Question about HP Photosmart C6280 Printer
Had paper jam. Followed instructions to release
Had paper jam. Followed instructions to release paper jam and have smears with black ink. Have done everything to correct the problem that is recommended by HP solutions. Also replaced black ink cartridge. Fine print is better than larger print.
    Genius:
  • 1,018 Answers
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Posted on Dec 12, 2009
Repair on Hp laserjet 4250. Printing but smearing black ink on paper
the fuser roller needs to be checked/ replaced. this is in the fuser unit which is availale in the maintenace kit from hp. all instructions in the manuals and on hp website
May 11, 2010 | Office Equipment & Supplies
Getting black streaks across documents and pictures
Usual cause is defective bllack cartridge or it needs to be removed and excess ink cleaned from the face of it.
SOMETIMES using too heavy of paper can bend up an touch the bottom of the cartridges as tehy move across to page.
Also a paper jam can brush the cartridge and after that the ink is smeared on the cratridge face and will mark the paper as it moves across.
Using BAD refilled cartridges is a common problem.
Nov 08, 2009 | HP Photosmart C6380 All-In-One InkJet...
My Canon i 560 s will not print and this is the error message, I followed instructions, no change, won't print, yellow light flashes ,"Operator error. Press the printer's RESUME button. If this doesn't...
Turn off your PC, turn off the printer. Open the printer and check for paper jams, push/pull the ink cartridge carrier left to right to ensure it also isn't jammed.
Only use a small amount of paper (10 sheets). Too much paper can sometimes block the feeder
Turn everything back on, try again.
Jul 02, 2009 | Canon BubbleJet i560 InkJet Printer
My printer (Canon Mp480) says there is a paper jam and I have done everything to find out, BUT THERE ISNT ONE!
Followed the instrutions above. Have to get in a good light, open all "gates", and remove inks. However, the photo paper matches the white plastic inside and was hard to see. Found it, got a pair of tweezers and paper came right out! Thanks all.
Jun 07, 2009 | Canon LASER SHOT LBP-5200 Printer
Print Quality Problem
Hi jepeto997:
Try these steps.
Check for and remove any media, jammed
paper, or debris found in the printers exit
path.
2. Did this correct the problem?
Complete. Go to Step 2.
2 1. Clean the maintenance kit wiper blade or
replace the maintenance kit.
Complete. Go to Step 3.
3 1. Check the exit area, exit frame, the
preheater, maintenance kit, and the
printhead (including the paper release blade)
to see if there is anything touching the drum
assembly.
2. Reseat any printer component interfering or
touching the drum assembly.
If there are streaks on the front side only of a
2-sided print, the preheater may be scraping
ink off the print.
2. Look for ink shavings along the streaks on
the printed paper.
3. Clean the preheater using the Control Panel
Remove Print Smears function.
4. Did this correct the problem?
Complete. Go to Step 5.
5 1. Possible weak or missing jet. Print the weak/
missing jet test print from the Control Panel,
see "Weak/Missing Jet" on page 5-33.
Complete. Go to Step 6.
6 1. Possible discolored jet. Print the solid fill test
print, see "Black, Red, Green, Blue, Cyan,
Magenta, and Yellow Solid Fills" on
page 5-40.
Complete. Go to Step 7.
7 1. The X-axis drive is not functioning correctly.
If the X-Axis Drive does not move the
printhead smoothly and evenly during
printing, vertical lines appear on the print.
For information about X-Axis Drive
problems, see "White Stripes (Pinstripes)"
on page 5-30.
Complete. Go to Step 8.
8 1. Smears on a duplex print can be caused by
the paper preheater operating at a
temperature that is too high or debris is in
the duplex roller or duplex paper path
guides.
2. Run the service diagnostics Duplex Path
test to check the paper preheater’s
temperature.
3. Is the operating temperature within the
correct value range?
guides.
temperature.
Replace the
preheater.
Replace the
electronics
module
Hope this helps
3. Clean the paper release blade.
May 20, 2009 | Xerox Phaser 8560N Laser Printer
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
May 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Dell A940 smeared printing
Our Dell AIO A940 stopped printing black ink (it went throught the motions but he paper came out blank). Finally got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
Maybe it will work for you! Good luck!
Dec 11, 2007 | Dell A940 All-In-One InkJet Printer
Gestetner DSc332 streaks and smears when printing in color
Check to see if you have a paper jammed near the drum near the color ink cartridge interface.
Nov 28, 2007 | Gestetner DSc332 Copier
HP Photosmart C6280 Printer Logo
157 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
