029 Side by Side Refrigerator
32Aap coffee brewer wont heat /older model
Green lamp is on when the thermostat board provides information that the temperature is set. It is either not properly connected or damaged.
Mar 20, 2009 | Fetco International Coffee Makers &...
Coffee Makers & Espresso Machines Logo
79 people viewed this question
Top Fetco International Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Fetco International Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
