Question about Brother MFC 420CN All-In-One InkJet Printer
Printer is feeding paper and ink cartridges are showing plenty of ink, but there is no ink reaching the paper. The sponge pad on the left side is sodden with ink
    Genius:
  • 1,018 Answers
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Posted on Dec 12, 2009
Nozzle test does not show pattern for either BLACK output; deep clean does not correct problem. both catridges have plenty ink. color displays are ok.
CANON MP780 BLACK DOES NOT PRINT
This is what works for me. Try at your own risk. I cleaned both areas.
CLEAN PRINTHEAD:
Perform a nozzle check using the Canon software under "maintenance." If the nozzle check prints successfully, the problem is most likely not with the printhead. Otherwise, 1) Lift up the lever above the ink cartridges. Take the ink cartridges out. Put them in a plastic zip lock bag. 2) The container in which the ink cartridges sit is removable. The container is inside the moving mechanism. The container is the printhead. Tilt it slightly and pull up. This should come out easily. 3) There are round pads under which the ink cartridges sit in the printhead you removed. The large one is black. On the underside of the printhead are small slits. The **** separated from the others is black. Fill a syringe with Windex. a. Run warm water over the printhead until no more ink comes out. b. Fill the areas where the round pads are with Windex. c. Set the printhead on some paper towels. The liquid will soak through and come out the underside along with the ink. Repeat steps a-c until no more ink comes out, but at least 10 times. 4) Let the print head sit and dry for two hours. Put everything back in the printer. Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
CLEAN PURGE MECHANISM:
You will need a light. 1) Unplug the printer and move the printhead all the way to the left. On the far right are two rectangular basins. The smaller one is black. Take your fingernail or a tweezers and lift out the sponge pad (do not drop it). Soak the sponge pad in Windex until it turns white. Plug in the printer. 2) Fill a syringe with Windex. a. Fill the basin with liquid. b. Let it soak for 5 minutes. c. Turn the printer off. d. Turn the printer on. Repeat steps a-d until you see a small hole in the basin. e. Put the syringe over the hole and fill the basin, pushing the liquid into the hole. f. Let it soak for 5 minutes. g. Turn the printer off. h. Turn the printer on. Repeat steps e-h 5 to 10 times. 3) Put the sponge pad back in using your fingers (do not drop it). Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
Nov 01, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Tip
Ink Absorber Pads - Cleaning them How To
Things you will need.
Needle nose pliers.
Paper towels
97% rubbing alcohol
Plastic gloves.
Flashlight
Disposable waste container, lined with plastic.
Disposable plastic tray about 6x9 or thereabouts.
Plenty of ventilation, outside if need be.
a. With the printer on, open this lid as if to change cartridges.
b. Turn Printer off. Unplug the printer. Unattach the communication cable. You will be moving it to a work area with excellent ventilation, such as outside.
c. At the far right where the the cartridges normally park themselves when not printing you will see a platform with rectangular compartments. When the cartridges park, this platform rises, seals off the nozzle area and captures any leaking ink, which till happens today.
d. Examine the platform with your flashlight and you will see what looks like sponges in the compartments. This material with holes in it, like a sponge, is plastic.Put on your gloves.
e. Place a paper towel folded over on itself underneath this platform as best you can to catch any spilling ink.
f. Use paper towels soaked in alcohol slightly and your needle nose pliers to push
the paper towel into each compartment, gently at first, until the majority of ink is
removed.
g. This will take quite a long time and plenty of paper towels and patience. So be
patient and ready for the long haul. Avoid smoking and the fumes.
h. At some point the sponge material, itself, may become dislodged and loose.
When you witness this, go ahead and remove it carefully using your needle nose
pliers and place it on some paper towels placed inside your disposable plastic tray.
i When you have one or both, if needed or more sponges removed and in the tray,
pour alcohol over these until the ink runs pretty thin. Leave to everything to dry.
i. Use a paper towel damp with alcohol and your pliers to clean out the compartment and its sides as best you can.
j. When you have completed these tasks allow the compartments and sponges to dry.
k. You are ready to reassemble the sponges into the compartments. Do so now.
l. Nearly done; take a towel wet with alcohol and hold it very gently against the bottom of the ink cartridge until ink flows freely onto the paper towel. If its stubborn, knock
the cartridge gently but sharply against a hard surface with the alcohol soaked towel held against the nozzle area.
k. Re insert the cartridges now.
l. Return the printer to its working location, attach power, attache the comm cable and with the lid closed apply power.
m. Run your printer through its normal setup routine, deep clean the print heads, run a nozzle check and finally do a print head alignment.
m. Your Printer is now ready to be used again.
Thank you,
Worldvet
on Aug 05, 2008 | HP Officejet 5610 All-In-One InkJet...
MP 610 is leaving black ink streaks the length of the page on back of paper. I have used the printer maintenance to clean the rollers, ink head etc several times and have installed a new black ink...
That sounds like the ink is coming off the waste ink absorbers. Try blotting the excess ink off the bottom of the printer with paper towels. The ink absorbers are small pads at the bottom of the paper feed path. With work, you can pull them pads and rinse them clean and then reinstall them when dry. Unfortunately, this can take almost disassembling the printer. Simply absorbing some of the excess is a temporary step.
