Question about Sony DVP-NC600 Multi-disc DVD Player
Gears Not Aligned
I had a slight child mishap, and the drive belt for the carousel fell off. I have since replaced the drive belt and have gotten the carousel to close most of the way, but was wondering what the correct gear alignment scheme is. Can you please assist me?
  • brenthaag Aug 10, 2008
    I have the same problem and I've taken it apart and put the belt back on, but can't get it to work...anybody else have ideas?
I actually got it to finally work! It works like a champ, now. (My brother owes me know!)
Posted on Aug 10, 2008
If anybody can help me please I need to know how to repair the carousel before the CD changer he does not spin thank you
Most of the carousels are driven by a small motor through a gear train, but some are belt driven. You would have to look underneath the carousel to determine what the mechanism is. If it's belt driven, make sure the belt isn't slipping. With the changer unplugged, find the carousel motor, then gently turn it by hand (make sure you are turning it in the correct direction) to check for excess friction, broken gears, jamming by a foreign object, or slipping. If you hit a hard stop while turning the motor DO NOT FORCE IT. Investigate the stop; it's probably your problem. Some changers rotate the motor in one direction to turn the carousel and in the other direction to clamp the CD in the spindle mechanism. If the spindle clamp is hung up, this will prevent the carousel from turning.
Jun 16, 2015 | Audio Players & Recorders
Player won't play discs.. Removed cover, little carousel motor belt wrapped around shaft. Untangled and put back on pulleys but seems loose motor rotates but carousel barely moves
take the belt to your local ace hardware and find an o-ring that is slightly smaller than the belt. Install that and you should be back up and running for less than a dollar.
Apr 04, 2015 | Sony MegaStorage CDP-CX455 400-Disc CD...
Replace water pump 2004 clk500
Hi Scott, Work evolved in replacing a water pump depends on the vehicle. Some vehicles have the pump driven by the timing belt, while others drive via a 'V' belt or PK (Serpentine belt) If your is the latter, take a few photographs of the lacing for the reassembly before doing any disassembly. If it is a vehicle using the timing belt, photograph the serpentine belt and then remove it and the timing cover. Before removing the timing belt, rotate the engine to TDC and align the timing marks before taking off the belt. It is always a good idea to paint a spot of white paint onto the gears and the engine. Once the match marks have been identified and aligned, loosen the tensioner bearing fully before removing the belt. When refitting, set the marks by adjusting the belt alignment on the opposite side to the side fitted with the tensioner. Once aligned, retention and check the alignment again. If you're happy turn the engine by hand at least four times and recheck the matching up of the marks each second turn. Changing the water pump is straight forward and child's play compared to the associated work. Regards John
May 25, 2014 | Cars & Trucks
I have a Sony CX400 & the belts became old & loose. I can easily see the TWO belts that are the same (called rorary belts) part # 422587601. My problem is there is a third belt that I cannot see....
I was under the impression that the third belt is a larger belt that rotates the carousel, and it is located under the carousel -- so you would have to lift/remove the carousel to get to it (which would probably give you some new problems). I could be wrong about this, but that's the impression I've gotten from everything I've learned about the CX400. If you're having problems with your unit, the third belt might NOT be the cause of it. If you're not having problems you'd probably be better off leaving that third belt alone. Best of luck to you. Hopefully somebody else will chime in with some useful info.
Mar 16, 2014 | Sony CDP-CX400 400-Disc CD Changer
93 Toyota 1hz hzj80 Replaced diesel fuel pump but had to take timing cover off due to oil leak and fuel pump gear fell out Reassembled and lined up the gear but got to stage of putting belt back on and...
The pistons are hitting the valves due to wrong alignment of timing gears and the timing belt. Align the timing gears and timing belt marks according to the following diagrams.
Good luck.
Mar 08, 2014 | Cars & Trucks
On 2000 mazda protege 1.6 replaced water pump now won't start, thinking timing now out what is timing procedure?
i dont have a more detailed picture of setting the timing marks for the belt so i hope this helpsonetufshoppe_81.gif
Jan 30, 2011 | 2000 Mazda Protege
I installed new toner cartridges and a new drum (authentic HP) and my printer won't print. When it is initializing, the sound is different and when I look at the gap between the toner cartridge and the...
On the 2840,one reason why the carousel gets out of alignment is because non HP cartridges were used and they were leaking toner. The leaking toner gets into the carousel gears and causes them to jump a couple of teeth.
