Question about HP Officejet Pro L7580 All-In-One InkJet Printer
It is sying i have a paper jam but there is no paper in it
    Genius:
  • 1,018 Answers
There are two types of paper jams:
1) A jammed piece of paper at or near a sensor. Or a shred of paper is stuck under a sensor.
2) A paper feed operation that does not send paper into the printer will get reported as a jam it the paper does not reach a sensor in the time that is allotted to reach the sensor. The printer knows that the page is late and suspects a jam occurred prior to the sensor.
To determine if there is a “Pick” problem in the tray, place a mark (line or scribble) on the top sheet in the paper tray. Send a print operation to the printer. If a jam is reported, check the tray. If the marked page is still in the tray then you know the paper pick failed.
There are dozens of reasons for paper to fail to pick. The simplest fix to try is to remove the paper and fan it to remove any possible static charge causing the paper to stick together.
Don
Posted on Dec 12, 2009
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
Frigidaire SY CF issues
Good Morning Jack, thank you for your question!
Typically error code SY CF indicates that your refrigerator has detected a communication failure after power up. The error code may possibly continue after replacing the part you have ordered. With this error code, a professional would need to check wiring between the main control board and user interface board. After proper diagnoses and if the error continues, the main control board may need replacing. Hope this information helps to some degree!
Dec 27, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
Saya punya printer Epson Stylus TX111.. pada saat dinyalakan dan dimatikan catrigde tidak bergerak dan lampu merah dua-duanya menyala.. sebelum kejadian ini muncul tulisan servis..(sy agak lupa tulisan...
Something's probably jammed in there. Get it out in the light with some paper to feed through, clean out the gunk in the paper path or cartridge area, perhaps running through a cleaning cartridge, and try for an error message.
Sesuatu mungkin macet di sana. Dapatkan keluar dalam terang dengan beberapa kertas untuk memberi makan melalui, membersihkan gunk di jalur kertas atau area kartrid, mungkin berjalan melalui cartridge pembersih, dan mencoba untuk pesan kesalahan.
Jul 25, 2011 | Office Equipment & Supplies
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
422 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