I hope this helps.
(there is a counter that indicates when (based on average use) the waste ink absorber is full. The printer will stop working when that number is reached. Unfortunately, I haven't seen a reset for this model that actually works.)
May 17, 2010 | Canon MP610 Photo All-In-One Printer
Waste ink absorber full
Open the lid of your printer. Find where the cartridge slot is located when cartridges are not printing. Usually it's either on the left or the right end of the printer. There, you will see 2 sponges. Take plenty of tissues or some toilet paper and clean the waste ink absorber. May be a bit messy, so you can put gloves on. When you're done, put the cartridges back in (clean them too, if necessary), and please let me know if you still can't print.
Apr 01, 2010 | Canon PIXMA MP130 All-In-One InkJet...
My ip 4300 has stopped feeding paper
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 18, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Mar 26, 2009 | Epson Stylus C66 Inkjet Printer
Grey sponge came out when I pulled a jammed paper out of printer
its the ink blotter it collects any excess ink when you load in new ink cartridges you can still use it but watch out for any spills ...
hope this helps... jedi-inc...
Feb 09, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Printer show E 2 7.
Hi zaris79,
The E27 code means that the waste ink absorber is full. You'll need to clean the absorber pads and reset the error code. Here's how:
The absorber pads are on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way (you can move them to the left by hand if the printer is off). You might need a flashlight to see the pads - each is positioned in a rubber retainer.Take the pads out of the retainers with tweezers and clean them with warm water. If there is ink in the rubber retainer, wipe it out with a paper towel. Finally, put the clean pads back into the retainers.
If the printer does not realize that the absorbers are clean, it may still give you the error code - here's how you reset it:
1)With the printer powered off but connected to a power source, hold down the Stop/Reset button and press Power (the power light should light up).
2) When the Power is lit, hold down the power button, and press the Stop/Reset button two times (then release both - the printer should enter service mode. (Waiting for menu selection)
3) Press the Stop/Reset button 4 times to reset the waste ink counter.
4) Turn off the printer, and turn it on normally. That should do it.
For your reference, here is the complete list of error codes for the MP150:
E2 No paper (ASF)
E3 Paper jam
E4 No ink
E5 The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera-Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
How to take empty cartridges out
1. Cover the outlet hole with the orange outlet seal that came with the cartridge (a rubber band will hold this in place) to prevent ink loss during refilling or with your finger over the outlet port while wearing latex gloves .
2. Use the "L tool" provided to push the Sealing Ball into the cartridge (tap on the 'L tool' if the ball is stuck). If you can't see the ball just above the "push" then peel back the top label on the reservoir side of the cartridge to expose the Sealing Ball. This is the ball Canon used to plug up the hole after they refilled the cartridge.
3. Attach the needle to the syringe and fill with the correct color ink.
4. Slowly inject approximately 13 ml. of Black Ink or 6 ml of Color Ink slowly into the filling hole until the chamber is almost full. Unused ink may be returned to the bottle.
5. Seal the hole using the Green Plug. Put your finger on the green plug and twist until it is seated well in the hole.
6. Remove the orange outlet seal (or your finger) from the outlet hole.
7. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
8. If you have trouble getting your cartridge to print and the sponge side of the cartridge looks dry then drill a hole (or burn a hole with a hot paper clip) into the top of the sponge side of the cartridge. Stick the syringe needle into the sponge and fill with ink. You do not need to seal this hole.
If you are filling cartridges to use later, leave the orange outlet seal rubber banded onto the cartridge. This will prevent your sponge from drying out.
Note: On the CLI-8 and PGI-5 series cartridges, there is an electronic counter embedded in a small computer chip/board. This counter starts at a high number and decreases for every character printed. Eventually, the counter reaches zero. At this point, an error message is generated by the printer. If you click "OK" to the error message, the printer will continue to print.
If you have trouble getting your printer to print because it thinks the cartridges are empty. Look on your printer for an orange blinking light. This is your reset button, usually the paper feed button also. Hold this button in for 5 seconds until the light goes out. Note: this will not reset the ink level back to full.
Dec 10, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Ink absorber is full
Needle nose pliers.
Paper towels
97% rubbing alcohol
Plastic gloves.
Flashlight
f. Use paper towels soaked in alcohol slightly and your needle nose pliers to push the paper towel into each compartment, gently at first, until the majority of ink is removed.
g. This will take quite a long time and plenty of paper towels and patience. So be patient and ready for the long haul. Avoid smoking and the fumes.
h. At some point the sponge material, itself, may become dislodged and loose. When you witness this, go ahead and remove it carefully using your needle nose pliers and place it on some paper towels placed inside your disposable plastic tray.
i When you have one or both, if needed or more sponges removed and in the tray, pour alcohol over these until the ink runs pretty thin. Leave to everything to dry.
l. Nearly done; take a towel wet with alcohol and hold it very gently against the bottom of the ink cartridge until ink flows freely onto the paper towel. If its stubborn, knock the cartridge gently but sharply against a hard surface with the alcohol soaked towel held against the nozzle area.
Please rate this solution as Fixed instead of Helpful, although as helpful as it is, the point it to return the printer to working order.
Thank you,
Worldvet
Aug 05, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
63 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