If you have a warranty HP will fix the problem under warranty repair. However, if you were using non HP cartridges you will be billed. If your problem is non aligned gears, you won't need parts. The gears will have to be aligned and vacuumed. It doesn't require dismantling the printer.
If you do have to pay, it should only be an hour of labor.
Does it print good? If the printing is good, the carousel isn't out of alignment. Don't fix it if it isn't broke.
Jan 08, 2011 | HP LaserJet 2840 Printer
How to replace timing belt on a 1992 pontiac sunbird
1989–92 VEHICLES
  1. Disconnect the negative battery cable.
  2. Remove the serpentine belt and timing belt cover.
  3. Loosen the water pump bolts and release tension with tool J–33039 or equivalent.
  4. Raise and support the vehicle safely.
  5. Remove the crankshaft pulley.
  6. Carefully lower the vehicle, then remove the timing belt. Fig. 11: Exploded view of the timing belt assembly — 1989–92 OHC engines 87953118.gif
    To install:
  7. Turn the crankshaft and the camshaft gears clockwise to align the timing marks on the gears with the timing marks on the rear cover.
  8. Install the timing belt, making sure the portion between the camshaft gear and crankcase gear is in tension.
  9. Using tool J–33039 or equivalent, turn the water pump eccentric clockwise until the tensioner contacts the high torque stop. Tighten the water pump screws slightly.
  10. Turn the engine by the crankshaft gear bolt 720°to fully seat the belt into the gear teeth.
  11. Turn the water pump eccentric counterclockwise until the hole in the tensioner arm is aligned with the hole in the base.
  12. Tighten the water pump screws to 18 ft. lbs. (24 Nm), while checking that the tensioner holes remain as adjusted in the prior step.
  13. Install the crankshaft pulley, timing belt cover and the serpentine drive belt.
1993–94 VEHICLES
  1. Disconnect the negative battery cable, then partially drain and recover the cooling system.
  2. Remove the coolant recovery reservoir.
  3. If equipped, remove the A/C belt.
  4. Remove the serpentine belt.
  5. Disconnect the evaporative emission pipe assembly.
  6. Remove the crankshaft pulley assembly.
  7. As outlined earlier, remove the timing belt front cover.
  8. Align the marks on the crankshaft sprocket with the marks on the rear timing belt cover by rotating the crankshaft.
  9. Loosen the water pump retaining bolts, and release the tension with tool J 33039-A or equivalent.
  10. Carefully lower the vehicle, then remove the timing belt. Fig. 12: Timing belt installation and tightening specifications — 1993–94 2.0L OHC engines 87953119.gif
    To install:
  11. Turn the crankshaft and camshaft gears clockwise to align the timing marks on the gears with the timing marks on the rear cover.
  12. Install the timing belt, making sure that the portion between the camshaft gear and crankshaft gear is in tension.
  13. Using tool J 33039-A, or equivalent adjustment tool, turn the coolant pump eccentric clockwise until the tensioner arm contacts the high torque stop. Tighten the water pump screws slightly.
  14. Turn the engine by the crankshaft gear bolt 720°clockwise to fully seat the belt into the gear teeth.
  15. Turn the coolant pump eccentric counter clockwise until the hole in the tensioner arm is aligned with the hole in the base. This must be done with the engine at room temperature, approximately 68°F (20°C).
  16. Tighten the water pump screws while checking that the tensioner holes remain as adjusted as in step 15.
  17. As outlined earlier, install the timing belt cover.
  18. Install the crankshaft pulley.
  19. Connect the evaporative emission pipe assembly.
  20. Install the serpentine drive belt and the A/C belt (if equipped).
  21. Install the coolant recovery reservoir.
  22. Properly fill the cooling system, then connect the negative battery cable.
Aug 11, 2010 | 1992 Pontiac Sunbird
Sony CDP-CX300 How To Replace Drive Belts?
The Sony call center says the two belts are the same size. Supposedly, there is a third belt "under the motor board" but I have not been able to find it. That is the 42x1.2 (4219362601). The two easy ones to replace are 421606101 and only cost 1.95 from Sony.
Aug 08, 2009 | Sony Audio Players & Recorders
The color is faded on the left side of the page printer, what is the possible cause or solution?
From the service manual:
If the light printing is on the left side of the page, the carousel might be dislocated.
Solution: Verify that the print-cartridge carousel drive teeth are aligned correctly. If the teeth are aligned correctly, replace the print-cartridge carousel.
Jun 03, 2009 | HP LaserJet 2840 Printer
Sony DVP-NC600 Multi-disc DVD Player Logo
110 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
