Question about HP Officejet 4315 All-in-One Printer
I load paper and printer tells me it is out of paper
    Genius:
  • 1,018 Answers
If your printer has multiple paper sources, then you may be loading the wrong source.
Check the application you are using under the page setup menu to make sure you are not telling the printer to print from the manual tray as opposed to the auto-feed tray.
Don
Posted on Dec 12, 2009
My printer says load paper then press start, I have paper in there and it wont print.
Dont know what you have already tried but first off verify that you are loading paper to the correct tray. Now this tray is going to have a switch located toward the feeder that tells the printer paper is loaded make sure the paper is back far enough but not to the point where you are forcing the paper into the feeder. If all this still doesnt work try reseting the printer and printing a test page. Hope this helps.
Mar 10, 2010 | Dell 924 All-in-One InkJet Printer
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Jan 14, 2010 | Brother MFC-9440CN Laser Printer
Printer wont print. It keeps saying PC Load Legal. The printer has paper in it.
Well the printer is telling you to load "Legal Size paper, which is 8.5" X 14" paper.
More than likely, the application you are using is telling the printer to print the page on legal sized paper.
If you want the document to print on "Letter sized paper (8.5" X 11") then in the application, go to the File drop down and select "Page Setup". From within page setup's window, change the paper size to letter and then re-print the job.
Don
Dec 16, 2009 | HP LaserJet 4 plus Printer
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
My Brother MFC-9420CN printer is telling me to check the paper size. How do I do this?
Check to make sure the document your sending matches the paper size you have in your paper tray. The reason its telling you to check the paper is because your document size and paper loaded aren't matching
Jun 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Printer loads paper incorrectly when trying to print
in the tray where you put the paper, there are two pieces of plastic that site on the side ,,,,, bring them close to the paper as to touch the paper.
this way the paper cannot go left or right when loaded and now will go in straight.
this oughta do it.
Mar 26, 2009 | Dell 922 All-In-One InkJet Printer
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
I get a load paper message when paper is loaded
Probaply some paper or obstackles stuck at PE (paper empty sensor) and that could be hard to fix it cuz you may need to pull apart the printer. However, if it is 6 monthsold, warranty covers this problem.
Feb 08, 2008 | Brother MFC-7820N Laser Printer
Epson R300 printer
ok " if you look in where the paper is loaded on top there is a small switch with a finger , may be bent. tells printer when paper is low
rubber wheels that pull paper threw may be glazed , take sand paper and go over wheels to ruff up
Jan 22, 2008 | Epson (C31C411016) Printer
Printer tells me to load paper and it already is loaded.
It sounds like you have the printer set on Manual Feed. This is common when you are hand feeding single sheets like resume paper rather than using the tray. I would suggest looking at the default settings on your printer object on your computer or maybe there are settings within the 1020?
Sep 10, 2006 | HP LaserJet 1020 Printer
59 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
