Question about Sky Toys
Set top box does not power up - Sky Toys
You just *******
Posted on Dec 12, 2009
Which button turns on subtitles
If you have a digital Set-Top Box with digital cable service:
Using Navigator:
  1. Press the SETTINGS button on your remote.
  2. Scroll left or right to the Quick Settings category.
  3. Scroll down to select the Closed Captioning option and press SELECT.
  4. Scroll up or down to highlight On, On with Mute, or Off and press SELECT.
Using i-Guide:
  1. With your Set-Top Box currently on, push the POWER button on your Set-Top Box to turn it off.
  2. Immediately-within one second-push the MENU button on your remote. You should see a User Settingsmenu screen displayed.
  3. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable.
  4. Power on the Set-Top Box to return to watching TV.
Otherwise, if you have basic cable, please consult your television's user manual for instructions to turn on/off closed captioning.
Sep 17, 2016 | LG 32LG30 32 in. LCD HDTV
On my e-motion tv when I switch it on and go onto did it says no signal....help please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
My tv model magnavox26mf231d/37 shows hdmi is disabled and the hdcp authorization failure.
This could be a problem with the cable box or other set top box and not the TV. It's known to happen with Samsung cable boxes from Cablevision.
First try resetting the TV and set top box by unplugging both. Remove the HDMI cable from the TV and the set top box. Reconnect the HDMI cable. If you are using a Redmere or similar HDMI cable, make sure that the end labeled TV is connected to the TV's HDMI port. (These cables have additional electronics and are not reversible.) Connect the power cord to the set top box and wait 30 seconds to a minute. Then plug in the TV. To ensure the set top box does the correct handshake with the TV, turn on the TV first and set it to the HDMI input. Then turn on the set top box. See if this fixes the issue. (On some cable boxes, this can be a temporary fix. You may need to have the set top box replaced.)
If the above steps don't help, try a different HDMI cable. If that doesn't solve the problem, then the set top box is faulty.
I hope this helps.
Jan 10, 2015 | Televison & Video
Rca 42in full hd lcd picture flickers
If the picture on your TV flickers, there may be a simple fix. Here are some possible answers and suggested solutions:
1. Your set-top box may need a simple reboot. Unplug the power connection to the set-top box for about 30 seconds. Reconnect the power and turn the set-top box back on.
2. Check all of your cables for a loose connection by tightening each one with your fingers.Flickers can sometimes be caused by bends in rigid cables, too.
3. If your picture flickers to a black or blue screen, you could have a bad set-top box. Contact your cable or satellite service provider about installing a new one.
4. If you still have audio, the flickering could also mean that you have a failing backlight.
For additional troubleshooting information, check out the chart at TV flickering for more solutions. I hope this helps!
Sep 14, 2012 | RCA Televison & Video
My Phillips 32pw8759 TV screen is Permanently blank
There might have been a power surge that had damaged the two units. For the reset, having the tv unplugged overnight should do it. If it does not work you may want to check the power supply of the tv for leaking capacitors or burned resistors or loose solders.
Aug 15, 2009 | Philips Televison & Video
A white screen that says set top diagnostics is on the screen
Hello pwon28,
This means that your set top box has been put into diagnostic mode and is showing on the TV. Power down your cable/satellite Set Top Box and then power it back on. This should clear up this problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 13, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Philips set top box malfunction due to power cut
sounds like a capacitor in the unit might be faulty. not reaching full charge, any other items get spiked in the blackout? insurance might be the way to go. i had a set top box that fried all the capacitors, i replaced the , cost about $10Au and some time soldering. unit works better now that before,
Jan 25, 2009 | Televison & Video
Hi, I have a Sansui high
i have same problems has any resolved this yet??
Mar 25, 2008 | Televison & Video
Set top box and remote control
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
Sep 16, 2007 | Hitachi 51F710 Rear Projection Television
Toys Logo
49 people viewed this question
Top Sky Toys Experts
Marvin
Marvin
NOEL
NOEL
matt
matt
Are you a Sky Toy Expert? Answer questions, earn points and help others
