Question about RCA P52771AT 52" Rear Projection Television
Are the projection tubes between a RCA P52771at and a Phillips model 60PP9202/17F interchangeable
  • RCA Master
  • 5,138 Answers
NO they sure will not.
Posted on Dec 12, 2009
Rca rear projection screen way to much blue
replace convergence ics .press the menu and go into the convergence
alignment.see if you are able to align the blue convergence. if not replace the convergence ics.
Aug 04, 2009 | RCA P52771AT 52" Rear Projection...
Blue Halo and too much blue...
if its a halo such as a glo you need coolant change in the CRT, if its like a 3D effect then you need new Convergence ICs. Can you post a picyure of your screen and I will properly diagnose it for you then be better equiped to help you properly.
Apr 04, 2008 | RCA P52771AT 52" Rear Projection...
Rca p52771at
Sounds like you have a bad screen asy,check around the pots to see if cracks are present,part number for this item is 204809,must use the generic,the part is no longer available from Thomson.
Feb 05, 2008 | RCA P52771AT 52" Rear Projection...
RED LINES
Your red CRT socket may be loose or have cracked solder if not, try turning down the red gun screen control inside the set just a little. Youre experienceing what is known as retrace lines
Jan 21, 2008 | RCA P52771AT 52" Rear Projection...
Wire diagram for splitter
On the 205064 hv splitter with the splitter mounted in the set,left to right, hv transformer,red tube,green tube,blue tube,plug on right side goes to screen asy,the black wires plug on the left side of splitter,which are grounds.
Jul 28, 2007 | RCA P52771AT 52" Rear Projection...
Power not working
the tv needs to be repaired take it to a tech the power supply is the culprit along with the related circuit.your tv must be repaired by a proffessionl tech good luck.
Apr 03, 2007 | RCA P52771AT 52" Rear Projection...
Model; P52750WK serial; 340486076
Hit remote power button. Brief " crackling " sound, no picture. No problem with TV since new. There is a brief spark like light with sound.
Nov 21, 2006 | RCA P52771AT 52" Rear Projection...
Rca tv p52771at problems
Mine did the same thing it ended up being the splitter. About 200 bucks. And then a year later it did it again. Another 200 bucks.
Nov 04, 2006 | RCA P52771AT 52" Rear Projection...
Rca p52771at - dark picture
Sounds like a bad screen asy,part number 204809,must use the generic,or you could have weak tubes,if so you may just need to turn up the screen drives,this part is located in the right top of the set with the back removed,if no cracks are present adj. the three marked screen's,turn the color all the way down in your menu and adj. for a black and white picture.
Oct 07, 2006 | RCA P52771AT 52" Rear Projection...
Blue shadow RCA p52771at
hi yeh it does sound right sorry do know anybody arround there... good luck
Feb 22, 2006 | RCA P52771AT 52" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
