Question about Whirlpool AWM8000 Front Load Washer
AWM8000 push button for door has snapped off can I get a replacement?
  • spatt29608 Dec 12, 2009
    Website given does not supply parts and parts website they refer you to I can't find what the part is called to locate it. Any suggestions?
  • Whirlpool Master
  • 3,463 Answers
There should be no problem getting the part you require for your washer.
Go to:
www.whirlpool.co.uk.
You should be able to get what you want there.
Hope this helps solve your problem
Posted on Dec 12, 2009
SOURCE:
Power locks fell into door
Remove door panel by prying out at the bottom. Follow around door and remove the panel retainering tabs. Push up on panel to remove from top of door. Now snap the window lock button assembly back in place.
May 10, 2014 | Nissan Maxima Cars & Trucks
The push button to open the door does not engage door, so door does not open
in most cases this is due to a snapped of push bar as they are made of plastic its a common fault. if the push bar is not snapped then its lost a plug that holds it in. as the microwave holds a constant 1000 watts of power i always recommend to people to have them fixed by lic techs the repair cost for this fault is around $ 100 if the part is still available
hop this helps please rank advice below
Dec 28, 2010 | Whirlpool GT4175S Microwave Oven
My lift gate says that its open when its closed and my interior lights will not turn off
there is a push button switch in the door jamb for the lift gate. look closely and you will find it. when the door is shut the button is pushed and the interior lights and open door warning go off. it is broken and you need a new one. this will be a dealer item and it snaps or screws in. when you get the new switch you may want to pay someone with mechanical aptitude to replace it.
Dec 06, 2010 | 2006 Jeep Commander
F dU
FdU = Door unlock error
Possible Causes
1 Door Lock Mechanism broken.
2 Check Door Lock/Switch Assembly for foreign objects
3 Check Wire Harness connections to the Door Lock/Switch    Assembly and Central Control Unit (CCU)
4 Door Lock/Switch Assembly Failure
Jul 27, 2010 | Whirlpool AWM8000 Front Load Washer
Radio does not shut off when drivers door is opened after engine is shut off
button on door is sticking, with door open try pushing in the button and releasing it quickly let it like snap back out..
Jul 20, 2010 | 1994 Chevrolet Corvette
AWM8000 AF flashing and machine cut out, very
WHEN I PRESS START - HAS ALARM ON DISPLAY F AND H FLASHING AND TAP OPEN POSTER HAS THE FLASHING LED TOO. HO TO REPAIR IT.
MY NAME XUAN
Sep 29, 2009 | Whirlpool AWM8000 Front Load Washer
Driver's side interior door handle snapped off
there is plastic snaps that attatch the panel to the door all the way around the panel which you can buy a tool to remove the panel without breaking the snaps,the door handle may have a cable hooked to it that releases the latch and it might be stretched causing the handle to pull hard
Apr 24, 2009 | 1989 Ford F 150
Exterior rear door handle on Honda Accord 2001
To Remove Door Panel on 2001 Honda Accord:
A: To remove the plastic piece with the door lock button and door handle connected to it:
1- Remove the screw in the middle located behind a plastic cover button
2- Push (slide) the whole assembly Forward (toward front of car)
Besides the screw, it is held in place by 3 hooks on the backside that hook into holes in the metal door frame
3- Now unhook handle from small metal bar going through door by pushing (toward door) plastic clip (blue?) off of the bar, then the bar will come out of the clip hole, thus releasing the handle.
4- Depress little grey button /bar (purple painted on it)on elec. connector to seperate connector, thus releasing door lock switch
Now the whole assembly (metal handle, door lock switch, and plastic piece) will come off door panel
B: The door is held on by 2-screws, 7-plastic snaps/plugs, and 1-plastic plug.
The screws are located: bottom of hand hold and the other behind the handle, both covered by little covers that have to be pryed off to access the screws.(hint: the screw with the built in spacer goes behind the handle when you are trying to reinstall)
The 7-plastic snaps: 3 across bottom and 2 on each side. Not visible, they are mounted to the inside of the panel.
The 1-plastic plug is visible at the upper front of the panel and is the same color as the surrounding trim
C: Take off the big plastic triangle piece above the door panel and behind the mirror. Pull/pry off. It has 2 snaps holding it on. one near bottom and one near the front.
D: Light lens prys off from bottom. Unscrew (1/4 turn) the light assembly with bulb still intact from backside of panel
E: Remove the Hand-Hold/window switch assembly:
Jan 14, 2009 | 1997 Toyota Camry
Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Oct 07, 2008 | Kenmore 63942 Dryer
Whirlpool AWM8000 Front Load Washer Logo
98 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
