Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Wont fill with water
The washer will turn on to spin but when you try to fill it with water it just hums but the water isnt coming out, how do I fix this?
  • chantelle23 Jan 20, 2008
    there is water getting past the valve, we actually had a guy come and fix it when it happened before and he just reseet the machine but we dont know how he did that
    Problem Solver:
  • 10 Answers
I probably has a bad fill valve or a clogged screen suggest check to see if the fill valve is engaging and if there is water getter past the valve.
Posted on Jan 20, 2008
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
Have a whirlpool washer that now hums when I turn the cycle on, no water just a hum
I had a similar problem - had to get a technician out - there was a valve at the back of the machine that allows the machine to fill. It had split (apparently its a common problem? there are separate valves for hot and cold water, so I'm not sure if using a different cycle choice (ie cold only), may let the machine fill?). 10 minute fix job
Jul 14, 2012 | Whirlpool Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
hi, Does the water drain out in the spin cycle? Sounds like the coupler might be bad. Is this a top load machine? Asking questions so I can be clear and give you better info on your question.
Please let me know.
Thanks
Vic
May 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer fills up but wont spin
heck your lid switch make sure it isnt broke and if it isnt you will need to replace the motor and pump coupler it comes with three pieces 2 nylon busshing and a rubber gromet that connects the 2 nylon pieces together very in expensive (usually under 20 bucks) you can easily purchase one at your local dealer or anywhere on line. Glad to be of service
Jan 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hotpoint washer
Your machine has multiple issues. First, the obvious: are the water lines turned on? When you try to fill it with water, can you hear the water valve humming? Try different temperatures, too. If it lets one temp in, but not the other, you need a water valve. If it doesn't hum at all, you could have a problem with the pressure switch or the timer.
The motor humming is the issue that worries me. Try removing the belt from the motor pulley. If the motor turns now, it's a transmission problem. If it won't agitate (you'll have to satisfy the pressure switch first) or spin at all, your transmission could be locked up. I've had limited success by pulling on the belt (hard) in both directions. This has only worked once to unjam the transmission.
Mar 01, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My new Frigidair front loader
Wow it sure sounded like the water was turned off. There should be no problem getting a tech out soon to see whats going on why it wont bring the water in. It sounds like maybe the door lock isnt working?? Is the strike broken on the door?? I take it it wont spin on its spin only cycle??just return it to place of purchase. If you need any other assistance let me know, reply to your old posts so i can be notified you wouls like more assistance.
Jan 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal De
