Question about Sony CMT-NE3 CD Shelf System
My sony CMT-Ne3 wont play CD's, when I load a disc the display says it reading and there are 3 clicks whilst the disc spins, then the disc stops and it displays no disc. I have cleaned the dust of the laser and it's still the same, any ideas?
3 Suggested Answers
SOURCE:
SOURCE: is their an aux function for a sony cmt-ne3
What if I no longer have the remote?? Is there another way of accessing the MD or "aux"??
Posted on Jun 24, 2010
F1xer
  • 415 Answers
SOURCE: Sony CMT-EP515 CD Shelf System. CDs wont play.
It could be 3 things.
1. the Laser carrier may be stuck and may need to be gently pried from centre to outskirt and back.
2. your cd spinning motor has gone and needs to be replaced,
3. your laser carrier motor has gone and needs to be replaced,
hope it helps.
Posted on Aug 04, 2010
What antenna I need for a Sony CMT NE3 mini hi fi,and where can I buy one in what shop please not on the net.
write down the details of the unit and go to places like JAYCAR or other electronic retailers and talk with them as to what you want
Jun 23, 2016 | Sony CMT-NE3 CD Shelf System
My cd player does not play music in order, instead of 123...it skips to 5 than 8 etc.
There's a control under PLAY MODE that selects random play labeled "1 DISC SHUF". Normal play would be "ALBM". Read the manual.
http://www.retrevo.com/support/Sony-CMT-HPX9-manual/id/268dj180/t/2/
Jul 18, 2011 | Sony CMT-HPX9 CD Shelf System
Sony CMT-EP515 CD Shelf System. CDs wont play. Place CD in tray and close, disc doesnt spin but 4 distinct clicks heard then nothing
hope it helps.
Aug 04, 2010 | Sony CMT-EP515 CD Shelf System
CD player does not read CD disk but tuner works
are you using copied disks as some player will not real them. but if you using original disk then it could be the laser that needs a clean, use a ear bud, and a clear spirit (NOT WATER) use white rum or soething lik that but it has to be clear, cheers
Dec 12, 2009 | Sony CMT-NE3 CD Shelf System
Micro hi fi component system sony cmt-ne5 / ne3 I
Hello
Check its sled motor. It is the motor that helps to spin the disc inside. If disc do not spin inside, check the voltage at the terminals of this motor. If it is alright, and comes near to 5VDC, the sled motor is damaged and have to be replaced. OK.
Dec 03, 2009 | Sony CMT-NE5 CD Shelf System
Is their an aux function for a sony cmt-ne3
Nov 13, 2009 | Sony CMT-NE3 CD Shelf System
Cd player not reading discs. Sony cmt-hx80r. When loading cd the player does not seem to read disc and displays 'NO DISC'
The reader is not recognizing the disc which usually means there is a problem with the circuitry or the "eye" itself. It will probably cost you more to repair this unit then to purchase a new one. Especially since CD players have come way down in price.
Oct 16, 2009 | Audio Players & Recorders
System doesn't read CD
You can try cleaning the laser lens with rubbing alcohol and cotton swab. If cleaning does not work, the laser lens unit will have to be replaced.
Jul 29, 2009 | Sony CMT-NE3 CD Shelf System
Access MD function without remote
Sony CMT NE3. A solution to access MD/AUX function without remote.
If you accept to lose the function Tuner (or possibly CD but not tape) you could be interested with this method. Personally, I never use that function on this system. The idea is to feed the Aux input into the tuner input of the IC 302 ( a bd 3881). So, you select the tuner and you hear the Aux input. It works quite good (the display shows "FM" but it's not too much annoying...). You can reach of course the bass-treble etc. settings but be aware that it's not so easy: you will have to work with very small resistors SMD (about 1*2 mm) but, fortunately, only to take them away. It's easier.
You need a solder iron for unleaded soldering, a big lens, some classical tools and not to be blind.
You can get the service manual onhttp://elektrotanya.com/sony_hcd-ne3.pdf/download.html
But it's not really necessary : the scheme pictures enclosed come from this site. Please, look at them.
Ready? First, take off the rear cabinet (many screws...).
You will have to take off 4 resistors - R116, R117, R216, R217- and set two wires on the main board, located on the left side, under a metallic cover you need to take off (2 big solderings). The PCB is of high quality and the resistors are well indicated. I hope my pictures will help.
Take heart! You will make it easily better than me; my wires are a bit damaged!
Questions : why is it impossible to do the same with tape ? Because the tape input on the IC 302 is not equivalent with the tuner, cd, and aux inputs (there is an extra preamplifier).
Don't pay attention at the IC302 two wires you can see cut on the picture. I thought first it was necessary to isolate the Aux input from the IC. It's not necessary.
Enjoy your new Aux input without remote (and try to forget the tuner...)!
Alain G.From France
http://www.fixya.com/support/t501799-access_md_function_without_remote
Apr 09, 2008 | Sony CMT-NE3 CD Shelf System
Sony CMT-NE3 CD Shelf System Logo
288 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
