Question about LG Incite Cell Phone
Sometimes when I 'wake up' the phone by the phone / power button or the unlock button on the side, the screen stays blank. I can see that it is slightly backlit, and the backlight can be turned off via toggling the unlock button. Also, If I have someone call me when this happens, it shakes off the black screen. I usually end up soft resetting it. What's going on?
I cant use the touchscreen just keyboard
1) sometimes screen locking apps ch make your touchscreen u responsive.
Reboot your phone/tablet.
Press and hold the power button for 10 seconds or until your screen goes blank. Wait a min or two
and then power your device up normally using the same button.
2)Eject and remove memory card and sim card.attached to it. Also remove the battery for a few seconds.
3)Remove any cases their automatic screen wake/sleep feature can cause device to malfunction. Remove case perform a restart.
4)ADVANCE USERS ONLY
Hard Reset
If everything above jails you can do a hard reset. This will completely wipe your device and return it to its original settings.
Hold the VolUp&VolDown buttons at the same time then press the power button. This starts your device in recovery mode.
You can do a Wipe-Factory Reset from there.
Use the Volume up & Down buttons to navigate and press the power button to select.
BE CAREFULand DONT MESS with the other options or you may brick your phone.
These are different solutions. Not to be done at same time.
Apr 12, 2015 | Tablets & eReaders
Tip
SLIDE TO UNLOCK BATTERY SAVER
One of the annoying things I found as a 6700 owner is that I was always pocket calling people and that my battery had a very short life. my battery used to only last from 7am to 1pm before I had to change the battery or or plug inmy phone (PHONE ON A WIRE? this defeats the wireless phone theory). Now I can get a full day sometimes 2 days out of my battery because all the buttons are disabled from turning on the screen and the only button that turns on the screen is the top power button which shows the slide to unlock screen. when you have a incoming call the screen will offer you to slide to answer if you set it up with the easy to use settings that will be located in your programs folder after setup. the instructions for setting up this program are easy to follow at the download page.
Solution: Download and install this awesome app called slide to unlock.
It will save your battery if you set the settings to:
  1. lock when device wakes up to ON
  2. lock when back-light turns off to ON
  3. Power off in 30seconds
  4. but blank screen only OFF
  5. blank screen on talk I prefer OFF because you may need to look at something when talking. but you may squeeze more life out of your battery if you select on.
S2U2 is a simple lock/unlock application which has the iPhone style slide unlocking. It can be used as a screen saver while you don't use your device. And it has a CallerID function.
ENJOY
LINK for copy and paste http://www.freewarepocketpc.net/ppc-download-s2u2-v0-98.html
on Apr 13, 2008 | Sprint Vision PPC-6700 Smartphone
Motorola moto x
Tap the power button to wake it up. You may also press the volume button to wake the phone. Then you should be able to hide and show the keyboard.
Mark
Motorola Support
Sep 03, 2014 | Motorola Moto X XT1052 4G LTE 16GB...
Unlock screen
Is it locked by a password? Or something more terrible occurred to it? To unlock screen password, you can enter your iPod touch into DFU mode:
1. Plug in your iPod touch and turn it off. Hold down the "Home" and "Sleep/Wake" buttons for about twelve seconds.
You'll briefly see the silver Apple logo and then your touch will appear to turn back off.
2. Release the "Sleep/Wake" button but continue to hold the "Home" button until you see a message in iTunes stating that it has detected an iPod in recovery mode.
More about unlocking iPod screen password.
Jul 11, 2013 | Nokia C7 (8 GB) Smartphone
Blank screen with apple logo
Please charge your phone do a soft reset by following steps below.
  1. Press and hold the Home button (big circle below the screen) and the Sleep/Wake button(on top of the iPhone) simultaneously.
  2. Continue holding both buttons (Ignore Slide to power off ) until the phone shuts off and begins to restart and apple logo appears.
Hope this works.
Mar 12, 2011 | Apple iPhone 3G
My i phone is not responding to my touch to unlock it so i can get in my phone
Unlock:
Plug it into iTunes with it at the unlock screen. Somewhere it should say "Unlock your iPhone" or something like that in iTunes. Click it. Otherwise do a restore by going to the screen where it shows how much memory you have used up in iTunes and click restore.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 27, 2010 | Apple iPhone Smartphone
My iphone 4 is locked .is on 4.1 baseband 02.10.04
Unlock:
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Dec 17, 2010 | Apple iPhone (16 GB) Smartphone
Power up IMac but screen blank, fan on, light on but no response
I have one doing exactly this at the moment. It had gone to sleep and the fans were going like crazy. I think it is a Motherboard failure (it happened with many G5 iMacs), this one has been replaced once already, and I can't actually get it to install anything. I'm taking it apart tomorrow to see what I can find inside. If I fond anything I'll let you know.
Aug 07, 2009 | Apple iMac G5 Desktop
LG Incite  Cell Phone Logo
50 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
