Question about HP PSC 1410 All-In-One InkJet Printer
Addresses do not align with xerox 3r96289 label
    Genius:
  • 1,018 Answers
What do you mean by addresses?
Are you talking about connection ports, IP addresses, USB addresses?
Do you mean the X&Y addresses on the page itself? If that is what you mean then the resolution of the document must be checked.
For example, if the document is set for 600 X 600 DPI and the printer is set for 1200 X 1200 DPI the image will be severely compressed. Likewise if the document is set for 600 by 600 and the printer is set for 300 x 300 the document will be expanded and sometimes off the page.
You can usually tell by looking at the "PJL" commands on the front end of the job. That's the most common place to set the resolution of the printer. You can also set the image resolution from within the print datastream.
Please let me know if I can assist you further.
Don
Posted on Dec 12, 2009
SOURCE:
How do I transfer saved labels from Smart Label Printer 100 to Smart Label Printer 620?
In the SmartLabel directory under Program Files look for a file named label.sll This file holds your SmartLabel 100 addresses. After installing your new SmartLabel printer, copy the label.sll file into the new SmartLabel directory under Program Files. When you open the SmartLabel software, if you don't see your addresses, you may have to use the Import command on the label.sll file to bring your addresses into your new SmartLabel Application
Feb 27, 2015 | Seiko Smart Label Printer 100 Thermal
How do I copy smart label printer files from desktop to laptop
I'm making the assumption that your SmartLabel printer was installed on your desktop computer and now you want to use the SmartLabel printer on your laptop. I'm also assuming your what the addresses from your desktop computer. That said...
Seiko has eliminated the software and driver support for all older models but you can download the needed software from a third party site. Here's a link to the very stable version 4.61
Seiko SLP 100 Free Driver Download
Make SURE your SmartLabel Printer is NOT Connected!
Set Up Steps
A. Install SmartLAbel Printer on your laptop
1) Copy the Seiko software onto your laptop and begin the installation program.
2) At the point were the installation program asks, connect your SmartLabel printer
3) If the SmartLabel program is open, close it
B. Retrieve your SmartLabel addresses from your desktop
1) Look for the SmartLabel directory under Program Files on your desktop computer
2) in this directory find a file named label.sll This file holds your SmartLabel 100 addresses.
3) Copy the file to a USB Stick
C. Transfer your labels to your new installation on your laptop
1) After installing your new SmartLabel printer on your laptop. Insert the USB Stick in your laptop
2) Copy the label.sll file into the new SmartLabel directory under Program Files.
3) Start the SmartLabel software and open a new label, you should see the addresses from your desktop computer
4) If you don't see your addresses, you may have to use the Import command on the label.sll file to bring your addresses into your new SmartLabel Application
Hope this helps
Sep 28, 2014 | Seiko Smart Label Printer 100 Thermal
How do I print labels using the bypass tray on Xerox phaser 3635?
All I can add to your question is from my experience.
Make sure you have the recommended labels installed.
The fuser can cause jams when not using the correct recommended stock.
Very old labels tend to ooze a small amount of glue along the edges and can get stuck to the inside.
Print as you would do on paper, perhaps try printing on some white 80 GSM stock and hold them up to the light to check alignment.
Good luck.
Jul 02, 2014 | Xerox Phaser 3635MFP/X Multifunction...
How do I import addresses from excel to my Dymo LabelWriter 4XL Thermal Label Printer?
You first need to install DYMO Label. If you already have installed it, click Address Book > Import to import addresses.
^CM
Sep 05, 2013 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP2824 label alignment problem with MYOB Retail Manager
Ensure that the label size in your MYOB and also the printer driver are set to the same as the physical size of your label. Also do a callibration on the printer.
Oct 14, 2009 | Zebra TLP 2824 Printer
I have a Xerox WorkCentre 5638. How do I save
You cannot save the e-mail addresses on this unit except by creating a .CSV file and uploading it via CWIS under Properties>Services>E-Mail>Public Address Book. A link to the instructions is below:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=195,E=0000000001733361539,K=3118,Sxi=11,Case=obj(10395)
Sep 15, 2009 | Xerox Office Equipment & Supplies
I want to add an store email addresses on my xerox phaser 6115mfp
You need to use control center , which can be found at Xerox.com .
But here are the steps.
The MFP ControlCentre (MCC) provides an easy-to-use Graphical User Interface (GUI) that simplifies configuring the Phaser 6115MFP and managing fax directory lists from a computer over USB. The MCC stores configuration and setting information in a .dat file that is uploaded from the computer to the Phaser 6115MFP.
NOTE: It is also possible to save the .dat file to a directory on the computer.
To program dialing and enter recipient e-mail addresses using MCC:
  1. Click on the [Start] button, then point to [Programs], select [Xerox Office Printing], then [Phaser 6115MFP], and then click on [Xerox Phaser 6115MFP MCC]. The MCC window will be displayed.
  2. Click on the [Connect to Machine] button. 'Connection Status: Online' will be displayed in the MCC window.
  3. Click on the [Download] button. The current .dat file will be downloaded to the MCC.
  4. Click on the [Menu] button.
  5. Click on the [+] on the left side of the window to configure Speed Dial, One-Touch Dialing, Group Dial, and e-mail addresses.
  6. Enter the required settings, and then click on the [OK] button.
  7. When finished, click on the [Upload] button, and then click on [Yes] to save these settings to the Phaser 6115MFP.
  8. Click on the [Save] button to save the new .dat file to the computer.
  9. When finished, click on the [Disconnect] button.
Oct 02, 2008 | Xerox Office Equipment & Supplies
Printing addresses on labels
did set the parameters in the system before printing labels you can make a new printer control in printers section to only be label printed with the same printer you use
when you goto print click on the new print control that you have set for labels this way your software wont get the big confusion of paper or labels
May 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Printing on CD labels seem to ruin fuser in Phaser 7300
Probably the labels have a slight plastic fiber or coating in them and is getting a coating on the heat roller.
Here are part numbers of the correct CD labels you can run without a problem.
Xerox Matte Coated CD Labels, 6-Up, 11x17
Reorder 3R12373
75 sheets per box
spacer.gif Other items to consider: Return to Top spacer.gif Item Color Price/Unit Quantity Xerox Gloss Coated CD Labels, 6-Up, 11x17
Reorder 3R12372
75 sheets per box
Item Color Price/Unit Quantity Xerox CD-ROM Glossy Coated Labels, 4 x 7
Reorder 3R6322
50 CD-ROM Labels, 25 Sheets per carton
White - Glossy Coated 1-9 Box $17.44 10-49 Box $16.90 50-99 Box $15.65 100+ Box $14.89spacer.gif
Feb 22, 2008 | Xerox Phaser 7300DN Laser Printer
HP PSC 1410 All-In-One InkJet Printer Logo
90 people viewed this question
Clive
Clive
Thomas F. Schneider
