Question about BenQ Monitor Lcd 24in G2400wd 1920x1200 Wuxga Black LCD TV
I try to connect the g2400wd monitor to a xbox360. Display is working but no sound. Anny solutions?
  • 29 Answers
Does your monitor have speakers?
Posted on Jan 12, 2010
Xbox360 to NEC Display NEC MultiSync PA271W
You need a DVI to HDMI connector. You will need to connect the audio separately to your sound system as DVI does not support audio.
Dec 02, 2013 | Nec Display NEC MultiSync PA271W-BK - LCD...
Hdmi connection
sounds like your TV is not compatible to ps3..or you can try to adjust your resolution
Jul 23, 2012 | Sharp AQUOS LC-32D44U 32 in. LCD TV
When iam doing work in my PC...small sound( tup ) has occured ( sound has came from inside the monitor ) and monitor is not display anything ...simply black...but cpu is working..so please tell me the...
try another monitor on the tower, if it works then the monitor is going bad, or has failed and needs repaired.
elah4@zoominternet let me know how / if it works for ya.
Dec 16, 2009 | Computers & Internet
When my monitor comes on, i see the gateway pic then the monitor goes black. i have the blue power button on and another square blue light eluminated just above the power on light? could this be a clue to...
Please check for the followings:
1. Check if display cable (which connects monitor to your display card in system motherboard) is properly connected.
2. Check to see if you have proper voltage maintain for your monitor and set the monitor to be used at 60hz.
3. Try using different display cable from another monitor or buy new one and see if this solves the problem.
Please do rate my solution as this will help me give you more proper solutions in the future.
Do let me know if these solutions are ineffective so that I could go for some alternate possible solutions for your problem.
Kind regards,
KK
Nov 03, 2009 | Gateway FPD2275W LCD Monitor
I want to connect directly to a computer monitor
The standard cable for an XBOX360 does not connect to a monitor. To do so, your monitor would have to have RCA jacks. However, they do sell a XBOX360 cable that has a monitor connector.
Oct 31, 2009 | Microsoft Xbox 360 Console
Monitor will no longer display my 360
problem caused by the GPU. I just fixed on the other day. you can fix them like the way you fix the 3 red light issue. you can get the repair kit for like $10. I got my from the site below.
Xbox360 Repair kit
Dec 10, 2008 | Microsoft Xbox 360 Console
Cannot display anything at all,sounds it is working but, cannot dispaly boot screen and rest???
Try connecting an external monitor to the Dell Latitude D820. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor has no display, then your problem is with either the video card or motherboard located inside your laptop.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 07, 2008 | Dell Latitude D820 Notebook
Game console and plasma displays
You did not list which console you have and what type of cables it has.
Looks like your plasma has:
1 component
1 composite
1 VGA
1 S-Video
If this is an xbox360 or PS3 then you will want to use the component connection, but this one is already used by the cable tuner. Don't worry there is a solution. The xbox360 and ps3 output a higher resolution that your plasma can handle, so use the component with those systems.
If it is an older console, predating the xbox360, then use the composite or S-video connections.
Since you are short on video inputs, you might need a video switch. A switch with both component and S-video connections for future add-ons.
You can find them all over the web, or your local video store like walmart and best buy. Here is a switch i found on ebay that should work:
http://tinyurl.com/3aoev9
here is the ebay search i used:
http://tinyurl.com/2ograc
Make sure you buy extra cables, most of these boxes do not come with cables, so buy what you need.
I prefer video switches that don't require a power outlet, but it's your choice. Some of the powered switches, have remotes for the lazy people, but I don't need anymore remotes on my table, keep that in mind.
Feb 14, 2008 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Acer AL1916W 19" LCD Monitor Blacking out
This is not a setting or driver issue! The best way to determine this is to connect the monitor up to another device to see if the same thing occurs! If it does then your backlight is in bad shape and it is starting to go bad. It will generate enough power to display some images, but when it continues to be on for a certain peirod of time it goes black. This is common when the backlight is starting to go bad!
Oct 04, 2007 | Acer AL1916W 19" LCD Monitor
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
BenQ Monitor Lcd 24in G2400wd 1920x1200 Wuxga Black LCD TV Logo
82 people viewed this question
Top BenQ Televison & Video Experts
Lawrence Oravetz
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
