I have acquired a Oki C5540MFP but am unsure if this model scans. I have set it up as a stand alone piece of hardware (not networked) The installation discs seem to suggest that the model can scan but I am unsure how to set this up
    Sergeant:
    Champion:
  • 232 Answers
MFP usally means Multi Function Printer and these tend to scan as well as fax and print. Install all the software and it should be pretty self-explanitory. They may be a scan button on the printer or in most software packages such as Word.
Posted on Dec 12, 2009
SOURCE:
Hello Steffen, We have a 8830 scanner Synergix.
Hey Panos,
What are you trying to feed a paper roll or single sheets or are you telling me you cant feed the original to be scanned? Can you copy or print internal status pages from your Xerox?
But it sounds like thats not the problem as it isnt hooked up and your lappy as it dont have a serial port you only have USB...... but this is a network printer.... do you have a network or it is just a stand alone lappy?
So I guess.. stand alone lappy to Xerox.... you will need to network it... and if it just a stand alone lappy ie no network then you will need a non standard network cable called a crossover cable to go from scanner to lappy but you will also need to set up a network with them manually asigning IP's of each to be on the same network, then hooking with a crossover (normally red never blue) network cable, and you will also need the software installed on this lappy no matter which way we go
Spose you could try a serial to usb adaptor but they will have issues propally when trying to use that sort of interface on scanning, normally one has the print server that is an option on your scanner to interface with the likes of a laapy, so I dont think it would workor a good idea to go with an adaptor
Well come back with some more info because the more info you can give me about your problem the better i can understand it.. cheers
We are talking about one of these beastys.. User Manual
Cheers
Steve
Dec 16, 2011 | Xerox 8830 Copier
I have a ASUS laptop. It's not opening the internet when I click on the icon. I check the connection and the internet is connected. I tried resetting to manufactory settings but not exactly sure how to do...
I don't think you are having a hardware issue. i'm most probably sure that you are either getting a virus problem or a spyware blocking access to internet. First of all, you need to scan your hard disk with a stand alone antivirus scanner. i usually use the trendmicro stand alone or the kaspersky one. since you don't have access on this laptop you need to download it from another laptop and transfer by pendrive. you run the antivirus tool with deep scan to removev all virus. as regards for spy, i suggest the adaware spyremover. again proceed by downloading and transfer to infected pc. it should work. at last,you can check all ip address and resolve conflicts in DNS and gateway. i hope this helps you in fixing the internet issue.
Jun 06, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Stuck copy button
Snap off the cover off around it and attempt to release the button. Only shot.
Jan 05, 2010 | OKI C5500n Printer
Does the Fiery Controller have a time-out setting?
If you go into the Setup menu from CWS, and log in as the Administrator, you will see all of the scanning settings that you are able to manipulate. Also, this should be covered in your service contract with the company that sold you the machines.
Dec 02, 2009 | Konica Minolta Office Equipment & Supplies
My computer says it cannot acquire IP address from my D-link DIR615. I have been using it for several months with no problem.
What I would advise you to do is,
Uninstall the Network Adapter totally from the System first,
Then go to "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your Network Adapter).
In case its a Wireless Network adapter, After this, Press your Wifi button on the system and ensure that it is On, then Scan for wireless networks.
It should connect like that.
(In case you dont know how to uninstall the Adapter, Right-Click on my computer Icon, Properties, Device Manager, then select the Adapter under network adapters, and right click on it, then select uninstall.)
Hope this helps.
Goodluck
Nov 18, 2009 | Computers & Internet
Xerox 510 color scan option not turned on
HELLO
CALL XEROX ON THE FREE LINE FOR PURCHASING THIS OPTION ON
THIS WILL COST YOU RS:49,000 + VAT
THANKING YOU
RAMANA
Dec 29, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Connecting to Linksys as Router for Canon Image Runner 3300I
You can connect by using a hub. Then wire the hub to the machine and from hub to the stand alone pc. Still you have ot do some pc configuration to make the system running.
May 22, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Remote Network Question
some for your hardware need software, kindly check with hardware properties,configuration
Mycomputer -----right click-----properties-----hardware----check all the drives are compactable , without any question mark,
May 15, 2008 | 2wire 1000-200004-000 Network Adapter
OKI C5200 laser printer
Delete driver, download latest from oki, reinstall, is this networked or USB?
Is printer free from error lights, check page settings.
more I think about it, it seems to be a network/driver issue.
If printer can stand alone print ok ie menu map, then it is either the cable but more often the driver.
Check IP config if network.
Fixya or post back
Jan 02, 2008 | OKI C5200n Laser Printer
k24674
Marvin
Marvin
