Question about Keurig Special Edition B60 Coffee Maker
Replacement resevoir where can it be purchased?
    Champion:
  • 213 Answers
SOURCE:
How do i replace the gromets on the resevoir
Its best to purchase a master cylinder with reservoir already installed. It is a bear to change the reservoir without damage.
May 20, 2017 | Cars & Trucks
How to bleed 2004 pontiac sunfire slave cylinder
There are 2 ways to bleed the clutch slave cylinder on any vehcile really. First way is to have a person in the car pump the clutch pedal several times and hold it to the floor. While the person holds the clutch pedal to the floor a second person opens the bleeder screw on the slave cylinder itself, once the air/fluid has stopped running out of the bleeder screw, tighten it again and have the first person in the car pull up on clutch pedal from the floor (because it will stick down after openening and tightening the bleeder screw) and then repeat that process until the clutch pedal feels good and hard. Make sure you fill the fluid in the clutch master resevoir each time you open and close the bleeder screw so you don't get new air coming through the system from emptying the resevoir.
Now, the second way is the way I prefer because you only need 1 person, however you do need more tools. Fill the clutch master resevoir will the proper fluid then find a cap that fits the resevoir or buy a replacement cap and drill a small 1/8" hole in the middle of the cap then use a vacuum pump and insert a rubber adapter (from the vacuum pump kit) into the 1/8th hole you have drilled. you'll want to hook up your vacuum pump with an inline catch tank that usually comes with the kit you purchase. Then just pump the tool creating a vacuum in the master resevoir, this will reverse bleed all the air up into the resevoir. as you see the fluid drop add more fluid and repeat this process until the fluid no longer drops. Check the clutch pedal for proper opperation and you're good to go!
Jul 23, 2014 | 2004 Pontiac Sunfire
Keurig Vue touchscreen does not work
If you can return it to the point of purchase for exchange, do so. You might opt for on-the-spot proof that the replacement works.
Jan 02, 2014 | Keurig Vue Brewing System
Whinning when you turn the wheel. filled the power steering fluid seems to be leaking
Check your hoses first - if cracking replace
Next check your resevoir is the leak coming from where the hose connects to or is the leak coming from the resevoir/pump. If the hoses are good you will need to replace the pump/resevoir. The wineing noise indicates low fluid. Too much fluid would cause foam at the resevoir
Aug 27, 2011 | 1994 Oldsmobile Cutlass Ciera
Power steering fluid is dripping out of the back side of the resevoir. Will i need to replaced the pump?
First thingdo is try and tighten it up. If that does not work, see if you can tell if the reservoir is cracked at that fitting. If it is not, I would replace the hose first as this will be the cheapest. If it continues to leak after hose replacement, replace your reservoir.
May 12, 2011 | 2000 Ford Windstar
White milky substance in oil resevoir
no that is cause dby oil and coolant mixing together
Apr 29, 2010 | 2002 Mitsubishi Lancer
Replacing / patching my coolant resevoir
there is actually a plastic epoxy putty that you can purchase at any auto parts store. the resevoir needs to be clean, follow directions
Oct 29, 2009 | 2001 Ford Windstar
POWER STEERING RESEVOIR WHERE ISI T?
Hello, here is a picture of the location of the P/S reservoir:
Oct 16, 2008 | 1995 Dodge Caravan
I have a 2001 saturn sl and i purchased a repair book from parts store. My windshield washer pump is out and i need to replace. The book does not address this problem. How do i replace it?
First locate the washer fluid resevoir, if you can remove it the pump is usually connected to the bottom or side of the resevoir. just remove and replace the pump and then reinstall the resevoir.
Jul 26, 2008 | 1992 Saturn SL1
Keurig Special Edition B60 Coffee Maker Logo
50 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Pierre Laplante
Steve Allison
Steve Allison
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
