Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
My Grand Wega KF60xbr800, has had some ghost images on it for the last several monthes and now it will not come on. When I turn the power on the standby flashes constantly and I hear a buzzing noise from the right rear.
  • Sony Master
  • 5,138 Answers
If your TV is DLP it could be the Lamp or Ballast Board Lamp is a XL-2000U Fox has them fo 109.00
1-800-227-5369
Posted on Dec 12, 2009
SOURCE:
How do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking...
Good day!!!
6 blinks its the clear indication that you have bad power supply board..
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Nov 20, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
I have sony grand wega kf60xbr800. When I turn on power, about one or two minute,it turn off and it blinking on stand by mode light. Could you tell me what wrong. Thank you.
If you can hear the fans kick on when you power TV on and Set does not come on,and the Lamp has never been replaced then Problem will be the Lamp.
Mar 09, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
My KF60XBR800 will not always power up when we
Replaced the projection lamp again.Sony projection lamp more expensive,but last longer too.Genaric projection lamp brand last about 1 1/2 max.U hear clickinng sound too,when LED light flashes?Mean the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Jul 07, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
I replaced the main lamp 6 months ago. Now I have blue on the right, yellow in the middle and normal color on the left. I also have a ghost image of tree branches on the whole screen.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Found it here:http://www.discount-merchant.com/SONY-1-758-484-22-p/1180916.htm Have a blessed one!
Mar 31, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
There is a double or ghosted image now while watching the TV. It seems to be shifted to the left, almost like a shadow. Is there an adjustment that can be made?
Look on Menu for convergence adjust thier first if this does not help you may need to replace convergence ICs they are Big Black ICs will have part number on them STK-392-110 example. for Pats call Mats 1-800-628-1118
Nov 12, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Red ghosting
There is a bulletin that addresses this problem, but you must follow it EXACTLY as it invoolves changing settings in the service menu and you could easily make your TV unusable if you change the wrong thing. if you want the bulletin i could send it, but I would recommend you have a Sony qualified tech do the adjustment
Oct 31, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Double image
have you done convergence? and is there a auto focus?
Jan 07, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Ghost images
Sounds like a light engine issue to me. Is there anyway you can post a picture of the issue itself?
Mar 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
335 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
