Question about Maytag MZD2766GES Side by Side Refrigerator
After struggling with my Maytag side by side (model MZD2766GES) for the past week, I think I finally have my freezer working as it should. However, it's on its coldest setting because I'm trying to get my refrigerator to cool. It feels warm. Why isn't cold air flowing over from the freezer? My ice cube maker is'nt making ice. Could my ice maker be locked up because of a recent thaw from the door being cracked open for a couple days and it's affecting it's operation? I scraped away the buildup of frost/snow from inside that was covering up the air vents. Could I have a buildup somewhere that I can't see? Should I empty everything out and thaw it out with a hair dryer or something? I don't know if maybe I should start taking things apart, but I'm considering it. Can you help? Your expert advice would be much appreciated. Thank you!
  • bellbrookbla Dec 12, 2009
    Thank you very much!
  • Maytag Master
  • 19,396 Answers
If the refrigerator is not cooling, and if there is no air circulation, ten the repair is done testing the damper motor, then replacing either damper motor or damper control (PS2061210 part 8- diag a ).
If the motor is working, then the temperature control may also be responsible (PS2060682 part 12 diag a)
If it is none of the above, then the compressor may be producing insufficient cooling. In that case have a look at the defrost system, testing element, high limit thermostat and fan.
Regarding the icemaker blocked, check if water is getting to the icemaker. Lines can be blocked, or the outlet water valve may be not working.
Rather than using a fan on water lines, if possible do a complete defrost, leaving the fridge disconnected overnight. That will get rid of ice buildup.
Click here to get all parts and diagrams for your appliance.
Posted on Dec 12, 2009
How do i fix my fridge that stopped working?
To aid in troubleshooting, the link below may be of help:
MAYTAG MAYTAG REFRIGERATION Parts Model MZD2766GES Sears PartsDirect
You may have a failed defrost heater.
Jun 27, 2015 | Maytag MZD2766GES Side by Side...
The freezer stopped working (the fridge is working but not as cold as it should be), I cleaned all the vents and the freezer worked again fro a short time then I heard a noise like possibly the fan...
It does sound like a bad fan motor. With the compressor getting hot you may need to change the start relay, overload and run capacitor if it continues to run like this with a defective fan motor. What is the correct model number? Sea Breeze
The condenser fan motor for a model MZD2766GES is part number=> 61005323 Condenser Fan Motor or here=> 61005323 Condenser Fan Motor
Oct 18, 2013 | Maytag MZD2766GES Side by Side...
I have a Maytag side by side MZD2766GES --the freezer is working great but the Frig side is only about 46,I have turned it to a colder setting ?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | Maytag MZD2766GES Side by Side...
Refrigerator does not cool. Coil in back of freezer has lots of ice and frost on it. What do you think the issue is? Thanks. SIde by SIde Maytag Model mzd2766ges.
with out question your have a defrost problem . either the heater / thermo or adative defrost control has failed . i would ck the heater . i think you will find it ok . then replace ( don't ck it just rep it defrost thermo . and if problem does not go away then the a d contorl . and its a little harder to repl than the others. .. mm majic **** .
Oct 22, 2010 | Maytag MZD2766GES Side by Side...
MSD2650KES SIDE BY SIDE REFRIGERATOR - BACK OF FREEZER ICED OVER AND REFRIG NOT STAYING COLD. DEFROSTED FREEZER, WORKED FOR A WEEK OR TWO NOW THE SAME THING...HELP
either the defrost heater located next to the evaporator core is burned out or the defrost timer unit is defective in the refrige compartment controls area or the defrost thermostat on or near the evaporator coil in the freezer is defective
Jun 08, 2010 | Maytag MZD2766GES Side by Side...
Maytag SidebySide model MZD2766GES Fridge portion not working...
yes probably the a.d.c. but make sure all ice is defrosted from evap. coil. remove the freezer panel and use heat gun or hair dryer.
Aug 05, 2008 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
74 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
