Hi.
This is an universal replacement part, that is the reason why it is different from your TB original part.
The thermostat should have the temperature probe already attached.
Fit temperature probe and thermostat, then connect the element (s) wires on one side of the thermostat. The order in which you connect element polarity to thermostat does not matter. The thermostat will cut off power to element when the specific temperature is being reached by the temperature probe.
Thanks, The main connections i have figured out using a meter but the two connections left for the timer are the problem. Thanks
