Question about Hotpoint Washing Machines
Door will not open on hotpoint wd420 washing machine door locked light not on
Turn off the power and isolate the water supply, Move the machine in to the middle of a room - you need some space. If you then rock the washing machine backwards, there is a door release. It's extremely hard to reach, about level with the lock, so make sure the machine is both stable and that someone is with you to ensure the machine doesn't fall and crush you to death!
It basically looks like an little electronic panel, in the middle of which you can see a steel knoble. Press with some force, and the catch will release.
This just happened to ours, and the actual lock is broken, so that was why we couldn't open the door. Yours might have a similar fault. The mechanism is partially plastic and it looks like the plastic sheared off and then the electric release no longer pulls the catch in to the position where it will release.
Posted on Dec 08, 2010
2 Suggested Answers
  • 42 Answers
SOURCE: Hotpoint wd420 clunking noises
Perhaps you are putting to much in it, poor machine, give it a break in its old age! All the Best -the Yeti PS leave room for the water!
Posted on May 17, 2009
Door stuck shut hot point wd420
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency
Apr 04, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My aqurius WD420 shows that the door is locked. So i can't open it........
If the door will not open normally, then the only solution is to remove the top cover, and force the door open from inside the washer at the front
Jan 17, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
Sep 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
May 17, 2009 | Washing Machines
WD420 hotpoint door will not open ?
In some cases switching off and back on again solves it. Otherwise try to run Rinse & Spin cycle again, and if after cycle door will stay locked you'll need to check the door lock itself, its wiring and/or main PWB
Please Update me how is it going on this
Mar 17, 2009 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT washerdryer WD420 The door dose not open after wash and there r no flashing light.Can any1 help plz with thx.
The interlock is stuck, you need to get behind the casing to release. this can be done by taking the top off and reaching down to the door mecanism and pushing the lever open. CAUTION disconnect the machine from the electricity supply before attempting this.
Nov 04, 2008 | Hotpoint Aquarius WD63 Front Load...
We have a hotpoint wd420 washing machine and it wont finnish a wash cycle. wont drain the water either, we do get an error code though in that the door locked light flashes as well as the reduce creases...
you have a blocked pipe - where the water is draining out. Either that or your filter is blocked.
best you open the back and take a look at the filter before calling out hotpoint - might save you 100 pound call out charge.
Jul 28, 2008 | Washing Machines
Washing Machines Logo
526 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
