Question about Sony Memory Stick PRO Duo (2GB) for PSP
Sony Memory Stick PRO Duo write-protected
Do u have any software for unlock this kind of memory card
  • Scott May 11, 2010
    What do you mean by 'unlock'?
SOURCE: wont access memory card
i) try to put memory card in any mobile if it working in it is fine, if not your memory is having some password put on it or attached, try to remove the password and then work with it ........
you can remove password by keeping the memory card only in that mobile where you kept the password(only in that mobile through which u kept the password...)
Posted on Dec 28, 2008
Geekman
  • 32281 Answers
SOURCE: memory stick pro duo sony won't read
Files on a flash drive and memory cards in a card reader can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the memory card and flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Posted on Nov 19, 2009
  • 7 Answers
SOURCE: Memory Stick PRO Duo is write protected
I had this problem and figured out a easy fix.
1. Take out memory stick from psp
2. Plug in usb to psp and start usb connection
3. Psp will recongnize there is no memory stick inserted
4. Now insert your memory stick and your good to go
For some reason you might have to repeat these steps everytime you want to access your memory stick.
Hope This Helps
Posted on Jan 23, 2010
SOURCE: my laptop cannot read memory stick pro duo 2gb
same problem here The driver is recognized but not opened
Posted on May 27, 2010
dj_relly999
  • 4070 Answers
SOURCE: My Sony Memory Stick PRO Duo says there is no
Hi! YOu will have to reformat the memory stick via pc. When you insert it on the pc a new drive will appear. Right click on the drive and click format. This should fix it, if no luck.... then i believe that the stick is faulty and may require replacement. Hope this helps and have a good one!
Posted on Jul 02, 2010
How to remove write protection from sony memory stick pro duo
There should be a small plastic catch on the side of the card which allows you to write protect the memory stick pro duo. It should have an image of a lock or say locked next to it, if it is locked you won't be able to write to it. Slide it to the unlocked position using a fingernail or a paperclip.
Apr 29, 2015 | Sony Electronics - Others
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Mar 26, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
The disk is write protected
You only can use Memory Stick Duo. There is a write protection switch on the memory card, you only can switch with a sharp point. Ball point or something like that. Have a close look on the card.
"Memory Stick Duo", "MagicGate Memory Stick Duo" and "Memory Stick PRO Duo" are equipped with MagicGate functions.
MagicGate is copyright protection technology that uses encryption technology. Data recording/playback that requires MagicGate
functions cannot be performed with this camera.
So if you have a MagicGate one it does not work and could give this error.
Nov 06, 2013 | Sony Cyber-shot DSC-W50 Digital Camera
How to protect pro duo card from unauthorised viewing
you enter card into computer and and going card properties,there having security system.
Mar 24, 2013 | Sony 4GB Memory Stick PRO Duo Memory Card
How Can I read my Memory Stick Pro Duo MARK 2 on my Computer? MY problem is I cannot read my Memory Stick Pro Duo Mark 2 on my computer but my computer is showing another Removable Disk(F:),which is my...
    • 1 Visit the Sony Support site (see Resources) and download the Sony memory card software. You will need to specify your operating system. Save the file to your desktop.
    • 2 Double-click the downloaded file to launch the installer.
    • 3 Follow the onscreen instructions to install the Sony memory card software. Restart the computer after completion. Once the computer starts back up, it will recognize the Memory Stick Pro Duo when inserted into the computer's memory card reader. You can browse the files using Windows Explorer or the installed x-Pict Story software.
May 31, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
My sony memory stick pro duo is write protected
There should be a lock switch on the card, most likely on the left side. Slide the switch into the opposite position and see if this fixes the problem. If not, try formatting the card from your camera and then attempt to load it on to your computer.
Mar 18, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
How can i unlock my sony 1gb memory stick?
There is a switch on the side of the actual memory card--> slide it up or down to 'UNLOCK'.
Hope this helps,
pennywise25
Jul 17, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Hope This Helps
Dec 23, 2008 | Sony 4GB Memory Stick PRO Duo Memory Card
Sony Mavica MVC-FD2000 can't read memory stick...
THE CARD PROBLBLY HAS NOT BEEN FORMATTED...ARE YOU SURE IT IS A MEMORY STICK PRO "DUO" THERE ARE DIFFERNT KINDS OF MEMORY STICKS (PRO DUO, PRO, QUAL, ETC.)
Feb 21, 2008 | Sony Mavica MVC-FD100 Digital Camera
Sony Memory Stick PRO Duo (2GB) for PSP Logo
118 people viewed this question
Top Sony Electronics - Others Experts
 Grubhead
Grubhead
Argospete
Argospete
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
