Question about Dell Latitude D600 Notebook
Laptop needs charging but he battery goes off when
Laptop needs charging but the battery goes off when I plug it in the back of the lap top. they were working fine yesterday so am not sure what's happened in the interim they've been stowed away.
    Sergeant:
  • 244 Answers
Try draining the Flea power first
1. Remove the battery and Ac adapter
2. Press and hold the power button for at least 10 sec.
3. Put back the battery
check if the battery is now charging. Hope this helps
Posted on Dec 12, 2009
    Sergeant:
    Champion:
  • 232 Answers
The battery has probably become deteriorated over time. When I see this problem I usually test the battery in a similar laptop, if you can't do the same then go and get the battery tested at a PC repair place. Thanks, Scott.
SOURCE:
Where do i buy a battery for my lap top
I suggest you Google the Internet for a replacement battery for your model laptop. You will get various suppliers and prices.
Mar 05, 2013 | HP Computers & Internet
Lap top will not charge battery
Sounds like the charging circuit on your motherboard is defective. Also check the AC adaptror by switching it with other Vostro.
Jan 30, 2012 | Dell Vostro 1014 Laptop Computer (Intel...
Hp pavilion Dv 7 won't power on even when the lap top is charged.
Pull the battery and plug it in to the wall (in other words rule out the battery). If it still refuses to come on, check out this troubleshooting link:
http://www.techspot.com/vb/topic55208.html
Jan 15, 2012 | HP Pavilion dv7-1130us laptop
On start up the lap top starts to come on and within 6 seconds it switches off and not even the screen comes on?
Do you have it plugged in? Also, do you know if the battery is charging? You may have a bad DC connection.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
The DC connector needs to be resoldered on the system board.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 08, 2010 | HP Compaq nc6000 Notebook
Lap top no power
If you were given a laptop with a brand new battery, it does need to charge for a while and depends on the manufacturers suggested charge time.
You should be able to power the laptop on without the battery attached. If you can't, you probably have a power supply issue on your hands or a bad component on the mother board. It may be less expensive to just get a new laptop.
Apr 06, 2010 | HP Compaq nc6000 Notebook
How do I charge my battery on my t30 lap top battery
You normally need a compatible Power Supply plugged into the Laptop from the mains. Without this the battery will go flat. If you do not have one a good place to look is Ebay, or the like simply put in the model name of your laptop and the words Power Supply.
EG: IBM ThinkPad T30 Power Supply.
Feb 03, 2010 | IBM 11P8273 for Thinkpad 14.1" Flat Panel...
My Compaq Presario C500T lap top won't start
Generally speaking, an orange power light indicates problems with the power. You also described to a "T" how a bad battery behaves. To test this theory, take out the battery and plug in the laptop. It should power up and run. If so, it's time to invest in a new battery.
To be doubly sure, if you have anyone with the same laptop as yourself, plug in their battery to your laptop. It should work if their battery is good.
Thanks for using fixya.com. Please rate this tip accordingly if it provides the information you needed.
Jan 13, 2009 | HP Compaq Presario C500t Notebook
Laptop not charging (Presairro C500)
Need to order for my Lap top Recovery Disk Need Phone No
my EM- IS Frances Lovegren lovetko8@fairpoint
Aug 18, 2008 | Compaq Presario Notebook
Acer extensa 4620Z laptop computer will not re-charge battery. The cord going to the outlet has power...green light...but no lights are on lap top and it is securely pluged into lap top. - When I...
It could be one of three things. It could be a bad battery, a bad ac adapter, or the recharging circuitry could be bad. I would try pulling the battery out, and see if the laptop will startup and run strictly off of the ac adapter. If that does not work, you have a bad ac adapter. If that works, and the battery has any charge left, try running it strictly on the battery. If it doesnt work, you have a bad battery. If it does work, the circuitry is bad and you will probably need new motherboard. One other thing you can check is where the ac adapter and battery plug into the laptop, and make sure there is no corrosion that could be causing a short.
May 10, 2008 | Computers & Internet
Dell Latitude D600 Notebook Logo
37 people viewed this question
Clive
Clive
Alun Cox
