I have soundcraft urei 1603 and when the music is loud i cant hear anything from the headphones only extremly loud snow and crackling and a little bit of the song but u cant make it out.. as soon as i turn the volume down on the gain or master u can hear it perfectly and i know its not the headphones cause ive tried 3 diffrent pairs plzzz help
  • 45 Answers
SOURCE: NAD C740 no longer reproducing music through loudspeakers
what was your amp? ic or transistorized? the output transistor of your amp may be opened, mostly it will short but because u still hear sound, maybe open and only the driver transistor are working. replacing output transistor or IC could solve the problem.
Posted on May 20, 2007
SOURCE: Logitech X-540 5.1 speakers loudly crackle when volume moved up or down
mine does that, its complety ok. Just run them at highish volume for about 30 secs should fix them, its just static.
Posted on Mar 05, 2008
SOURCE: No Sound from speakers from my T_Mobile Wing
If possible, place all data and media on a memory cars. Then, do a hard reset.
Posted on Mar 20, 2008
SOURCE: TASCAM DP02 CF
Try a seperate mike pre-amp, solved my problem. The output of both my dynamic and condenser mikes was too weak for the built-in pre amps in the DP02. Seperate pre-amps are also quieter than the DP pre-amps Turn the seperate pre-amps up first, then use minimal DP02 pre-amp. Good luck
Posted on Aug 29, 2008
  • 4234 Answers
SOURCE: Pioneer SA-9500 Extremely Loud Crackling
The volume control and tone controls are dirty as well as the selection switch. This is common for older units. These controls and switches need to be cleaned with an electronic switch cleaner which should be available from an electronics store. Spray each control/switch and work them (turn repeatedly). Repeat this procedure a number of times and the accumulated dust/dirt will be cleaned and the unit should no longer have the problem.
Please note that it is possible that there is a transistor or 2 that are breaking down that can cause this as well. If the cleaning does not resolve the problem, let us know.
Dan
Posted on Dec 19, 2008
Soundcraft spirit sx stuck in pfl mode
Probably one of your PFL switches is stuck in ON.
If not, the digital decoder went kaput.
Also could be your +5V power rail, that one powers the digital stuff...
Good luck.
Nov 11, 2017 | Soundcraft Music
The right channel on the headphone out does not work
Do the headphones you are using have a stereo plug. I find most times people are using a mono adapter plug of some sort..It needs to be a stereo plug. If it is, then contact this site and they can help with the proper parts to repair http://www.prosoundservice.com/
Apr 02, 2014 | Soundcraft *new* Soundcraft Epm8 Analog...
Can you plug a stereo headphone (for on stage monitor) to aux 1 on a Soundcraft fx12? This output seems to be only mono...
Generally mono outputs on this kind of mixer are usually balanced. This means all three poles of the connector are connected. The hot or plus signal (tip) will go to the left of your phones, the cold or minus (ring) will go to the right. This will be ok from a sound point of view But it may not have enough drive to make the phones loud enough.
If you only hear a signal in the left then the output is unbalanced.
A simple fix is a cheap headphone amp (less than 20 pounds) and a simple jack to two phono lead (wired as a split). There is a ton of old audio equipment about for very little money including some very small mixers, that have headphone outputs, that is what I have done a lot in the past.
Oct 31, 2013 | Soundcraft Music
My headphones crackle with loud music
your headphones my be damaged or "blown-out" This is common when played at high volumes. the crackling you hear is the result of the voice coil in the driver (speaker) contacting the cone. the only way to remedy this is to either replace the driver in the headphones or get better made headphones.
personally I recommend JVC RX300 because they are loud and have good sound quality and are cheap enough that the can be replaced when broken.
Jul 17, 2011 | Audio Players & Recorders
Hello. With my HD205 headphones, in the left headphone it has a small crackling noise with certain songs.. I don't know if its meant to be like that? Its done it since I had them first - Happens to bass...
There are two likely causes for this. One is much, much easier to fix than the other.
1) You are turning up the volume too much. Headphones, especially non-top of the line headphones, are not meant to be listened to at very loud levels. In this case, the crackling you are hearing is the speaker trying to reproduce a bass sound that is "clipping", or exceeding the maximum output level for that system. Remember - headphone speakers are very small; they have a harder time producing low sounds accurately. The solution is to just turn them down a little.
2) Assuming problem 1 is not the problem, the other likely issue is that they came with some sort of mechanical defect built in. If you are not playing them loudly, but you are still getting a crackle, especially if it is only on one speaker, they probably are broken. It is probably the jack itself, or the wiring leading up to the earpieces. Either way, it is not a terribly hard fix if you have some electrical know-how, but if you don't, there are plenty of people who can rewire them for much cheaper than it would be to buy a new set. However, if this has been happening since you got them, I would call the manufacturer first and see if they will replace them. Sennheiser tends to pride themselves in the quality of their equipment, so I would not be surprised if they sent you a replacement set.
Hope this helps!
May 03, 2011 | Sennheiser HD 205 Professional Headphones
Turtle beach x31 work for 1-5 seconds then sound stops.
I have the x31's and it sounds great and everything, but when my friends talk to me they say they can hear themselves talking. any sugestions?
Dec 30, 2009 | Voyetra Turtle Beach Ear Force X3 Wireless...
My grado sr 225's have developed a crackling noise
You have damaged the internal drive units,need replacing
Jan 18, 2009 | Grado SR-225 Consumer Headphones
IPOD TOUCH
same thing happened to me. your probably not plugging the headphones in all the way.
Sep 07, 2008 | Apple iPod touch
Sound problem
dear replace the speaker of ur phone in k300 the speaker and ringer are the same if u not have new speaker then short both point of the speaker to gather will be ok.
Mar 18, 2007 | Sony Ericsson K300
132 people viewed this question
 Grubhead
Grubhead
