Question about Woods INDUSTRIES 59383 OUTDOOR MECHANICAL HEAVY DUTY TIMER 7-DAY
Instructions on woods outdoor timer wth pins
How to you set the pins on the timer for on an off
Go to Woods heavy duty timer and there is three tabs below the advertisement, one will say "specifications" and at the bottom of the tab page is instructions in green highlight. use the instructions given for pin timer , it works on earlier models as well.
Posted on Nov 28, 2011
How do I set a Outdoor Timer Model 23ULD/3AOType 3R
Copy following link to identify timer, and see instruction manuals for each type:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 08, 2013 | Woods Outdoor Lighting Timer
Where are the pins on the 59382 outdoor timer
The 'segment pins' mentioned in manual are tiny segments located around outer edge of dial.
There are 4 segments per each hour.
Each segment represents 15 minutes.
Use small screwdriver or fingernail to pull segment up.
When segment is up, timer is OFF
Leave segment down, timer is ON
Timer is 500 Watt.
Timer handles maximum 20 strings of 50 mini-bulb Christmas lights
Dec 06, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
LOST MY INSTRUCTIONS ..... HOW DO I SET THE TIMER?
You posted under Woods 59204 outdoor timer.
If this is not your timer, add a comment.
manual for Woods 59204 timer
http://waterheatertimer.org/pdf/Woods-59204.pdf
Instructions:
Rotate dial until current time lines up with arrow.
48 segments (or pins) located around edge of dial > each segment is 1/2 hour
Set ON-off times by pushing pins in or out
Pins pushed out = timer ON
Pins pushed inward = timer OFF
Plug in timer.
Maximum 1250 Watts.
50 mini-bulb strand of Christmas lights is 25 Watts.
Timer will operate 50 strands of 50 mini-bulbs.
Long-winded guide for Christmas light wattage:
http://www.christmaslightsetc.com/pages/how-much-power.htm
Nov 29, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
I need instructions on how to use my outdoor timer for the model59733 the other number is 23uld/3ao
59733 appears to be Woods timer number, but Coleman Cable CCI does not have 59733 manual.
Internet search turns up no Woods 59733 number.
There is a Woods 59730 outdoor timer stake, but I can't find manual for 59730 either.
http://www.acehardware.com/product/index.jsp?productId=4433644&CAWELAID=604875525
I do not have 59733 timer photo or manual.
But some Woods timers go by more than 1 number.
Check if your timer appears on following page:
Woods also has promotional line of timers sold in retail stores, and many of these timers carry Woods name but nobody has on-line information.
If I find manual or more information I will post on this thread.
We need clear instructions for setting the timer
Woods makes several outdoor timers:
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
I can't find the pins that the instructions refer to.
Woods timers:
1) You posted question under Woods 59383 which has segments located around edge of dial.
These segments are pulled up to set OFF times.
Segments are left in down position for ON times.
2) Other Woods timers have tiny pins that stick up on the dial.
Pins are located on part of dial that rotates.
Get your glasses.
Run your finger across the dial and you can feel tiny metal pins that stick up.
Dial has 48 pins. Each represents 1/2 hour.
Use fingernail to move pins outward from center of dial.
Pins out = timer ON
Pins inward = timer OFF
Below are 2 EXAMPLES of Woods timer showing pins and segments
Nov 23, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Woods  INDUSTRIES 59383 OUTDOOR MECHANICAL HEAVY DUTY TIMER 7-DAY Logo
1,672 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Steve
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
