Question about Yahoo Mail
An internal error occurred when attempting to attach a photo
    President:
  • 252 Answers
Try uploading your image as a file. What i mean to say is try the file upload option rather than photo upload option.
Posted on Dec 12, 2009
SOURCE:
Why do I get an error message: Internal error occurred. Scan driver will be closed. Code:5,202,52?
Look at the bottom of the scanner and there should be a lock/unlock slider. Unlock it and see what happens.
If it is already unlocked then the drive/stepper motor or belt is bad.
Mar 27, 2015 | Canon CanoScan LiDE 25 Flatbed Scanner
Hai ....am vivek .please help me dears...i have RICOH Aficio 2045 ...it will appears sc 990. What's the solution for this error?? Plz help me ...
SC 990 is software performance error. This means The software attempted to perform an unexpected operation.
Possible causes:
1. Software defective
2.Internal parameter incorrect
3.Insufficient working memory
4.When SC occurs, the file name, address and data will be stored in NV RAM this information can be checked by using SP 7403. Note the above data and situation in which this SC occurs. Then report the data and conditions to your technical control center.
Apr 23, 2013 | Office Equipment & Supplies
My hp scanjet 2400 stops at warming up then shows unexpected error. please help
Try connecting it on direct wall outlet.Not a surge protector or power strip
Try below solutions
An Unexpected Internal Error Has Occurred' Error Message Displays
Issue When attempting to scan, or, during the scanning process, the error message An unexpected internal error has occurred may display on the computer screen. There are three scenarios where this issue occurs. This document covers each scenario where this error may occur and provides links to the appropriate documentation for resolving each scenario. Solution one If you have multiple versions of HP Image Zone software installed on your computer, click here to download a patch that might resolve this issue . If you do not know if you have multiple versions of HP Image Zone installed, follow the instructions below.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Click Add/Remove Programs .
  3. In the list of programs that displays, look for the following entries:
    • HP Image Zone
    • HP Photo and Imaging Gallery
  4. If there is more than one entry listed, then there are multiple versions of HP Image Zone software installed on the computer.
  5. Click here to download the patch. Follow the on-screen instructions to download and install the patch.
  6. If the issue persists, try the next solution.
Solution two Clicking Scan picture or image in the HP Director software results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00369826). Solution three When accepting a scan from the HP Scanning preview window, the scanner may start to scan and then lock up with the lamp approximately ½ way down the scanner bed. This results in an unexpected internal error or causes the computer system to stop responding. Click here to resolve this issue (c00373192). Solution four When accepting a scan, the scanner completes the final scan and the lamp returns to the home position; however, when the image is being processed or sent to the receiving application (that is, HP Photo and Imaging Gallery), an unexpected internal error occurs. Click here to resolve this issue (c00373192). Solution five Immediately after clicking Scan Picture from the HP Director when using an HP Scanjet 3970 with v2.2 software, an unexpected internal error occurs.
Try also this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00259434&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=297430
I hope you issue should be fix to lessen your frustrations.You can do it
Regards
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | Office Equipment & Supplies
Fluke 1651portable multifunction tester is displays Err 1
Error 1 is an indication that the self test has failed. This will require repair at an authorized Fluke service center. There is an internal problem with the meter. The only thing that you can try is to replace the internal battery. Should the battery be defective, the internal testing can be effected. I have only seen this occur once, but it is worth the attempt. Should a new battery not fix the problem, return the meter to Fluke for repair.
Dan
Apr 15, 2010 | Fluke Networks Fluke T+PRO Electrical...
Error code #0x80070052 occured while attempting to transfer photos from memory stick back to camera chip
The error message means "The directory or file cannot be created."
Make sure the folder containing photos is having sufficient write permission .
Hope this helps .
Jan 27, 2010 | Fuji FinePix Z1 Digital Camera
When opening an attachment I get a Adobe Reader error message
go to Add/Remove programs in windows, and remove Adobe Reader. Then download the installer and install the Reader again and its should work fine.
Jan 18, 2010 | Computers & Internet
Photo explosion will not load. OS VISTA 64 BIT
This error often occurs when we declare a command or an operation that the system can not find the application or that person's no.hoac can not find information in the mail vien.khi that force you to check future information systems thong.Sua change or activate certain features in the source code using "regedit" ... to edit the functionality necessary.
Nov 12, 2008 | Nova Development Photo Explosion Deluxe...
Psp internal error
I try to apply a theme and it says an internal error occurs. It freezes when a game starts off my memory stick, then it freezes when i leave the game
Dec 27, 2007 | Sony PlayStation Portable (PSP) Console
Scanner component stopped communicating
well, reinstall the software and see if it will work.
Aug 13, 2007 | HP PSC 1350 All-In-One Thermal Printer
Yahoo Mail Logo
815 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
Steve Allison
Steve Allison
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
