Question about Sony Ericsson K800i Cellular Phone
Blank screen New Sony Ericsson W595 Worked perfectly for 3 days When turned on kepad lights up but screen remains blank
I connected my W595 mobile to my laptop with its usb cable, the laptop did not 'find' the device and it turned off. Now when I try to turn it on, the keypad lights work normally, but after 3-4 seconds it...
The laptop is shorting out the phone, try another usb port or test if the same happens when you place it in another pc. If so, replace the cable and try again.
Best Regards
Oct 23, 2013 | Sony Ericsson W595
Can you unlock my sony ericsson w595
Hi, You can unlock your Sony Ericsson W595 safer and easier using unlock code. You can get the accurate unlock code for a Sony Ericsson W595 from www.unlock-zone.com/sony-ericsson-w595/rs16wp9/ at affordable cost with easy step by step unlocking instructions. All the best mate.
Dec 11, 2012 | Sony Ericsson Unlock Code For At&t W300i...
When i turn on my sony ericsson w595 the keypad lights comes on but the screen dosen't then all of a sudden the keypad lights just come off.
The slider phones use a circuit strip that connects it to the base. With excessive using of slide, sometimes it loosens it self or is damaged. This damage causes the malfunction of the sliding function.
Aug 16, 2011 | Sony Ericsson Walkman W595 Cell Phone
W595 sony ericsson froze and now wont turn on
the exact same thing happened to me. i was in london and had low reception and that and i thought if i turned it off then back on it would be better again but now i just vibrates for a second shows the sony ericsson logo then goes black but the buttons keep lighting up and vuvrating but not turning on.
i dont know whats wrong but i think it has something to do with the battery so im going back to the shop i bought it from and ask them about it (lost reciept though :L) i might have to buy a new battery for it (everyone is saying something to do with an alein thin on the battey)
Feb 07, 2010 | Sony W595a Cell Phone
I have a sony ericsson W595, it worked perfectly until yesterday. my phone died, so i put it on charge. It seemed to be working perfectly normal until i slide the phone up. The screen then went black. i...
HI FRIEND...
i think it crashed try formatting the phone or restore into,,,factory restore settings,,,
thatsall thank u
PLEASE RATE IT....
Nov 10, 2009 | Lands Phones
My sony ericsson Z310i cellphone has now a blank grey screen
I fixed my daughters phone last night by doing this.
This is a simple connection problem, that occures at either end of the ribbon connection at the top right (looking from the back of the phone)
you need to take the phone apart the screen side and the kepad side.
pull the connector ribbon out of both ends and then ease the screen out of the casing.
re connect the screen ,making sure to push it in firmly.
then connect the other end of the ribbon.
Now connect the battery terminals and turn the phone on.
The screen should light up and resume normal function.
Nov 03, 2009 | Sony Ericsson Z310i Cellular Phone
Lcd light
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD screen is very easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony W580i LCD Screen Replacement
I hope that helps you out
Jul 24, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson W580i screen went blank
Ok, my phone had the same problem. I took the face plate off and the screen out and there's actually a little connector that connects to a board behind the screen(can come unplugged for replacement). I fiddled around a little with it and it worked fine. about a week or 2 later it happened again. I tried fixing it again and it would just flash white>black>lines>white, repeat. I know my phone's taken a bit of abuse, dropped down a road, soaked in rain, but it always worked after. These phone screens aren't meant to take abuse. Problem; the phone screen died. Solution; get a new screen.
Apr 20, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Sony ericsson w850i blank screen
I am having the same problem with my w850i, poweres up but nothing more than a blank screen? Any suggestions?
Jan 20, 2008 | Sony Ericsson W850i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
427 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
