Question about Nokia N95 Cellular Phone
Hi, my n95 8g battery doesn't stay long after charging 5 hours , i dont know why?!!
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
It has been charging for 5 hours like this and doesn't turn on. What do I do? It turned on twice but stayed at 1% for about 10 minutes but then shut off again. I have no idea why it is doing this and
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 11, 2013 | Cell Phones
My battery keeps going flat overnight. well i should say over a period longer than 8 hours left off. and it dies with in 5 minutes if i play my head unit or have the heater on with out the car on. and no i...
You answered your own question
You going in the right direction,but you don't
have the experience or meter to test anything
So you go to a repair shop & have the battery
tested ,as well as the alternator & current draw
Jul 18, 2011 | Ford Laser Cars & Trucks
My acer aspire one battery doesn't work. How do I check if the battery works or not
If you want to know if your battery works or not. Heres a simple way.
Use your laptop without using the AC charger. If the Laptop stays on for atleast 30mins and above that means your battery is ok. specially if the laptop stays on for 4-5 hours, your battery is working 100%.
Hope my solution help.
Jul 03, 2011 | Acer Aspire 3000 Notebook
My msi u100 starts up but then the battery light goes red and shuts down how can i fix it
HI Cws666, try to charge your computer for a full 3 - 5 hours without interruptingit, than try again.
If that doesn't work, try buying a new battery.
If that doesn't work send it to computer's brand labs.
Jun 08, 2011 | MSI Wind U100-280US Netbook
I have a polaroid pmp350-4 it doe not seem to charge. after 4 to 5 hours on charge the display shows minimal charge.
The answer is easy. Your computer USB is too weak to supply it juice needed. The best answer is to get yourself a wall power supply to usb that will give it more juice. You will know it is working when the battery that pops up on the screen actually MOVES from bottom to top more quickly than Sonic the Hedgehog moves versus the steady 'stay in place' or a snail's pace upward as I like to call it when plugged into the computer. You'll get your player charged in 2 hours versus 15 hours plugged into the computer and you have the bonus of the battery holding the charge better than the PC way where I've seen the battery be at the top and then you watch 1 video and it drops 4-5 bars. Use the faster, better charging method and it'll stay up there the whole time.
Oct 03, 2010 | Polaroid Audio Players & Recorders
Archos 5 not working, will not switch on.
Hi I would think the best place to start is with ARCHOS,
give them the lowdown and see what they come up with.
You could use the Archos forum and look through the help files
Apr 13, 2010 | Archos 5 MP3 Player
Please help me fast
Plug in the power adapter. Leave it plugged in for about an hour or two.
Jun 26, 2007 | Durabrand DUR7 Portable DVD Player
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
