Question about Thump T1046 Car Subwoofer
If the speaker no have movement so how to repair it...
  • 47 Answers
Umm, does it produce sound? Or is it seized. Because if so the coil is blown. I doubt there are any re-cones for that subwoofer, so just buy a new one.
Posted on Dec 13, 2009
SOURCE:
I have an Kenwood 12" sub woofer everything looks good but it will not do anything
The assumption is that it is a passive speaker with no crossover circuit. If you connect a good 9 volt battery to the speaker and neither hear or see a sound or movement the next step is to confirm with a multi-meter an open voice coil circuit.
It is possible to repair a broken wire but not likely a burnt- open voice coil.
Hope this helps?
Apr 03, 2016 | Kenwood KFC-W3003 Car Subwoofer
I need parts for my seth thomas westminister ave marie clock I need the swinging mechanism the clock is a mantel clock, the bar and head is missing a parts list would help
Howard Miller Clock Parts ' eBay
www.ebay.com/bhp/howard-miller-clock-parts
eBayHermle 2115 Ave Maria Westminster 2 Chime Quartz Clock Movement ... hermle hamilton ridgeway howard miller seth thomas, clock winding key #7/4.00. $9.99.
Clock Repair & Replacement Parts - Movements, Motors ...
timesavers.com/c-325738.3-clock-repair-replacement-parts-movements-...
Items 121 - 180 of 249 - Front Plate - Seth Thomas #2, #77 Movement ... of #2, 77 movement parts that have been in storage since the 1970s. ... Hermle #2115Westminster/Ava Maria Quartz Movement ..... My Account; Login/Register · My Cart.
Jan 27, 2016 | Westminister Time Warp Shelf Clock
How do I get access to repair loose wires?
Some compact speakers are accessible internally only by removing the the grilles but caution is advised as some grilles are glued on to prevent rattles.
Aug 05, 2015 | HP 2.0 Compact Speakers Br387aa
Chimes do not work
Check for loose wires between the clock Movement and the chime box. If those are good (and the batteries have good solid connection-not lose) you probably need to replace the chime control box or the whole movement.
Timesavers.com carries replacements.
Mechanical clocks, while more in cost, will live a much longer life with proper care than battery clocks. Plus, an actual chime (not noise through a speaker) is much more pleasing to the ears.
Jan 11, 2014 | Seiko Mantel Clock
WHEN YOU PUSH DOWN EVENLY ON THE SPEAKER ITSELF...IT JUST SUDDENLY GIVES-WAY, WITH A KIND OF POP. DOES THIS MEAN THAT THE WOOFER IS BLOWN??? AND IF SO IS IT POSSIBLE TO REPAIR THIS TYPE OF PROBLEM? ...
The first thing to do is to check the resistance of the voice coil. Get an ohm meter & place one lead on each of the speaker terminals. If a value of 0 ohms results, or no reading at all, the voice coil is blown.
If you are pressing in, and suddenly gives way, my guess would be that the excursion of the speaker was too grand (common with car stereo, everyone loves bass) and the wires that wrap around the voice coil of the speaker were broken from the speaker inputs.
It is possible to recone the speaker, but by the time you track down a recone kit (highly unlikely that it is even available) you would be rather deep into the project.
Long story short:
check the speaker terminals with an ohm meter. If you get a resistance, they should work with free woofer movement. No resistance = blown woofer.
Mar 17, 2011 | Lanzar MAX10D Car Subwoofer
Have Cobra 29 LTD Classic, no sound when hooked to antenna, no light or meter movement on the RF/SWR meter, DOES have power to radio and channel display, any tips to repair, or check for problem areas?
check the squelch by turning all the way both ways. check the external speaker socket. if it is the swicthing type it could be either bad conntact or dry joints. try an external speaker to see if that works. another thing is I believe it wont work if the microphone is not pluged in or connection fault there. Good luck.
Jul 25, 2010 | Cobra 29 LTD CB Radio
The magnets came lose is there a repair place that can realign and attach my magnets
flip the speaker upside down n it should b a hole thats where the screw is a woffer is nothig but a cone n a magnet
Jun 01, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Why is my L7 12" *******
Get a volt meter and check the resistance from the positive pole to the negative. There should be at least 2 ohms or 4 ohms depending on the model you have. No reading at all? Check the leads under the terminals - are they still connected? Does the voltmeter read 0 or no ohms- then the voice coil is shorted out and should be repaired or replaced.
-Dynami
Mar 26, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Sony ericsson c902 loud speaker is distorted any ideas how to get into clean it?
Hey guys ....
follow this link, its shows you how to take appart your phonr to inspect?clean the speaker.
www.formymobile.co.uk/c902disassembly.php
Mar 21, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
Harman Kardon Elegant 2.1 speakers problem
Chances are you have wrecked the cone and movement with the overly high input. Nor repairable if this is the case. Check out the makers website for more tech info
May 13, 2007 | Harman Kardon HK695 Computer Speakers
Thump T1046 Car Subwoofer Logo
63 people viewed this question
Top Thump Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Thump Car Audio and Video Expert? Answer questions, earn points and help others
