Question about Neff B1641 Single circotherm super Electric Oven
Neff Circotherm Double Oven keeps blowing elemrnts. Ie. only works a few times then only gets warm
  • Neff Master
  • 3,463 Answers
I assume that you are fitting genuine elements, as opposed to cheap copy ones..
Make sure the fan is working o/k as well.
You also need to check the temp is correct, for this you need to have a oven thermometer to check it with.
Make sure the connections to the element are o/k as well.
Hope this helps with your problem.
Posted on Dec 12, 2009
Tip
Common heating faults with Neff U1421 Double oven,
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1421 Double circotherm Electric Oven
Tip
Common heating faults with Neff U1461 Double oven
on Jan 19, 2010 | Neff U1461 Double circotherm plus Electric...
My neff fan oven keeps blowing it element is there something wrong wit it? I have a double oven and its the bottom one that keeps blowing
It is quite common for neff elements to fail, make sure you have fitted the correct wattage element to it, as there are more than 1 element that will fit it.
Nov 12, 2010 | Neff U1721 Double circotherm Electric Oven
Neff circotherm doudle oven main oven fan working
It is more than likely that the oven element has failed.
You will it located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 09, 2010 | Neff B1641 Single circotherm super...
Tip
Neff U1452 Double oven Common heating faults,
For all Free appliance repair videos visit our VIDEOTUTORIALS
1, If the Neff fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1452 Double circotherm plus Electric...
Tip
Common heating faults with Neff U1661 Double oven
on Jan 19, 2010 | Neff U1661 Double circotherm super...
I have a Neff U1721 circotherm oven. The lights come on and the fan works but it does not heat up. What could be the problem?
For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
Nov 13, 2009 | Neff U1421 Double circotherm Electric Oven
Neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Aug 26, 2009 | Neff U1421 Double circotherm Electric Oven
3rd blown element
no connection between lights on fan. problem is that bulbs these days are poor quality (but cheap)
it is common for these circular elements to go. usually last about 2 years. worth checking tho that fan is turning at right speed
Jun 21, 2008 | Neff U1721 Double circotherm Electric Oven
Neff B1641 Single circotherm super Electric Oven Logo
161 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
bobby1964
Level 1 Expert
Paul Carew
Are you a Neff Oven Expert? Answer questions, earn points and help others
