Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F1 code at 17 min. left on normal cycle - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • Whirlpool Master
  • 2,696 Answers
There is a recall on your machine,call factory and they will give you a new control board and install it
whirlpool F1 code - Appliance Repair Forum
Posted on Dec 12, 2009
Testimonial: "Thanks.....After I Saw the telephone # posted I called and a girl named Crystal set up an appointment for this Tues ...WoW !!!"
  • Sal De Dec 13, 2009
    you're welcome and i'm glad i could help
Kenmore Elite Washer Oasis Model: 11027042603 I have been getting a F1 code error with all wash cycles for the past month. It occurs as soon as I start the wash cycle and with 23 minutes remaining in the...
depending on its age take a look at the motors brushes. sounds like 23 mins would be spin cycle when the motor picks up speed. they may need replacing.
Dec 08, 2013 | Washing Machines
I have a Whirlpool Cabario. I keep getting an error code of F1. I hit cancel and then start several times and it resets itself and continues. The same thing happens when it is about to start the rinse...
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Bosch Classixx 6 - tried washing a load on easy care which on normal cycle takes 48 min, the timer counts down for about 5 mins but doesn't sound like any water is being drawn in. After the 5 mins or so...
i have checked all my tech info and error codes only go to f 12!! never had f 17 but based on description sounds like either flow sensor or inlet valve failure will need service tech to sort out but if either of these will not be expensive.
Nov 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
The washing stops 3 times when you first start it with the codes F1 on display then 3 more times with 19 min. left with the codes F1. What is F1? Everytime it stops I press the stop button then start...
This F1 Code is a Communication disconnection problem between the Control Unit and the Electronic Curcuit Box. First Check the Connection and reply me with the make and model no.
Sep 21, 2009 | Washing Machines
Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Feb 13, 2009 | Whirlpool Washing Machines
On start up the washer show F1 Ihave to hit pause start 3 time
The F1 fault is indicating a problem with the main machine control board assembly. It may be going bad but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru --- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Washing-Machine-Parts
Jan 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
f1 code means the main control needs to be replaced. pretty common repair
Dec 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
142 people viewed this question
Dan Webster
Dan Webster
Sal De
