I have a apple desktop tower that seems to be caught up in a loop when i boot it up. It seems to be looking for the network that it was previously on. This was given to me at a place of work where i previously worked. The operating system is outdated, it's 9.2...
    Problem Solver:
  • 13 Answers
Contact Apple via e-mail or phone call (you can most likely find both on the Apple website)
It will most likely cost you money, but they can give you an up-to-date operating system and get your computer back up and running in no time. Depending on how old the computer it is, it may be more cost-efficient to simply buy a new computer. Check prices on an updated operating system and on a new computer before buying.
Hope I helped!
~Aeoryth~
Posted on Dec 24, 2009
Alert. previous attempts at booting this systemhave failed at checkpoint [0032]
XPS 8500 Desktop booting fails - General Hardware - Desktop - Dell ...
en.community.dell.com/support-forums/desktop/f/3514/.../19452875
Dell
Jun 13, 2012 - 16 posts - ‎9 authors
I am sorry to know the concern with the computer. As you .... I have the identical problem on a 3 week old XPS 8500 desktop machine. It seems ... Dell XPS 8500 - Will Not Boot At All - Motherboard ...
Aug 13, 2014
Dell XPS 8500 Unable To Boot
Jun 25, 2013
New Dell XPS 8500 won't boot
Dec 5, 2012
XPS 8500 UEFI boot
Oct 29, 2012
More results from en.community.dell.com
How to Use and Troubleshoot the XPS 8500 ' Dell US
Dec 15, 2015 | Dell XPS 8500 Desktop Computer; Intel Core...
Xp booting loop bios
Seems to be a bad driver or damaged boot.
If the computer shuts down and restarts check CPU fan and blow dust out from heat sink, CPU may be overheating.
Otherwise, use the recovery disk to repair, or the installation CD and do the system repair. Or from repair disk, if your computer worked fine before, Restore To a Previous setting.
Jul 16, 2013 | HP Pavilion a1410n (ER890AA) PC Desktop
How do you resest pram
I would try starting the machine up in single user mode you do this by booting your machine up and then immediately press and hold the command (Apple) key and the s key. If you do not know how to reboot press down the command-control-power key at the same time.
Once you get white text appearing on a black background at the command line prompt type /sbin/fsck -fy then press return. The machine will then go through some testing and then hopefully it will tell you that your hard drive is okay. If it says that the file system has been modified run the comand again i.e. /sbin/fsck -fy When the fsck command reports that your hard drive is okay type reboot at the prompt and then press return. Hopefully your computer will boot up okay after this.
Nov 12, 2011 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
My pc had a blue screen that said my bios may not be acpi compatible i restarted and the pc is now caught in a boot loop
if you have the recovery CD set, reinstall to factory settings
www.restoredisks.com, if you do not have that CD set
does this help ?
Oct 16, 2010 | Computers & Internet
I am stuck in the boot up process with the option
Look at the HDD (Hard Disk Drive) LED light...
Is it a steady red? Put your ear to the computer case. Do you hear a repeating clicking sound?
You should be able to press [F10] to get out of the BIOS Setup. If not, it may be a loose hard drive cable (open up the PC) or a failing Hard drive (replace).
Oct 20, 2009 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
Safari 4 works briefly, then stops browsing
It's probably a bug which most likely can't be explained for now,
I would suggest reporting the error to Apple,
and going back to using Safari 3 for now.
Hope I helped,
Tom
Jun 21, 2009 | Apple safari
Can not get computer started
The flashing folder with a '?' means that the computer can't find the boot files. This may be that the hard drive has failed, boot files are damaged, or, that the drive is missing. In each case you will need to re-install the Mac OS. from the system disks.
May 27, 2009 | Apple Power Mac G4 Desktop
Windows xp stuck in restart loop
Needle in the tower? Wow! Who told you that? Geek Squad.
OK in all seriousness this is what I want you to do.
Press F8 as the computer boots up.
Choose "Safe Mode with Command Prompt"
Let me know if you're able to get that far and then we'll proceed from there.
Feb 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
System will not boot up
Hi there
Hit F2 on boot up and go into the Bios settings, look for the boot order and change it to HDD as first boot device, hit F10 and save and exit.
The PC will restart and should boot into the hard drive.
Good luck
Jan 26, 2009 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
My PC with Vista Home Premium is caught in a loop
One of the updates is not installing properly. The only thing you can really do in this case is to use your Windows Vista installation disk and try to either repair or restore to a previously known good restore point. Hope this helps.
Dec 27, 2008 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
