Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid superba disposal
My kitchenaid superba disposal is clogged!  the liquid won't drain. i have a two-sided sink.  to operate the disposal i have to put a plug into the drain on the disposal side and turn.  it's the opposite side where the liquid is sitting and won't go down.
  • Gary Davd
    Gary Davd May 11, 2010
    open the trap under the sink you have a clog
    Novelist:
  • 184 Answers
IF THE WATER IS NOT IN THE BASIN OF THE DISPOSAL, THE PLUMBING IS THE PROBLEM, NOT THE DISPOSAL.
YOU CAN TRY TO TAKE THE TRAP LOOSE AND SEE IF THERE IS ANYTHING STUCK IN IT OR YOU COULD TRY SOME DRANO IN THE SINK WITH THE WATER STANDING IN IT. THE TRAP IS THE PART OF THE DRAIN THAT RAISES UPWARD TO HOLD WATER. IT KEEPS THE SEWER GASSES FROM COMING UP THROUGH, BUT IT ALSO IS A GOOD CATCH ALL FOR HEAVY ITEMS AND GREASE.
LOOSEN THE NUT LOCATED AT EACH END OF THE TRAP. HAVE A BUCKET UNDER IT TO CATCH ANY WATER THAT DRAINS OUT. REMOVE THE TRAP AND SEE IF THERE IS AN OBSTRUCTION IN IT.PRESSURIZED AIR WILL SOMETIMES CLEAR AN OBSTRUCTION IN A DRAIN LINE ALSO,
Posted on Apr 04, 2008
When dishwasher is emptying it is backing into sink
there is probably nothing wrong with Dishwasher itself.
Your Sink drain is stopped up or your Garbage disposal is clogged.
usually, dishwasher drain is connected to the Garbage Disposal, but if the dishwasher empties the water into the Garbage disposal, if its clogged then water will come out of the sink. Same if sink is clogged between sink and sewer.
If you fill up your sink and then water drains away, then you know your sink itself is not the problem. If its only the Garbage disposal side that does not drain, its the garbage disposal that is clogged.
Dec 22, 2013 | Dishwashers
Garbage disposal and possible clogged drain
plug the one side of the sink so as to create a sealed enviroment for the plunger to work weffectively ... plung the open side ..
If this does not work , try running a metal coat hanger thru the outlet at the disposal exhaust line.
Mar 25, 2013 | Electrical Supplies
Kitchen sink won't drains only when garbage disposal is on
Remove tubular pipes under sink and clean out disposal.
Copy following links for steps for clogged disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 29, 2012 | Badger 1 All Insinkerator 76039h 1/3 Hp...
Kitchenaid dishwasher wont drain
Allow the current cycle to complete. Draining will occur at the end of the cycle.
Close and latch the door. The dishwasher will not drain if the door is not properly secured.
Press the "Cancel/Drain" button on the dishwasher to start a two-minute drain cycle.
Remove the knockout plug in the disposer outlet of the garbage disposal if the dishwasher drains into the disposal. Turn off the water supply and remove the drain hose from the disposal. Place the tip of a screwdriver on the plug and tap it lightly with a hammer to remove it. Replace the drain hose and turn the water supply on.
Clogged Drain
5
Run the garbage disposal to empty it and clear the drain if the dishwasher drains into the disposal.
6
Remove the cover on the air gap on the sink or countertop. Turn the plastic cap counterclockwise to remove it. Remove soil from the inside of the air gap. Replace the plastic cap and cover.
7
Check the sink. Dishwashers connected to a sink will not drain if the sink drain is clogged. Unclog the sink. Contact a plumber, if needed.
Issues With the Drain Hose
8
Check to see if there is a loop in the drain hose. The loop cannot be more than 20 inches above the floor. Disconnect the hose and loop it just above the floor. Reconnect the drain hose.
9
Remove kinks in the drain hose. Always use the new drain hose included with the dishwasher. Do not reuse old hoses.
10
Check the length of the drain hose. The hose should be less than 12 feet long. Replace with a shorter hose, if needed.
Sep 01, 2012 | KitchenAid KAWS850LE Top Load Washer
Garbage disposal sink will not drain, every thing sounds like its working
Sounds like the disposal drain is clogged.
Under the sink, put bucket under plumbing, take a photo of parts, remove 2 nuts on p-trap and trap falls loose.
Run water and disposal and see if disposal drains correctly.
If disposal is still clogged, remove tailpiece on side of disposal to access the disposal cutter chamber. The tailpiece is sealed against the disposal with rubber washer. Make sure washer is clean when putting tailpiece back.
If necessary, use coat hanger to reach into disposal.
Clean out trap and reassemble tubular drain using photos to help assist where each part goes.
I use white teflon joint compound on each joint and washer when reassembling tubular joints to make sure they seal first time.
Oct 07, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I put half a small lemon down the garbage disposal. The disposal kept working fine with the water running, but then it violently threw out water and food particles. I stopped the disposal immediately, the...
Sounds like a clog at or beyond the P trap of the sinks. With water coming back into the sinks, it has to be part of the drain line that is common to both sinks. If you try and unclog the sink, work on the side that does NOT have the garbage disposal in it. A small hand snake for sinks might do the job. You could also try a plunger on either side, but when you do, put a wet rag over the other drain so you are not just pushing air back and forth. Work on one side with the plunger while holding the wet towel down tight over the other drain. Sounds like a clog that was there prior to you putting the lemon in the GD.
Oct 02, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Here is an interesting problem. We have a Badger 5 1/2 Hp Garbage disposal hooked up on left side of double sink. The Disposer runs, spins, but will NOT drain.. at all. Left sink with the insinkerator will...
If this connects into a tee between the sinks, usually if the tee is in the middle of sinks, then often there is a divider in the tee to keep water from backing up the other drain. Remove the tee and inspect to be sure it isn't cloggged. Also put a bucket under the outlet. Try running it this way, if you get good flow you know the disposal is working
Aug 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal works, won't drain, other side of sink drains fine.
well if you put things like rice--chicken fat ==it will pass through the disposer but it will clugg your pipe so yes your pipe is clogged
open the j trup it might come out
Jan 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
I am attempting to install a dishwasher drain line to a kitchenaid disposal under my sink. The disposal is a Kadette 250 1/2 hp. There is some kind of block or plug stoping the water from entering the...
Remove the hose from the disposal, take a hammer and long screw driver, put it in the hole where the hose attaches and knock the plug out. Turn power off to the disposer and pull the plug out of the disposer. Hope this helps.
Aug 09, 2008 | KitchenAid Dishwashers
i would check your drain for restrictions under sink. fill with water, and then cancel cycle, did you hear water draining freely??? sounds like a clog
Feb 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
169 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
