Question about Dell 3100cn Laser Printer
Streaks on left side
I've had a 3100cn for 2 years and have printed about 25,000 pages. Suddenly I started getting 2 brown streaks about 1/4" wide on the entire left edge of the page. This happens on both color and black & white prints. The more pages printed at a time, the darker and wider these streaks get. I reseated all the cartridges but it didn't help. Is this a drum problem or something else? I took the drum cover off the drum and tried it but I still have the same problem. So the cover must not be causing the problem. I am getting a "Drum Cartridge Replace Soon" message but I thought the drum is supposed to last a lot more than 25,000 prints. Is the streaks a symptom of a drum needing replacement?
  • 1 more comment
  • blair08 Jan 23, 2008
    I have the same problem. I have pulled all the cartridges out of it and tried to clean it throughly. I purchased a brand new drum and I still get the streak(one down the middle and two down the sides).
  • Anonymous Feb 12, 2008
    Hi
    The solution is here. (page 3)
    http://www.dellcommunity.com/supportforu...
    Yop
  • Anonymous Mar 25, 2014
    When printing it prints light streaks down the page.
Hi
Solution here
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&thread.id=22414&view=by_date_ascending&page=1
Yop
Posted on Feb 12, 2008
REPLACE DRUM CARTRIDGE THE CLEANER BLADE IS BAD
Posted on Feb 02, 2008
Brother 7220 black streaks
Clean the roller and the inside of the machine, asny residue on the roller will cause these black streaks. If cleaning doesn't cure the problem you will need to replace it.
Jan 18, 2012 | Brother MFC-7220 All-In-One Laser Printer
Dell 3100cn streak on left side of paper
Hello..
I would definitely check your margins on the printer and also look at the properties of the photos you are printing bc they may also be set a certain way. Does this happen on every photo you try to print? If that is the case, then it is definitely something with the settings on your printer or the picture itself. It may take a little time but I think this should resolve your problem. The other thing is your camera could also be going bad, i had one that did that so check that last. Also, if you had to install any photo software for the picture/camera you have, then uninstall it and reinstall the software.
I hope this helps!
d
Feb 22, 2008 | Dell 3100cn Laser Printer
I am having some very large, consistent streaks that just run across some of the top of my pages. If I print or copy out 20 pages only three or four will have this streak. It looks more like a stamping...
Sounds as though the fixing film assembly ( FM2-1793-020 ) in the fuser has developed a build up of toner causing what is normally called offset. You may also have to replace the lower pressure roller ( FC5-7207-010 ) also. You will have to remove the right side covers, door, and then the fuser assembly. Rebuilding the fuser has some challenges until you've done it a couple of times. Good Luck.
Jun 09, 2011 | Canon imageRUNNER 4570 Copier
Grey streak down the right side of the page 1/4 inch wide
Yip, its fuser film alright. You could pick up a fuser unit / kit from:
http://www.printersupplies.com/c-Laserjet3015Parts.html
and fix it yourself using the manual in this post:
http://www.fixya.com/support/t468332-fuser_removal_instructions_hp_laserjet
Best of luck
BD
Sep 07, 2010 | HP LaserJet 3015 All-In-One Printer
Lexmark t520 suddenly prints poor quality, i.e. the previous page prints softly onto the next page and the right side of the page (2" from right) is streaked with toner. Please help. TIA, Mike
this sounds like you have a fuser problem look at the fuser and see if it has toner build up on the rollers ghost printing can be caused by the toner cartridge or the fuser. this would indicate that your fuser isnt maintaining enough heat for complete fusing. is you take the rear covers off and run your print job. look to the far left side of the fuser and you will see the heat lamp lit up. this light should cycle on every 1 1/2 pages or so. any longer than that and it wont keep up with the print job
Oct 28, 2009 | Lexmark T520 Laser Printer
When printing, I see a vertical streak on the printed page, from top to bottom, about 2 1/4 inches from the left side of the paper, and about 1/16 of an inch wide. I can't seem to see what causes this. The...
This is more than likely down to the upper roller in the fuser assembly. It's the heat roller at the back of the printer. The upper roller wears so paper dust and toner stick to the roller which then can get deposited back on to the page.
Oct 15, 2009 | HP LaserJet 1020 Printer
Dell 3100cn Smudges on all color except black
Sounds like the fuser. Try heavier paper settings (you have to change them in all 3: driver, printer itself and program you are printing from). If that doesn't work replace the fuser.
Feb 24, 2009 | Dell 3100cn Laser Printer
Lines down both the left side of the printouts.
good day,
this usually occurs when you print large volume of copies of documents that goes beyond the printable area of the paper, some powders stick in the roller of your printer hence making the gray streak.
you can check if the rollers have accumulated some powder, if so, have the rollers cleaned.
i hope this will help.
Oct 14, 2008 | HP LaserJet 4L Printer
Black streaks on printout
Your fuser is worn out. Needs to be replaced.
Mar 27, 2008 | HP LaserJet 5p Printer
Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Aug 14, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
694 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
