Question about Samsung 500w Rrss Rear Reflecting Surround Sound Home Theater System
When i turn samsung HT-TZ212 home cinema system on the screen come up PROTECT and switces off. Why
    Problem Solver:
  • 5 Answers
Hi , your amp board need to replace , get one from ebay.
Posted on Apr 04, 2010
It could also be a short circuit caused by a nick in one of the speaker cables. This happened to me as I had a cable caught in the pivoting TV bracket. Repaired the cable with a 'chocolate block' connector and all was fine thereafter. Hope this helps.
Posted on Oct 08, 2011
Samsung dvd player switches itself onto protect!
hi,i can't connect my audio tv to cinema theater dvd
Apr 02, 2010 | Televison & Video
I have a samsung home cinema ht-tz212 keep saying protect and not working
its most likely over heated. Try removing the plug and moving it away from the tv and any heated areas for atleast a day, then try turning it on and it should work..
If it only goes into protect when you put a dvd in then change the regional code.
Feb 26, 2010 | Samsung Audio Players & Recorders
My samsung home cinema ht-tz212 wont play discs, just says loading, then open or disc error??? ive tried cleaning fluid lense cleaner with no luck ???
Try resetting the system turn power off then press and hold stop button on Main unit for at least 5 seconds this is main system reset it may well do the trick for you
Jan 31, 2010 | Samsung Audio Players & Recorders
Samsung hiome cinema protect error message
you need to change 5q tranzistor.if you dont have short circuit on pin 9 to ground on flat who comes from amplifier
Aug 04, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Ht-z210 home cinema protect error
Protection Error means that there is a malfunctioning component inside your unit. It will go into protection mode and immediately shut down to protect your system from any further damage. Unfortunately you would have to bring it to a dealer or repair shop to diagnose the exact malfunction and that could be expensive.
Gary
Jul 18, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
When turn on ht-tz212 it shows protect and turnes off again
I the same problem. When I opened the system up I find that I have a burnt out resistor on the power supply board. Can anyone tell me the value of Resistor number SWR60, which is located fairly central on the board.
Many Thanks
Dec 19, 2008 | Audio Players & Recorders
SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Nov 14, 2008 | Samsung 500w Rrss Rear Reflecting Surround...
Samsung ht-tz212 protect!
resistor smr60 is 470r / 470 ohm
Nov 08, 2008 | Audio Players & Recorders
Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Feb 02, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
725 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
