Question about Brother IntelliFAX 770 Plain Paper Thermal Fax
How do i copy and sort? - Brother IntelliFAX 770 Plain Paper Thermal Fax
  • 1,297 Answers
Enter in the function node and press the Start (green button) for copies.The sort is not possible to the fax machine.
Posted on Dec 12, 2009
How do i fix sorting issue on my AR-276 SHARP PHOTOCOPIER?
Try doing a reset by unplug wait 10 min. and plug back in.
press the helpful button
Jan 30, 2016 | Sharp Office Equipment & Supplies
What do you mean by "stack copies" in brother
Sorting copies using the ADF
You can sort multiple copies. Pages will be
stacked in the order (1, 2, 3), (1, 2, 3)
and so on.
1 Press (Copy) to illuminate it in
green.
2 Load your document.
3 Use the dial pad to enter the number of
copies you want (up to 99).
4 Press Options and ? or ? to select
Stack/Sort.
Press Menu/Set.
5 Press ? or ? to select Sort.
Press Menu/Set.
6 Press Start.
Jun 28, 2011 | Brother MFC 7420 All-In-One Laser Printer
My sort buttons and button to copy from one sided to 2 sided disappeared. I tried to reboot the HDD and it says failed. Do I need to replace the copier??
hello mate. to select the sort options and duplex copy you have to select from machine operation. email me on ronils_singh@yahoo.com.au. i will guide you
Sep 24, 2010 | Ricoh Aficio 1035 Copier
Can the Canon Imagerunner 3030 count/sort sheets of paper out for you?
please, the count you want is copies made or you want the machine count the originals ??
The machine count 1 copie for A4 (LGL) and 2 copies for A3, called double count.
Nov 20, 2009 | Canon Office Equipment & Supplies
How to do copies,ie what buttons do i press
Making a Single Copy
Place the original face down in the ADF.
2 Press Copy/Help twice.
To cancel, press Stop.
Do NOT pull on the paper while copying is in progress.
Copy Options: Single or Multiple Copies,
Reduce/Enlarge, Sort/Stack
You can choose additional copy options. First, you can select the number of copies. Next, you can
choose whether multiple copies will be STACKED (all copies of page 1, then all copies of page 2, etc.)
or SORTED (collated). Finally, you can choose an enlargement or reduction ratio. To automatically
reduce the copy to the paper size you have set for the paper tray, select AUTO. To reduce the copy by
a fixed percentage, choose 93%, 87%, 75% or 50%. Or, to enlarge the copy, select 150%, 125% or
120%. To copy a document at its original size, select 100%.
1 Place the original face down in the ADF.
2 Press Copy/Help.
3 Enter the number of copies you want (1-99).
For example: Press 9 for nine copies.
To start copying now, press Copy/Help.
If you would like to select additional copy options, like
SORT, ENLARGE or REDUCE, press Menu/Set.
Oct 02, 2009 | Brother FAX-T74 Plain Paper Thermal...
I have a Ricoh Aficio and I cannot find how to use the stapling feature.
Are you sure it has stapling?
Some machine may show it on the control panel but it is an option that may or may not be installed.
Is there a stapler in the sorter?
If it does, then the stapling should come up as a finishing option when making copies.
On your control panel, there will be a Sort, Group and a Sort/Staple option.
Select this feature and it should staple your copies.
If you select this and it doesn't staple then it may be out of staples or the copy is not the correct size or orientation to allow stapling.
Apr 15, 2009 | Ricoh Office Equipment & Supplies
Brother mfc8860dn what do you mean by sort button
The sort button is one of the 6 buttons on the bottom right side of the control panel within the series of buttons in the COPY controls. When making multiple copies of documents with more than one page, it tells the MFC to sort the multi-page coping jobs into the correct order of the original document rather than the seperate individual pages.
Mar 07, 2009 | Brother MFC-8860DN Printer
Matching data
1. Open up both workbooks.
2. Copy one worksheet from one workbook to another using.
Right click on the tab of one book and Select "Move or Copy"
3. A dialog box will appear..Next to the "To book" select the workbook you want to move it to.
4. Be sure to select the 'create a copy' box in the bottom left of the dialog box.
5. Sort each worksheet by students name. Data..Sort.
6. Copy the scores from one sheet to another.
7. You then you can manipulate the scores and compare anyway you like by using formulas in different columns.
Apr 29, 2008 | Microsoft Excel for PC
Copier will not sort documents correctly
Hi songman to sort you need to have the A4 paper in both cassettes one cassette needs to be A4 portrait(wide edge first) and the other needs to be landscape (short edge first)make sure you have the green paper size selector set correctly as well regards Dr Bob1
Apr 09, 2007 | Ricoh Aficio 1018D Copier
Brother IntelliFAX 770 Plain Paper Thermal Fax Logo
23 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
