Question about Kodak EasyShare M863 Digital Camera
Usb not charging
Mains usb not charging camera. Kodak M863.
    Genius:
  • Kodak Master
  • 1,099 Answers
The computer will only charge when the camera is switched off.
Try a different computer. It will usually only work from a desktop.
Try a different USB outlet
Try a different USB cable
Posted on Dec 14, 2009
Kodak M863 charge ok checked battery is charged and tried new battery. Within one day battery is flat.
Go into settings, close wi fi and blue tooth. change screen brightness , change time on screen shut down.
Oct 29, 2014 | Kodak EasyShare M863 Digital Camera
My m863 kodak camera charging light won't turn on.
Is the camera charging? Remember when charging thought the computer NOT to switch the camera on since this will deactivate the model to charge. Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak EasyShare M863 Digital Camera
My Kodak m863 won't turn on. I've gotten a new
There is no firmware available online for this camera model. Therefor you do need to set up a "repair" with KODAK directly.
An Out of Warranty repair for this model for this fault is about 48 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to arrange your repair/Trade up: Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 30, 2009 | Kodak EasyShare M863 Digital Camera
12v charger use in kodak m863 help
This camera is only compatible with a 5V adapter/charger and it should charge via the USB cable.
In order to order your 5V adapter please follow this link:
http://store.kodak.com/store/ekconsus/en_US/AddItemRefID/pageType.product/externalRefID.EKN034940#accessories
Dec 19, 2009 | Kodak EasyShare M863 Digital Camera
When i go to charge my kodak M863 camera (in the wall or by USB) the green light flashes and then the red light blinks 3 times. please help this is the first time charging my camera.
You can used the USB cable to charged the camera, But some of the M863 camera will not take charged usign the USB cable., I strongy suggest used the AC adaptor just make sure the AC adaptor is 5V ac adaptor it will only charged using the 5V adaptor., About the flashing green it indicates camera is charging just wait for the solid green light it means it fully charged
You may purchased also a special charger for your battery(KLIC-7001)- cahrer model is K8600-C. i think the price of this charger is around $29.00
Nov 14, 2009 | Kodak EasyShare M863 Digital Camera
M863 LENS WILL NOT EXTEND AT SWITCH ON
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Nov 01, 2009 | Kodak EasyShare M863 Digital Camera
My kodak m863 wont let me view pics or take them
If this is a No power issue:
Remove the battery
Contact KODAK:
Oct 03, 2009 | Kodak EasyShare M863 Digital Camera
I have a Kodak M863 camera and it wont stay on
If your cam use manufactors rechargeble batt.:
Remove the battery
Contact KODAK:
Sep 29, 2009 | Kodak EasyShare M863 Digital Camera
My kodak m863 won't charge at all either using the included AC charger or use computer USB. The charging light don't even come on.
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 02, 2009 | Kodak EasyShare M863 Digital Camera
Kodak EasyShare M863 Digital Camera Logo
181 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
