Question about Desa International CCL3924PTA 24" LP Gas Log Heater
Burns for a few minutes but when when it goes off the pilot light goes out.
  • 767 Answers
Flame sensor is bad or dirty. You can try cleaning it with a piece of emery cloth or sand paper.
Posted on Dec 12, 2009
SOURCE:
Pilot light problems
Could be the bulb of the safety thermocouple is not being heated by the pilot light or the thermocouple is faulty.
Jan 22, 2016 | Heating & Cooling
My gas Dearborn model#drc40mc pilot light stays lit.when I turn to on position and heater comes on , it burns high , even on low number setting, then after few seconds goes out taking pilot out also
clean/replace the flame sensor. Your heater doesn't recognize that it has lit and continues to try and light the gas. when the sensor doesn't tell the 'brain' it lit? it shuts down the gas for safety reasons.
Oct 19, 2014 | Heating & Cooling
The pilot light will not stay on for more than 5min. If I light the fire when its on,it just goes out. The fire is a Fusion 2/7
I assume this is a gas log? If so, you have dust in your pilot assembly. Turn everything off and let it cool. Note the opening where the pilot flames burns. Use the wand from your vacuum cleaner and place it over the opening for the pilot flame. Gently tap the side of the pilot assembly while holdign the vacuum above the opening. This will lift the minute dust particles out and allow the flame to burn nice and blue again. These logs have Oxygen Depletion Valves on them. The pilots are very sensitive to dust.
Jan 18, 2011 | Heating & Cooling
I have an empire heater and the problem that I am having is that when the valve is turned on high or any setting, the flame burns for a few minutes then goes out. It will not stay burning, we have to...
Have you replaced the thermocouple? Have you cleaned the Pilot? Do you have a strong pilot flame and is it touching the thermocouple? Sometimes if you don't have a good strong pilot is that when you turn the main gas on it pulls the pilot flame away from the thermocouple and cools it off so it drops the signal. Check the gas pressure should have 10 to 11 "WC of manifold pressure.
And you could have a bad gas valve. Hope this helps.
Jan 02, 2011 | Sunbeam Heating & Cooling
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
AFTER LIGHTING MY RICHMOND 6G40-36F1 WATER HEATER IT LIGHT FOR A FEW SECONDS AND THE FLAME AND THE PILOT LIGHT GOES OUT. WHAT CAUSE THIS TO HAPPEN?
There is air in the gas line. The best way to get the air out, is with the gas on, loosen the nut that attaches to the gas valve and make sure you can smell a little gas, then reattach the gas line, making sure everything is tight, and then relight the pilot making sure to hold the pilot light button down for at least 1 minute. Please rate
May 24, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heating & Cooling Logo
91 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Steve Allison
Steve Allison
mcijoe
Level 1 Expert
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
