Question about Garmin StreetPilot C330 GPS Receiver
Power on, but just show logo, then turn off immidiately.nothing change after I remove faceplate and reset
Power on, but just show logo, then turn off immediately.nothing change after I remove faceplate and reset
  • kmenck Jan 20, 2008
    I have the same problem. I have tried to charge it in the car with the charger, but that doesn't help. What should I do?
  • 504 Answers
Have either of you tried charging this via the USB connection on your computer? Sometimes this helps. Give it a try.
Posted on Jan 28, 2008
I have an old garmin c330 that works fine but no sound. How do I fix this problem?
I checked the manual for my C330 and under the Resetting topic it says:
1. Unplug cables and remove external power
2. Place your thumbnail in the groove under the Garmin logo on the faceplate and gently remove
3. Press the Reset button for about 3 seconds
4. Connect the C330 to a power source. It should turn on and operate normally.
Aug 12, 2017 | Garmin GPS
Frozen Garmin C510
remove the faceplate, there will be a little notch at the top where the Garmin logo is. On the right side under the faceplate you will see a reset botton. Press the button and the unit will power off/reset.
Feb 23, 2009 | Garmin StreetPilot c510 Deluxe GPS...
Code problem
to reset the c550 place your thumbnail in the groove located under the garmin logo on the faceplate. Gently pull off the faceplate and press the reset button then connect to a power source and the unit should automaticly turn back on.
Dec 21, 2008 | Garmin zumo 550 GPS Receiver
Garmin StreetPilot c340 stop responding no sound, no movement at all - DEAD! Serial #116484764 Registration Code VADUCBQ
please leave the unit with out power for few hours and then again start the unit.
that may help you in some cases
Aug 12, 2008 | Garmin GPS
Garmin c340 will not turn on
Verify that plug is inserted fully and that the outlet is live. If that is good, then try the reset button which is hidden under the faceplate. Unsnap and remove the trim ring from the front by pulling with a fingernail under the logo. Press the reset button. If still no joy, check fuse in power plug by unscrewing silver nut on end of plug. If none of this works, then you might have a battery failure or other internal failure.
Aug 10, 2008 | GPS
Kenwood KRC -X858 Faceplate/Power Problem
I have the exact same problem. I called the tech line and the tech reported that the ribbon cable is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Apr 26, 2008 | Kenwood KRC-X858 Cassette Player
I can not turn on my 530 and it dos not show that the battery is being charged on the screen
Yes, there is a way to reset it. You can try the reset button under the faceplate, or a Master Reset. Keep in mind, a Master Reset WILL ERASE ALL OF YOUR FAVORITES. In order to do a Master Reset the unit must be off. Press and hold the bottom right of the screen, then press the on button. Keep pressing the screen until the unit asks if you are sure you want to reset. Follow the prompts. To use the reset button, you must remove the faceplate carefully (put your fingernail or another object in the indentation on the top of the faceplate, and pull it toward you). Then press the reset button on the right hand side of the unit.
Mar 02, 2008 | GPS
Will not turn on
Champ...If your 340 stops responding, try turning it off and back on.If this does not help, reset the 340.
1.Unplug the power and the usb cables to remove external power.
2.Place your thumbnail in the groove located under the Garmin logo on the faceplate and gently pull off the faceplate.
3.Press the reset button for about 3 seconds.
4.Connect the 340 to a power source using power cable. The 340 should automatically turn back on and operate normally.
Good Luck ... Ginny
Dec 26, 2007 | Garmin StreetPilot c340 GPS Receiver
Functions do not work even after resetting.
try cleaning the faceplate pins on the faceplate and the deck with alchool and q-tips, that dont work id start with peanuts :-)
Don
Nov 27, 2006 | Sony CDX-R3000 CD Player
Garmin StreetPilot C330 GPS Receiver Logo
65 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
