Question about Hotpoint Ultima WF860 Front Load Washer
My hotpoint washer/dryer keeps coming up with code e30 see user guid and stops washing,what does that mean
  • Hotpoint Master
  • 3,463 Answers
Error code E30 indicates motor tachometer failure.
There is a loss of signal during tumble or spin.
Check your user guide.
Posted on Dec 12, 2009
What is E30 ?
E30/31: Motor problem - check motor brushes, drive belt, tachometer or tachometer magnet, motor relay or PCB (TRIAC motor control).
Jan 28, 2010 | Hotpoint Ultima WD72 Front Load...
Ultima 1200 washer dryer. what does E30 mean
Hi .
E30 is a problem relating to the motor, check brushes, if o/k then could be faulty or broken tacho magnet on end of motor shaft, also check for broken wires in motor plug.
Please rate my solution.
Thanks.
Aug 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
E30 flashing when I try to start wash program on Hotpoint Aquariu
E30 indicates a motor problem, you will need to call an engineer.
Possible worn brushes which you can do if you know what you are doing.
Nov 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Wd71 with e30 code on display when i try to use the dryer
try changing the thermostat located on top of heater in top of machine
Nov 08, 2008 | Hotpoint Ultima WD72 Front Load...
I have a hotpoint ultima 1000 coming up with E30 problem. can you help, I do not have a manual.
Jan 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima 1200 wm72
code e30 means motor fault. this can be just motor brushes, tacho fault or module fault. can't narrow it down more than this - you will have to dive in and check
Apr 05, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
293 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
